best all rounder for vertically challenged
r_o_b
PostPosted: 21:09 - 24 Jan 2009    Post subject: best all rounder for vertically challenged Reply with quote
Hi All
after riding sports bikes for 5 years its time for a change.
Id like to get into green laning/off road riding it looks like great fun and our typical weather suits this kind of riding just perfect.
I've been searching the net and im a bit lost with the many different models and classes of bike for example trail/enduro supermoto etc etc!! Not really sure where to start with it all! Shocked
i had a look at a recent thread titled
'Best/Good Commuter/Trails/Occasional Enduro Bike'
i found this quite useful as my requirements are practially the identical as those detailed in the thread by jackdim. same budget/something i can commute on/greenlane on 2-400cc etc etc
The only issue i think i will have is my height.... At 5'5'' i think im going have a limited choice as most of these bikes seem to be pretty tall.
Going on purley what ive been looking at online i quite like the look of the wr400 or the dr-z but have no idea if these two will fit me.
Any sugestions as to what might suit a shorty?
Thanks
PostPosted: 23:18 - 24 Jan 2009    Post subject: Reply with quote
I've ridden an XR250 and I'm about the same height as you. I did have a bit of an issue touching the floor, but I suspect you could reduce the preload a little...
I currently have a GasGas Pampera which I use for green laning and a bit of muddy fun. Its probably the shortest trailie that still has some ability. It has a trials based engine and has loads of torque and is good fun to ride. Its sat in the back of my garage not doing a lot at the moment to be honest.
I plan to get it MOT'd soon and then sell it. Your profile doesn't say where you are, but if you aren't too far from Reading then it might be something to consider.
It does have one or two downsides though. It runs on premix, it doesn't currently have a sidestand (although I have the stand and the spring, I just need to refit it). It does not have an ignition key and starts with just the kickstart.
However, it only weighs around 100kgs, which is pretty damn light, its got a trials based engine and so parts are plentiful. The tyres are nearly new Michelin enduro tyres and it has great brakes and suspension. Its a bloody nice little bike, but I just don't use it at the moment so can't justify MOTing it and then keeping it. So I might as well MOT it and then sell it.
garyd
PostPosted: 14:48 - 25 Jan 2009    Post subject: Reply with quote
Its the Honda CRF230 every time Laughing
CRF230 all you need
CRF_Rider
PostPosted: 15:22 - 25 Jan 2009    Post subject: Reply with quote
Have a look at the Scorpa T-ride should be perfect. Great fun bike with a highly capable motor.
Why is it everything i race, seems to be going backwards?
Current: Honda CRF 450 R Supermotard
Previous: Yam TY250 x2, Gas Gas TXT 200, Sherco 290, Suzuki TS 50,Honda CG 125, Yam SR250, Suzuki DR-Z400E, Yamaha YZF R6 112rwbhp
ben_wheely
PostPosted: 18:43 - 25 Jan 2009    Post subject: Reply with quote
Most/all trail bikes can be lowered...
Rides: '05 Yammy WR290-F
PostPosted: 19:13 - 25 Jan 2009    Post subject: Reply with quote
Correct, but they usually work best off road if they haven't. My Pamp for example is as designed, and very capable off road. I think a lowered DRZ400 would have both weight and height going against it.
The Scorpa T-Ride never actually existed as far as I can tell, or if it did it was never imported into the UK. The closest thing you can get to it happens to be a GasGas Pampera.
CRF_Rider
PostPosted: 19:40 - 25 Jan 2009    Post subject: Reply with quote
completely agree on the DR-Z
as for the T-Ride https://birkettmotosportukltd.co.uk/?Current_Models::T-Ride
there is a guy on the next street up from me who has got one. really smart looking machine. Goes very well too and super stable. An with a 800mm seat height should be spot on for you dwarf types with a great amount of manouverablity. although i'd be tempted to put in a regular SY flywheel tbh so its a little bit easier on the trails.
best thing i saw was a Rieju tango altough its only a 50/125cc if i had the time + money id take out the lump and put in a yam ty250 motor. Be great fun and the TY motor is known for just plodding on.
there is also the Beta ALP but i haven't ridden one and they look erm odd.
r_o_b
PostPosted: 11:07 - 26 Jan 2009    Post subject: Reply with quote
Quite fancied a dr-z but if lowering it will affect the handling then ill go for something else.
what about a wr? would that be the same situation as above.
I have considered the CRM230F and have also looked at the TTR250 but ive not seen many in my budget.
XR250.. ill have a look at those too.
Hi marjay, Id never heard of gas gas before... it looks a pretty smart bike though very light aswell looks like great fun. how does it go on the road?
Oh im based in twickenham, so its not too far from reading which could be handy should i go for that bike.
I guess ill get myself down to a local dealer aswell, just to try out a few different bikes for size before i decide on something.
PostPosted: 12:32 - 26 Jan 2009    Post subject: Reply with quote
Its OK on the road. Its got a lot of get up and go as it were. Its geared for trialsy type work though, so at the moment its top speed is around 55mph, and the enduro tyres make it 'interesting' to say the least.
Also, when I use the bike on the road I don't tend to use first gear as it is very short and the bike will pull away in second perfectly happily. This leads me to believe that higher overall gearing would give the bike a better top speed and better road manners. The front sprocket is absolutely tiny, so one up on the front and three down on the back should still be OK for offroading.
Here is the only picture I can find on my computer of the bike:
https://www.bikechatforums.com/files/offroadincropped.jpg
More info here:https://www.bikechatforums.com/viewtopic.php?t=108151&highlight=pampera
Since then I've added a Sigma Sport digital speedometer and I've added a rear brake light switch for the MOT. I have the sidestand and I think it will go back on OK.
r_o_b
PostPosted: 08:10 - 27 Jan 2009    Post subject: Reply with quote
looks quite a nice bike there and in the link you posted.
I dont think it would be all that practical for me, what with requiring premix and the ammount of day to day use on the road id be doing
i'll be using more on road than off so would need something a bit quicker too for the roads ill be using.
also the lack of steering lock/igition would be a bit of an issue for me(already had one bike stolen)
looks like a blast off the road though....
i know it will be a compromise between one and the other....just a case of finding the best one for me.
r_o_b
PostPosted: 13:57 - 27 Jan 2009    Post subject: Reply with quote
What does everyone think about a super moto type bike... are there many out there that are suitable for shorter riders?
with the tyres i guess they'd be better on the road but what do you guys think of taking a moto on the trails with sm tyres. Are they any good, or would that be asking for trouble?
I like the moto look. It could be more suitable as ill be on tarmac more than ill be off the road
Ive seen a few people change the tyres to knobblies or vice versa but it looks like you have to change the rims also to suit right?
meach
PostPosted: 14:42 - 27 Jan 2009    Post subject: Reply with quote
I am probably going to get hammered here but what about the XT660R
Ok ok i know its not everybody's cup of tea but with the R you will be able to commute and do some greenlaning too as standard.
seat height may be a tad high but you can lower them
2005 xt660x in red, not everyone's cup of tea but neither is coffee
https://www.youtube.com/imeach
PostPosted: 14:43 - 27 Jan 2009    Post subject: Reply with quote
You have to change the rims yes. Most people have a spare set of wheels. If you try to ride off road on supermoto wheels it would be not a lot different to taking a road bike off road.
Bear in mind that a Supermoto will be shorter than a normal trail/enduro bike because the wheels are significantly smaller. If you can ride a bike in SM guise it doesn't mean that you'll be able to ride it with a 19 inch front enduro wheel on it.
dudeskin
PostPosted: 22:23 - 31 Jan 2009    Post subject: Reply with quote
hi i've not read through this much.
but, im about the same high, i've come back from my ride today in a massive old quary, full of mud and rocks.
lots of fun.
i have a WR400 that i use as a supermoto and more recently for off road. i struggled abit in the mud as i could do nothing but slide around and not put my feet down very well. but if i was on gravle i wouldnt need to put my feet down.
you can drop the forks down about an inch, and problem solved.
i love mine.
dudeskin
live hard, die young, leave a damn good looking corpse.
r_o_b
PostPosted: 11:07 - 01 Feb 2009    Post subject: Reply with quote
I quite like the look of this... didnt really want something over 500 but it looks alright.
Thanks dudeskin....
ill keep in mind the WR400 as i could be an option in i can get the seat height down enough with out affecting the bike setup too much
eddclarke
PostPosted: 11:21 - 01 Feb 2009    Post subject: Reply with quote
Im 6foot1 and ride an xr250r, Its a pretty tall bike, ive got my suspension set up pretty hard, due to my size/weight. I think you would struggle a lot on a bike like this. even if you adjusted the rear shock a lot.
Honda XR125L 06 ----> Yamaha FZ6 05 + ex SAS XR250 --> VFR800 + XR250r
dudeskin
PostPosted: 12:11 - 01 Feb 2009    Post subject: Reply with quote
edd is right. my best mate had an XR250, a reasonaly old one, and i couldnt ride it as it was way too tall. he is also 6 foot 3 Shocked .
dudeskin
PostPosted: 12:28 - 01 Feb 2009    Post subject: Reply with quote
It does depend on set up a lot; bendy rode my KTM 200 EXC ok (similar height to Marjay.)
Then I adjusted the preload to be correct and I can only just touch the floor now (I'm a little under 6 goot).
The XT660 makes less power than something like a WR400. But, more importantly, it weighs about the same as my Triumph 675 track bike! Sure you can do green lanin on it, but it's going to be less fun; doubly so if you can only just touch the floor when you're not on a muddy slope!
I wouldn't get too worked up about cc; as suggest, the XT engine would be a pussy car to use in comparison to something like a Husaberg 500cc.
How about the BMW G650X_Country. This is a smaller version of the X-Challenge. Unfortunately with smaller wheels too, but you should still be able to get tyres ok for greenlaning in those sizes.
Good reliable (F650) engine for road work too.
r_o_b
PostPosted: 21:25 - 03 Feb 2009    Post subject: Reply with quote
lots of fun.
i love mine.
dudeskin
I like the look of the WR400... would like to have one of these if its rideable at my height
What are the service intervals like? and would it be suitable for a daily commute of around 20 miles.
also am i right in saying this bike only comes with kick start/no steering lock?
Thanks
The last post was made 17 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 110.82 Kb
