| steppen22 |
 steppen22 World Chat Champion
| sickpup |
 sickpup Old Timer
| The Original Muzza |
 The Original Muzza World Chat Champion
| MarJay |
 MarJay But it's British!
 Posted: 23:58 - 22 Jan 2009 Post subject: |
My bad then. Read up a bit when I was getting my bike restricted and got the impression that was the restriction method on "most" EFI systems.  ____________________ Current Bikes: Husqvarna Svartpilen 401 (2020)
From then on, I and the bicycle feelings deeper. |
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| ncrn |
 ncrn World Chat Champion
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 09:35 - 23 Jan 2009 Post subject: |
You could make yourself a throttle stop if it's fuel injected. Make it so its the opposite of an idle adjuster. In other words; you can adjust the amount of throttle opening.
Take the bike to a dyno center and stick it on. Adjust to 33bhp. Then you should weld the adjuster in place so it can't be moved.
Job done I would say.
PS. What bike is it specifically? ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| MarJay |
| smegballs |
 smegballs World Chat Champion
 Posted: 16:22 - 23 Jan 2009 Post subject: |
My theory on restriction goes thus:
Get an "inline" rev limiter unit that intercepts signals from CDI, ECU (most likey easier on oldy bikes) etc etc
Get bike dynoed and find limit for 33bhp and set aftermarket rev limiter to this limit.
With the rev limiter switched out of the ignition circuit one can ride ones bike like the the firebreathing beast it is (or isnt).
If pulled discreetly flick switch over to have the "rev interceptor" in the ignition circuit.
LICE: "Is this restricted??"
ME: "Yes officer it is" *starts bike and bounces of say 5k rev limit* "See its got a rev limiter"
https://i44.tinypic.com/2uzf61i.gif
(Adapt circuit for particular bike, just an example)
Interesting point, on the assumption that the police pull you over at feasible 33bhp speeds say 80mph and they decide just for laughs to strip the bike by the roadside and find the limiter switch. (Copper is also a expert auto electrician )
When confronted about the switch they would have to prove the limiter was turned off to prosecute you right?
You wouldnt have to prove the limiter was turned on.
Rich |
| ncrn |
| smegballs |
| MarJay |
| Tristan. |
 Tristan. World Chat Champion
 Posted: 21:25 - 23 Jan 2009 Post subject: |
OK, heres another one, say on a CB500, parrallel twin, 50 odd brake and massive underseat storage, you install a long HT lead to one cylinder and route it under the seat and kep a pair of snips in there.
Pulled and the police say they're taking it to check, you ask if you can retrieve your wallet/family mementos/pet lizard from beneath the seat and discretely cut the HT lead, meaning it's running on one, and probably putting out about 20 brake.
Mind you, you now have a sparking HT lead next to your frame, and very close to your petrol tank, but thats the police dyno operators problem
....or
on a 600 sportsbike say, you see the blues and quickly so cut through your throttle cables and turn the idle up to full, yes officer this is how I always ride it.
OK so that wouldnt work, but I love the image of you waving at the police as you creep away slipping the clutch with a constant 4k RPM |
| temeluchus |
The last post was made 17 years, 267 days ago. Instead of replying here, would creating a new thread be more useful? |
