VFR400 speedo / derestricting question
lalaland
PostPosted: 02:15 - 10 May 2004    Post subject: VFR400 speedo / derestricting question Reply with quote
Hi,
I have just bought a Jap import VFR400 that's retricted to 113mph by Jap law. When you reach this speed two of the cylinders stop firing aparantly and you can't get any more power until you drop below 113mph.
I have heard of ways of removing this, mainly either cutting two wires to the speedo or changing the speedo to MPH from KPH by adding a converter to the cable. This then means that when doing 113mph the restricter doesn't think you are going as fast as 113mph isn't as high up the clock as what ever it's kph equivelant is.
I prefer the second option as I would like to convert my reading to MPH and leave the KPH clocks in place. It's easier and cleaner to just add something rather than chop something and I would like to know my MPH speed instead of KPH. I wouldn't change the clock though, just leave the KPH in place.
Does anyone know if this works?
My VFR is the 400 NC30 1992 import version.
Thanks
(anyone know what the top end is when derestricted?)
Stew
If it's good enough for top race teams...
PostPosted: 16:37 - 10 May 2004    Post subject: Reply with quote
Yes it does work. The restriction only kicks in when the speedo needle reaches 180kmh. With one of these little converters in place the needle never gets round that far (if your NC30 can do 180mph could I have it please) and therefore removes the restriction.
The other way of doing it requires you to open the clocks and either bend or remove the little bit of metal that is on the back of the clocks at the 180kmh mark, afaik you must make sure that you leave the metal bit that is at 0kmh though.
Oh and you should be able to get about 135mph (speedo reading) probably about 130mph real speed.
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
lalaland
PostPosted: 17:03 - 10 May 2004    Post subject: Reply with quote
That seems a very simple way of restricting a bike. I think I'll order one of these from Motrax.
I also saw a little black box and a wire that aparantly blocked the speed cut out signal to the engine, but the isntallation etc. seemed a pain and this way I get MPH and derestricted for the same price.
Are they easy to fit? Is it just a case of unscrew a cable at the back of the clocks, screw this on to the cable and then on to the clocks?
I won't do 130 mph of course, I'm new to bigger bikes and also it would be illegal, but it would be nice to have the full potential of the bike available even if I don't use it. Very Happy
Stew
PostPosted: 21:57 - 10 May 2004    Post subject: Reply with quote
Exactly like that. I bought mine at Hein Gerricke in Doncaster and fitted it in the carpark before riding home.
Bod
PostPosted: 10:20 - 11 May 2004    Post subject: Reply with quote
so instead of looking at the stickers for mph, the kmh becomes mph?
fazed
Korn is my hero!
PostPosted: 10:21 - 11 May 2004    Post subject: Reply with quote
yes.
Bod
PostPosted: 10:25 - 11 May 2004    Post subject: Reply with quote
Stuff it then, I'll do that instead. I was looking out for a MPH speedo for my ZXR400 but may do that instead.
lalaland
PostPosted: 10:53 - 11 May 2004    Post subject: Reply with quote
Does anyone know if it passes the MOT with the clocks showing KPH as their scale but actually giving MPH readings?
Bod
PostPosted: 12:06 - 11 May 2004    Post subject: Reply with quote
how wud they notice?
Laura
Playboy Bunny
PostPosted: 12:24 - 11 May 2004    Post subject: Reply with quote
When a 400 starts doing 180 mph but no I wouldnot have htought this would have been a problem for the mot ask kev.
Good girls ride motorcycles bad girls thrash them.
lalaland
PostPosted: 21:42 - 11 May 2004    Post subject: Reply with quote
I think I'll just do it anyway, my MOTs not until January anyway and if it's a problem then it won't be hard to uncouple the connector before getting to the MOT station.
carvell
Scuttler
PostPosted: 21:50 - 11 May 2004    Post subject: Reply with quote
I was considering this, but then it occured to me that it would completly screw up your mileage readings - so I went back to stickers!
Yamaha TDM 850
lalaland
PostPosted: 22:18 - 11 May 2004    Post subject: Reply with quote
Not really, just make a note of the KMs that you've done and then add them to the miles when done.
Shouldn't be a problem surely?
There is a gap of 5 years, 224 days between these two posts...
jasthabass
PostPosted: 10:21 - 21 Dec 2009    Post subject: Removing The VFR 400 NC30 Speed Limiter Restrictor Reply with quote
Hey Guys n Girls!!
I hadn't found ANY images on the VFR400 NC30 speed restrictor! (pain in the ass) I looked at the posts and all people would say is "Just bend this or that" but when i opened up the speedo there wasnt anything to bend.
So after a while looking at the insides i ripped this piece of metal out that went in between 2 magnets when the speedo reached 180 to limit the speed of the VFR 400 NC30.
See the photos! Just tested it about 20 mins ago and the needle goes deep into blank space!
Word of advice! (be careful with the speedo needle (the one that points at your speed) it breaks VERY easily!!!
https://www.unitedwebsitedesign.com.au/images/nc30-speed-restrictor.jpg
PostPosted: 12:10 - 21 Dec 2009    Post subject: Reply with quote
You can also bypass the restriction by attaching a resistor between two of the wires on the CDI.
I did work this out with someone a while back for his track bike but the thread must have been removed in one of the forum clear outs.
The last post was made 16 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 84.67 Kb
