| Mattastic |
 Mattastic Trackday Trickster
 Posted: 23:28 - 10 May 2004 Post subject: Shocking front brake |
I have an 86 plate GS125 that has a front brake that is going to kill me! I bought the bike a month or so ago with 10 months MOT remaining and the bike had only done 300 miles since it passed it, so it must have been safe then.
I have no confidence in it at all, if I am going more than 20mph it alone won't stop me (I ALWAYS use the back in conjunction with the front in normal conditions). I have bought some new shoes for it (They are drum brakes you see) but have yet to fit these as I am waiting for my girlfriends dad to help me out as I wouldn't know what to do.
If the new shoes don't help it what else could it be? The bloke in the shop hinted that the lever may have been overloaded and that it may not be getting the leverage required to assert the correct pressure?
Any comments or help will be appreciated. ____________________ Too skint to buy a bike  |
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
 Posted: 01:10 - 11 May 2004 Post subject: |
Hi,
Don't know much about it, but here's my
Could be a worn out (or strectched) brake cable - replace it!
Could just need adjusting - I know that with drum brakes you have to keep adjusting them to keep them sharp (I think!)
Hope this helps, I'm sure Kickstart will set me right anyway, but at least it's something you can check in the meantime.
Mark ____________________ Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..." |
| Panther |
 Panther Nova Slayer
 Posted: 08:24 - 11 May 2004 Post subject: |
the drums may be full off dust too...a good strip down, clean and replacing the shoes should help as well as checking the cable for stretch and replace /adjust as need be...the existing shoes could be glazed?
When I serviced my small bikes every 1000 miles or so I stripped and checked them as routine. I used to rough them up with a wipe of sandpaper occasionally.
On bikes with front drums I always had to use the tried and tested 60/40 front back rule anyway as drums tend to be poor anyway....(not quite as poor as a CB100 cable disk but thats another story)...
 ____________________ Mike |
| Zx6man |
 Zx6man Nova Slayer
 Posted: 08:59 - 11 May 2004 Post subject: brake |
You want me to have a look at it matty? And in my opinion, drum brakes at the front are marginally better than puting your feet down to stop you.  |
| rizzla |
 rizzla Renault 5 Driver
| AcIdBuRnZ |
| Robby |
 Robby Dirty Old Man
| mr jamez |
 mr jamez World Chat Champion
| AcIdBuRnZ |
| rizzla |
| rizzla |
| mr.z |
 mr.z World Chat Champion
 Posted: 12:01 - 11 May 2004 Post subject: |
I wouldn't be supprised if they are just not far off that bad anyway! after checking everything through, just give yourself more time to stop is all i can say, not helpful for emergencys but not much can be done...
Keeping it adjusted should help a bit (had to do mine something like every 2/3weeks to keep it spot on) make use of the back brake and make sure that is in good working order as you might need it one day! Use engine braking as well to slow you down some (my cg had plenty of that!).
Be careful when dismantling brakes, DO NOT take it on the road before thuroughly testing it, if you use any grease inside the brake do NOT use high melting point grease as it will melt and foul the pads = big trouble, i used copper slip sparingly on the cam inside the back brake of my cx when it seized, its been working fine ever since, again don't let anything slippy on the pads/drum.
Just keep going on it till you can move up to something bigger, you will appreciate disc brakes and a electric starter ooooh so much more that people who are used to modern 125s!! ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Mattastic |
 Posted: 12:04 - 11 May 2004 Post subject: |
Well I'm taking the back wheel off on Saturday or Sunday so I can get the tyre changed so I may as well whip the front off at the same time. I have a feeling the shoes are glazed and from the outside view of the drum itself I wouldn't be suprised if they are a few years old, after all the bike had done only 1500 miles in the last 2 years. I've already got some new shoes so will look into getting them fitted. ____________________ Too skint to buy a bike  |
| Kickstart |
 Kickstart The Oracle
 Posted: 23:49 - 11 May 2004 Post subject: |
Thought the GS had a front disk brake in the 1980s.
Anyway, check it is all adjusted correctly. Possibly worth putting a new cable on (I am a bit paranoid about cable operated brakes). Check that the angle between the cable and the arm on the brake drum is about 90 degrees (this is the point where the torque will be greatest).
Also check that the handlebar lever matches the drum (ie, that nobody has just chucked on a front brake lever from another bike where the lever ratio might not be correct).
The last post was made 21 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
