| Bishbash |
 Bishbash World Chat Champion
 Posted: 10:19 - 19 Jan 2009 Post subject: One lucky Mo Fo |
Well went to get a new tire at the weekend for the R1 and I drove from my house to Guildford tires, which is about 8 miles, I was taking it real easy as I had next to no grip on the rear.
On route my rear kept slipping out, I managed to control it and adjust accordingly. So after about 4 - 5 rear slips I arrived at the tire place and parked up, ordered what I wanted and handed the chap my key.
So I do the usual thing, go up to the reception and get reading MCN or a bike mag when I hear my bike start and then 2 seconds later;
Mechanic: "Guy with the R1?"
Me: "Yeah"
Mechanic : "Can you come down a moment?"
Me: "Sure"
So I get down stairs to my utter shock;
Me: "Whats up?"
Mechanic: "You're missing something"
Me: "Huh?"
Mechanic: "Come look" (Pointing at my wheel)
Turns out my wheel nut and spacer was missing and I just rode 8 miles thinking my rear tire was slipping when in fact the wheel was moving. The spindle had tried to come out, but only got about 5mm to where it should have been. Phew!
I had a complete look of shock on my face, then me and the mechanic just looked at each other and laughed. He said he has never seen that happen before. Well neither had I.
So I obviously had to leave the bike there and luckily there was no damage to the bearings or anything, so I just have to get a new space and nut, which add about £60 to my bill Oh well, it could have been MUCH MUCH worse, so I think £60 is fair game.
I was thinking over the weekend why it could have come off, the only solution I could come up with was I forgot to do the nut up tight enough when I tightened my chain.
So, I was rather lucky from that little ordeal.  ____________________ My current bikes are - YZF-R1 & GS 500 E
Trackday videos - https://www.youtube.com/user/bishbash13 |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 10:22 - 19 Jan 2009 Post subject: |
Lucky lucky. ____________________ My Flickr |
| JAMSXR |
 JAMSXR World Chat Champion
| Bishbash |
 Posted: 10:37 - 19 Jan 2009 Post subject: |
Yeah its the one in Chilworth, I always use them, as they are a great bunch as you said. And pretty good on prices for services/tires etc.
To top it all off the speedo cable snapped on my GPZ on Sunday as well. So I have two poorly bikes at the moment. ____________________ My current bikes are - YZF-R1 & GS 500 E
| CaNsA |
 CaNsA Super Spammer
 Posted: 10:39 - 19 Jan 2009 Post subject: |
you lucky boy.
good spot from the mechanic  |
| the grim reaper |
 the grim reaper World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 12:13 - 19 Jan 2009 Post subject: |
So not only did you not tighten it up you also forgot to put the split pin back in......
I always use R clips and when i take it out stick it in the ignition switch Can't start the bike without forgetting to replace it. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| 0ddball |
 0ddball World Chat Champion
| SoND |
 SoND World Chat Champion
| the grim reaper |
 Posted: 12:52 - 19 Jan 2009 Post subject: |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| Bishbash |
 Posted: 13:09 - 19 Jan 2009 Post subject: |
| iooi wrote: | So not only did you not tighten it up you also forgot to put the split pin back in...... |
No, it does not have a split pin. Not sure why it doesn't but, it doesn't.
| the grim reaper wrote: | I hope for your sake that you did not apply the rear brake or you could be looking at an expensive new rear wheel. I made the mistake of forgetting to tighten my rear spindle on my Thundercat, many years ago. I only got to the end of the road and applied the rear brake, then I found the problem. Unfortunately, applying the brake clamped the rear disc in the caliper but allowed the rear wheel to twist, this damaged the disc mounting and it failed the next MOT on a warped disc. Replacing the disc revealed the warped wheel mounts. |
No rear wheel lock occurred, but now you come to mention the caliper and rear disk, I will get them looked at, especially the rear disk, that would make sense that it could warp due to the wheel movement.  ____________________ My current bikes are - YZF-R1 & GS 500 E
| Tristan. |
 Tristan. World Chat Champion
 Posted: 15:01 - 19 Jan 2009 Post subject: |
I did that on my CG ages ago, rode 150 odd miles to Oxford, then about 120 back home when the spindle slipped out of the swingarm and the back wheel dropped off.
Did another 20 miles with some duck tape wound round the spindle thread and then it happened again, so I left the bike in a farm and walked back home  |
| nick606 |
 nick606 World Chat Champion
| Faldo |
 Faldo World Chat Champion
 Posted: 18:55 - 19 Jan 2009 Post subject: |
| Bishbash wrote: | No, it does not have a split pin. Not sure why it doesn't but, it doesn't. |
Surely your rear spindle has a hole through it to take a split pin or R clip?
I'm mega paranoid about this happening. In fact on Saturday I tightened my chain, and had to shoot out quickly. I'd put the bike back together, got to the end of the street and thought "Did I tighten the nut?", turned round and double checked (Of course I had). Just one of my biking 'ocd' habits.  ____________________ Current: ZZR1400
Previous: ZXR 400 L9, ZX-7R P5, ZZR 400, ZX-7R P6, Bandit 600, GSXR 750 Slingshot, DRZ400, DR650, ZX10R C1H, ZXR 750 L1, ZXR 750 L3, '99 ZX7R P4, KTM 300 EXC, ZX-9R E1, TDM850 |
 Posted: 19:11 - 19 Jan 2009 Post subject: |
Many modern bikes don't have split-pins in the spindle - they use nyloc nuts instead. ____________________ a.k.a 'Geri'
| Noxious89123 |
 Posted: 19:23 - 19 Jan 2009 Post subject: |
Stupid question, what's a nyloc nut? My cbr6 doesn't have a hole in the spindle to take a pin. ____________________
| G |
 G The Voice of Reason
| Wafer_Thin_Ham |
| Tristan. |
| Faldo |
 Posted: 19:43 - 19 Jan 2009 Post subject: |
I've never seen a nyloc nut used on a spindle either. If I bought a bike with a nyloc spindle nut I'd be getting my drill bit set out and a proper nut.
There's no way I'd be happy with just a nyloc nut. I'd also be replacing the nut everytime I'd have the back wheel off.
R clips all the way. ____________________ Current: ZZR1400
| G |
 Posted: 20:09 - 19 Jan 2009 Post subject: |
Perhaps not strictly 'Nyloc' brand but that type of self-holding nut, no split-pins or R clips. PS the condition of nyloc nuts is defined by the run-down torque so you only need to replace them if that is out of spec.
If you had this type of spindle and were worried about it then you could buy a spindle for a yank bike as they have to have a mechanical security like castle-nuts & clips on them in some states. ____________________ a.k.a 'Geri'
| thefallenange... |
 thefallenange... Crazy Courier
 Posted: 20:29 - 19 Jan 2009 Post subject: |
On my SV there is a washer which has something on it which bites into the thread if the nut were to wear loose or i was told. ____________________ Past - CG125 ,KR1S, SV650s, Street Triple R - Current - Duke 390
r.bridge1988@gmail.com |
| G |
 Posted: 20:31 - 19 Jan 2009 Post subject: |
Ok; never seen anything with a nylon-locking nut on the spindle .
Don't think I've ever seen one as big as most modern 'performance' bikes tend to have. |
The last post was made 17 years, 39 days ago. Instead of replying here, would creating a new thread be more useful? |
