| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 19:35 - 17 Jan 2009 Post subject: Xbox sound via HDMI ?? |
I've just plugged my Xbox into the new Samsung via a HDMI cable.. picture works perfectly (and it's amazing!) but I can't get the sound to work??! I've adjusted settings on the TV and on the xbox itself but still no luck. any ideas??  ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| Pedd |
 Pedd World Chat Champion
 Posted: 19:45 - 17 Jan 2009 Post subject: |
Some tvs have a hdmi power saving feature could be this ??, leave xbox on and turn the tv off then on again see if it detects the sound ____________________ Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around  |
| Colin Edwards |
 Colin Edwards Brolly Dolly
 Posted: 19:47 - 17 Jan 2009 Post subject: |
There was a thread a few weeks ago when people said an HDMi cable was an HDMI cable.. That a £15 cable was the same as a £99 cable... This is the reason why...
There are 3 versions of HDMI... 1.1, 1.2 and 1.3..
1,1 was video only
1.2 was video and audio
1.3 was video and audio but also supports advanced features like viera link from Panasonic (were one remote does all)
CE
https://en.wikipedia.org/wiki/High-Definition_Multimedia_Interface |
| carvell |
 carvell Scuttler
| Pedd |
 Posted: 19:51 - 17 Jan 2009 Post subject: |
go into your 360 display options, are you being shown the options for hd OR the video options for vga.
Also have you got the new nxe update or not ?? ____________________ Dont Click HERE
| Pedd |
 Posted: 19:54 - 17 Jan 2009 Post subject: |
try this
| Code: |
Hold the Y button and the R Trigger while your Xbox is loading - which will reboot your xbox - and then it should produce sound.
| Sparks! |
| Pedd |
 Posted: 20:24 - 17 Jan 2009 Post subject: |
as you are seeing all resolutions from 600 up then you are in vga mode NOT hdmi, hence you seeing the 640x480 etc instead of 480/720 etc. If your 360 has a hard drive remove it and turn on the console, let it boot to dash and then plug in the harddrive see if that helps.
Its in vga mode so thinks your tv is basically a monitor hence the no sound as pc monitor dont have speakers (some do but they have seperate audio in jacks) ____________________ Dont Click HERE
| Sparks! |
| Sparks! |
 Posted: 20:45 - 17 Jan 2009 Post subject: |
All I keep finding on xbox support website is mentions to their own cable which seems to have a HDTV/Av switch on it?? would a normal non-branded HDMI cable work or do you need this xbox 360 specific cable? ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| Pedd |
 Posted: 20:48 - 17 Jan 2009 Post subject: |
not sure what else to say fella, the fault is known and only affects the sound when using hdmi cable. you could try a compleate unplug of hdrive and memory card from 360 then totally disconnect power for 5 mins then reconnect 360 leaving hdrive and memcard out. ____________________ Dont Click HERE
| Pedd |
| Sparks! |
| Pedd |
 Posted: 21:21 - 17 Jan 2009 Post subject: |
have a look here fella as I've never used the component sid eof it tbh
https://www.engadget.com/2007/04/26/xbox-360-elite-vs-classic-the-test/ ____________________ Dont Click HERE
| Luke_Retrofly |
 Luke_Retrofly Silly Lesbian
| Pedd |
| Pedd |
 Posted: 00:00 - 18 Jan 2009 Post subject: |
another temp fix virtually the same as the other
| Code: |
Switch on the xbox, then remove the harddisk and plug it in again. The box makes a short reset and afterwards, magically, i get HDMI output in 1080p with sound.
| Sparks! |
The last post was made 17 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
