| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 17:16 - 27 Jan 2009 Post subject: GSXR750 G starting probs...and only firing on 2 cylinders? |
Bear with me please, I have done a search but can't see any posts with my specific issues.
Got a new battery for my slabby, fully charged and also trying to start with a booster pack.
Will start eventually on full choke, when it does it idles but hideously roughly and cuts out shortly after or if choke or throttle are touched.
All 4 plugs spark outside the engine, but none look particularly strong (not entirely sure how big the sparks should be). They are new plugs. HT leads all seem in good condition and snug fitting.
When it does start and is run for a min or two, exhausts 1 & 2 (from left) are hot, 3 and 4 are stone cold. So on 2 cylinders, probably why the idle sounds so rough (and then cuts out?).
Fuel tap is on, gallon of fresh fuel in tank, not sure of condition of carbs but has been stood (with occasional attempts at starting) for about 6 months now.
What should I be looking at/testing next? Coils? CDI unit? Straight to carbs? Anything I've overlooked?
Cheers ____________________ CBR125|||GSXR400|||CBR400|||CBR400|||CB250RS|||GSXR750|||CB250RS
"You're clumsy, you eat too much and you behave like a 12 year old boy. But you know what? Every once in a while, you find a thumb." |
| lonner |
 lonner Spanner Monkey
 Posted: 17:27 - 27 Jan 2009 Post subject: |
personally id go straight to the carbs
check and a good clean is best imo (have you looked at the diaphragm's lately as they could be perished on an early gixer)hth
| NiteMare |
 NiteMare Spanner Monkey
| bootsbiker |
 bootsbiker Traffic Copper
| NiteMare |
| bootsbiker |
 Posted: 18:24 - 27 Jan 2009 Post subject: |
i took out the sparks and cleaned them.. They look good.. Got my mate around with his transit and tried to jump it, wouldn't start and it was down to no-spark.. First i cleaned the connect to the CDi.. YUK.. That wasn't the problem.. a connector come lose from the CDi to the coils. DUH
Replaced it now and i getting a dull spark, but a spark.. Problem now is m8 has gone home Tomorrow is a new day..
I am 100% sure the battery is a gonna. Can tell just by the way the starter motor turns..
"flatties from a slabby" not use to the jargon,, think I know what u mean
If any1 can tell me to remove the carbs without to much brain power would help.. I hate doing things blind..
cheers Boots |
| NiteMare |
 Posted: 18:34 - 27 Jan 2009 Post subject: |
if you really want the best possible source of information regarding your slabby i suggest you register with "old skool suzuki" ...
introduce your self in "general" then dive into "oilcooled" with your question of "how to remove carbs", there'll be plenty of folks there that'll be able to tell you exactly the procedure
P.S.
i wouldn't remove them until you've tried jump starting it again, there's absolutely no point in making work for yourself ____________________ it ain't broke...
i ain't fixed it enough |
| NiteMare |
 Posted: 18:39 - 27 Jan 2009 Post subject: |
just an extra to my previous posts regarding "flatties" ...
apparently they rattle quite loudly, this can vary quite a bit depending on wear but they rattled from new ...
so don't get too panicky about the strange noises  ____________________ it ain't broke...
| Robby |
 Robby Dirty Old Man
| bootsbiker |
| NiteMare |
| bootsbiker |
 Posted: 19:26 - 27 Jan 2009 Post subject: |
I wasn't going to use it for the bike... Just out of interest and nice to have free info etc... I like the pic as well..
We covered carbs in college but only just.. Fuel injection was the topic(cars)..
Bit off subject... are all new models of bikes fuel injected now or are they putting in carbs still in new models??
You r right through should just find a manual.. |
| NiteMare |
| lonner |
 Posted: 19:41 - 27 Jan 2009 Post subject: |
| Ichy |
 Ichy World Chat Champion
 Posted: 23:09 - 27 Jan 2009 Post subject: |
FWIW.
My old GSX used to do exactally the same if it was left for any time. It would be a pain to get going and then only run on two cylinders for a few minutes with loads of back fires.
I used to connect it to my car battery then either heat up or swap the plugs on 3 and 4 and they would eventually fire up and run fine.
I'd definately do what nightmare suggested and make sure the plugs are connect correctly, done it myself plenty of times.
New plugs can work wonders.
I've owned loads of bikes over the years and have only needed to clean the carb once due to varnish blocking the jets. That bike hadn't moved for 8 years. My old GS wasn't used for three years and started up in minutes with a gallon of petrol, warm plugs and a car battery.
Are you running pod filters or standard? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| bootsbiker |
 Posted: 14:31 - 28 Jan 2009 Post subject: |
sorry Mudskipper for butting you thread but didn't want to start 1 myself.. this is more of an update
ok.
Mate came back and we hooked up the transit and if by magic it started with 15s.. I did spray some easy start (i didn't say that) but that was yesterday so i reckon it has vaporized over night.. c how it goes with it's own power source..
It was only running a few minutes and cut out but we unhooked it etc.. Was coughing a bit but hasn't run for a while and its cold.. will put a new battery in and then run it for a while on idle.. would go 4 a ride but no tax or mot..
I joined that forum but havin asked about the carbs yet.. Still would like to clean them but it can wait..
now the forks seals.. god damn the rain.. |
| Mudskipper |
 Posted: 15:01 - 28 Jan 2009 Post subject: |
| bootsbiker |
| damz |
 damz World Chat Champion
| NiteMare |
 Posted: 19:17 - 28 Jan 2009 Post subject: |
i just use a blowlamp on plugs (forget about wasting oven gas ), if you haven't got a blowlamp use the gas "ring" on top of the oven ...
obviously you take the plugs out first, then play the flame onto the threads/metal body of the plug....
i heat plugs until they're almost too hot to hold and have to keep rolling the ceramic in my fingers to stop it from burning me ...
then just drop them back in the holes and nip them up with a socket/box spanner...
be a little careful of overheating the starter motor by just keep spinning it over, give it a chance to rest and cool the windings off, we don't want you asking how to change the starter next :p
Damz...
it sounds more like your bike was struggling to get fuel thru even tho the choke was on, once it had caught on all four pots it made it easier to draw fuel thru as the revs picked up slightly ____________________ it ain't broke...
| Bikeless |
 Bikeless World Chat Champion
| bootsbiker |
The last post was made 17 years, 239 days ago. Instead of replying here, would creating a new thread be more useful? |
