| Jello |
 Jello Nova Slayer
| Itchy |
 Itchy Super Spammer
 Posted: 19:20 - 19 Jan 2009 Post subject: |
Multimeter across the terminals of the battery should not read more than 14v while revving the bike if it does the reg / rec might be fried but check the connectors first as sometimes the block connectors corrode...
Doesn't matter anyway as you have the kicker, and its not a good idea to use the lights on with the battery only anyway as it will kill your battery pretty sharpish.... hah here was me riding in the dark 80mph running total loss as the reg/rec had died.... took lights on I'd have been stuck outside warrington lights off I managed to limp to bolton.
Oh and if the reg / rec was replaced with a Honda one you have exactly the same problem again , I have a Kawasaki one on my Africa twin , it needs air flow and also needs to be cushioned from vibrations which means rubber mounts to the frame.
Ride around for a bit then feel the reg/rec if you burn yourself then this is very bad, it should get mildly warm if working correctly. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| lonner |
 lonner Spanner Monkey
 Posted: 19:27 - 19 Jan 2009 Post subject: |
you need a multimeter to check volt's .
connect to the battery and if its working you should see 13.5-14.7 volts with the engine running
check all connections for rust etc and earth's are sound hth
if you don't have a metre the lights will brighten slightly when you rev the bike and shows its charging
the battery may be shot and unable to hold a charge if its a couple of years old or a cheap nasty thing as some last 12 mths and will flatten very quickly  |
| Jello |
 Jello Nova Slayer
| Gawain |
 Gawain Nitrous Nuisance
| Jello |
 Jello Nova Slayer
| The Disapproving Brit |
 The Disapproving Brit World Chat Champion
| Jello |
 Jello Nova Slayer
| Gawain |
| Jello |
 Jello Nova Slayer
| Gawain |
| Finglonga |
 Finglonga World Chat Champion
| Stelmer |
 Stelmer World Chat Champion
 Posted: 17:44 - 21 Jan 2009 Post subject: |
Reg Recs can go bad many, many ways.
Wemoto guide:
https://shop.wemoto.com/info.dyn?title=Regulator/Rectifier
https://shop.wemoto.com/info.dyn?title=Battery_Care_Guide
If you can turn the lights off and on then the voltage should be a steady 13 odd volts when the lights are off and rise to 14 odd with the lights on at around 4000rpm.
I'd also be inclined to check the ground by doing a voltage test with the -ve wire attached to some metal part of the bike.
Bad connections in the reg reg loom can cause a low charging voltage as well as internal faults. The one on my GSX was not charging much above 13v because someone had butchered one on the loom using spade crimps and fed a wire to the live side of the brakelight switch to turn it on.
New proper crimps fitted and it now works spot on. |
| Bikeless |
 Bikeless World Chat Champion
| Bikeless |
| killingtime88 |
 killingtime88 L Plate Warrior
| killingtime88 |
 Posted: 09:22 - 26 Jan 2009 Post subject: Now fixed |
It turns out the 2 yellow wires from the mtx stator were shorted to earth/frame.
we have fixed this by replacing the mtx stator with one from an mbx125 this had the same cdi winding plus normal 3 wire charging system found on most bikes.
both the 2 wire ac lighting regulator and the 5 wire charging regulator have been removed and replaced with an mbx125 6 wire regulator.
the wires from the mtx two wire regulator can just be taped up as all regulation is now done by the mbx reg.
There is one side effect which we can live with and that is the headlamp now works at all times even without the ignition on.
anyway problem fixed.
And of course the headlamp is now fed with dc instead of ac this could have implications down the line with the headlamp switch if it is only ac rated.
Regards Paul
The last post was made 17 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
