More cambelt questions.
Cigaro
PostPosted: 15:03 - 14 Jan 2009    Post subject: More cambelt questions. Reply with quote
I've had the cambelt cover off the Polo, and the belt that's on there is a 'Unipart' one and looks quite new and in good condition. The water pump and tensioner also look pretty much new.
This, to me, suggests that the cambelt actually WAS replaced at the 60,000 mile service, but whoever did it forgot to put a sticker on the cam cover. Surely the OEM belt wouldn't be a unipart one?
advice?
LustyLew
PostPosted: 15:08 - 14 Jan 2009    Post subject: Reply with quote
Was the 60k service done at an approved VW garage? Could have been done elsewhere and they dont bother with the sticker.
If you have the invoice, could give them a call, might have a history of parts used etc...
Cigaro
PostPosted: 15:17 - 14 Jan 2009    Post subject: Reply with quote
I don't actually know, I have no service history with the car.
I was just thinking that being a Unipart it doesn't seem to be an original belt, as they seem to do belt kits for almost every car.
The belt looks good and is not frayed or hardened anywhere, anyway. I have a replacement belt here but the thought of changing it scares me, so I may just leave it until the car reaches 100k (you're supposed to check them every 20k miles after the initial replacement and it's nearly on 80k now).
LustyLew
PostPosted: 15:25 - 14 Jan 2009    Post subject: Reply with quote
Do you have any old MOT's? Might be a chance that it was serviced by the same people..?
Other than that, I would have thought UniPart would be a pattern part fitted afterwards. I think only MG Rover probably used them for factory components.*
* - Waits to be corrected!
Cigaro
PostPosted: 15:34 - 14 Jan 2009    Post subject: Reply with quote
Cheers LH Smile
No old MOT's, only the current one.
Like I say, it looks like it's been changed, and is in good condition, so I'm not going to worry about it too much.
On a sidenote, does anyone know what type of oil I should use in this car? Would boggo Tesco Value 10w/40 do the trick?
Oil+filter change and clean out the Throttle Body is my task list for Sunday now Laughing
Walloper
PostPosted: 15:45 - 14 Jan 2009    Post subject: Reply with quote
Cam belt rule of thumb.
If it breaks you have a blistering bill for recovery, repair missed appointments etc.
If you want peace of mind, change it.
Not a big job and the costs are less than all the ugliness of the alternative.
Belts that break looked OK the day before so not always easy to say.
Oil I would never dare to advise on here. The bcf Lubrication Police will jump all over the top of me. Smile
Me I would put the best I could afford. Or what the OEM recommends.
WildGoose
White Van Man
PostPosted: 21:00 - 14 Jan 2009    Post subject: Reply with quote
If in any doubt about a cambelt - and in your position you can have no idea apart from assumption when that cambelt was changed and by who - change it.
What do they say about assumption? Laughing
Cambelt failure can mean a catastrophic engine failure in some vehicles, so for the sake of the price of a cambelt/tensioner and waterpump, and an hour or twos hassle, change it.
[EDIT] Added these pics for interest, this are what my transit engine did when the cambelt stripped. Learned later that this is what transit engines are designed to do in such situations, the push rods were designed as the cheap weak link to save major engine damage, as transits will be prone to a lack of maintenance.
The rockers break regularly too but less often, mine didn't fortunately.
You would never be so fortunate in a petrol or OHC engine.
Phoenix
Twisted Firestarter
PostPosted: 04:30 - 15 Jan 2009    Post subject: Reply with quote
Camchains and pushrods are where it's at.
It's a polo, Tesco or Asda 10w/40 will do just fine if you fancy treating it. As for old MOT's you can enter the details on the MOT website online to get all the old electronic certificates which will list where it was done so you might be able to find out where it was serviced.
Remember cambelt life depends heavily on how you drive, lots of town driving and short journeys will bring it's life down to near the recommended intervals, lots of motorways or continuous driving will mean it will most probably last a lot longer, of course how hard you accelerate and brake affects it too, though in a Polo I imagine that factor is negligible.
Swim41
PostPosted: 23:12 - 16 Jan 2009    Post subject: Reply with quote
I'm currently fretting over a Polo belt change too BassJunky. My motor is the diesel and it's a big job costing £££, but better safe than sorry I suppose Very Happy
arry
PostPosted: 23:47 - 16 Jan 2009    Post subject: Reply with quote
No, VAG don't use unipart belts - they use another brand that i can't think of for the life of me which is quite annoying, keep thinking gates but it's definitely not that.
Gah!!
Robby
Dirty Old Man
PostPosted: 23:53 - 16 Jan 2009    Post subject: Reply with quote
Why is it expensive in the diesel? If it does the injection pump as well thats another pulley for you to lock, but it shouldn't be too difficult.
And goose - cambelt and pushrods? Isn't that the worst of both worlds, why not just gear the camshaft off the crank and run the pushrods off that?
Stelmer
PostPosted: 00:10 - 17 Jan 2009    Post subject: Reply with quote
I've had a cambelt slip on me. Did just as much damage as if it snapped. Cambelts do not age or show signs of wear (apparently).
My dad's focus on the other hand was very close to slipping or snapping. The plastic tensioner pulley was disintegrating.
Now, when I buy another car, the first thing I ask is ''when was the cambelt last done"? Most sellers usually reply "I've not had it done''.
It gives me a good stand in getting £200-£300 more off the asking price. The first thing I do is then book it in for a cambelt at my local garage.
Then, sell the car shortly before it's due again. If the buyer asks, you did it when you got the car!!!! Twisted Evil
Swim41
PostPosted: 00:12 - 17 Jan 2009    Post subject: Reply with quote
From the research I've done it's well beyond me - most VW specialists quote around three and a half hours labour as there is a lot of dismantling involved.
I found this guide to the process on an American site:
https://www.tdiclub.com/articles/pdf/a4timingbelt.pdf
Shocked Shocked
arry
PostPosted: 12:32 - 17 Jan 2009    Post subject: Reply with quote
oh they do. They tend to laminate due to heat build up over time, and go very brittle/stiff
Finglonga
PostPosted: 13:12 - 17 Jan 2009    Post subject: Reply with quote
Most the time they don't though, plus how many people check their oil level regular let alone the cam belt.
Andy Sez....
F.Y.Y.F.F.
Trixie
PostPosted: 17:38 - 17 Jan 2009    Post subject: Reply with quote
Personally I'd change the cambelt for peace of mind. I've got a Zetec-S engine in my Puma and it's pretty cruicial to keep on top of the cambelt in that engine. When I bought it the woman selling it told me she hadn't had it done so I managed to knock her down by a few hundred quid. I then got the belt, tensioner, water pump and aux belt done.
Bear in mind, the cambelt might look new, but was the tensioner changed at the same time? A bodge merchant may perviously have got their hands on it and done half a job. For peace of mind do it yourself or give it to someone you trust.
Dead nobodies in company cars...
Method
PostPosted: 14:57 - 18 Jan 2009    Post subject: Reply with quote
If your worried just change it, its a polo - realy simple to do.
IF its a unipart then 99% its been done by a backstreeter / DIY.
Odds are if you track its old MOT's it will have had 2 / 3 MOT's at the same place, it would more than likely have had any servicing done there too. As a result, if its had a belt change, odds are they would have done it. Trace its MOT's online, check the garages and give them a bell to check.
If it looks good and its recently changed, odds are its fine, if unsure - just get it changed (assuming you want the car to last you another year or two).
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
The last post was made 17 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.29 - MySQL Queries: 13 - Page Size: 95.12 Kb
