What are the symtoms of needing a rebuild.
 Topic moved: from General Bike Chat to The Workshop by Korn (9 May 2004 - 00:36)
monkeyman
PostPosted: 00:35 - 09 May 2004    Post subject: What are the symtoms of needing a rebuild. Reply with quote
My NSR seems to be slowly loosing power. Its currently derestricted and was able to manage 85 which it could storm up to.
BUt now basically i can just about get 85 down hill with the wind behind me and it takes me longer than usual.
I think the power valve is still working as i get the noise when i start the bike. I haven't checked the air filter but i will do it tomorrow.
Im not sure when or if, it has been rebuilt because the guy i bought it off didn't know much about the bike.
it has currently done 9000 miles.
Any ideas people?
Also what is involed in a rebuild?
How hard is it, i pretty confident with a spanner i could proberbly manage a haynes 3 spanner mabye 4 with help from my dad.
Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750
Danny
Ask Me About Stoppie School
PostPosted: 00:55 - 09 May 2004    Post subject: Reply with quote
I had about the same symptoms, check the compression before you do a rebuild. Mine was about half the compression it was supposed to be before the rebuild.
The rebuild itself was a horrible matter, took me and Robby ages to do it.
I'm sure Keith will provide more info.
Robby
Dirty Old Man
PostPosted: 05:38 - 09 May 2004    Post subject: Reply with quote
Those sound like the symptoms pretty much.
The rebuild was horrible. It goes much more smoothly if you have the manual sitting next to you, but basically its a tight frame, not much room to work in there. Probably easier if you take the whole engine out, but then you need to put it back again.
Shifting the gudgeon pin was a total arse on danny's one. Took me 2 hours of gradually squeezing it out with a long bolt, 2 nuts, and a lot of washers.
And then I went and bought a bike with 250cc version of the engine for myself. Curious.
PostPosted: 11:59 - 09 May 2004    Post subject: Reply with quote
Does sound like it might need new rings. Do a compression test on it (it should be 142psi, give or take 28psi).
It is possible to get the top end off the engine on the early models, but the later frame looks like it would make it worse. On the early bikes it is quite easy to drop the engine out.
NSR125-Kid-UK
Attention Whore
PostPosted: 00:47 - 10 May 2004    Post subject: Reply with quote
robby wrote:
but basically its a tight frame, not much room to work in there. .
That's the bloody understatement of the year. There's not even enough room to get a plug socket in there without using a spanner to lever the oil/coolant tank out of the way Mad .
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
Danny
PostPosted: 11:08 - 10 May 2004    Post subject: Reply with quote
I never had problems doing that.
Robby
Dirty Old Man
PostPosted: 14:17 - 10 May 2004    Post subject: Reply with quote
No problem at all changing a spark plug on it. Its much easier to use a spanner to change one anyway - its a 2 stroke with a flat cylinder head and the plug sitting proud, no need to use a plug socket.
The last post was made 21 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 3.09 - MySQL Queries: 16 - Page Size: 52.94 Kb
