my battery keeps going flat!
veze
PostPosted: 21:50 - 26 Jan 2009    Post subject: my battery keeps going flat! Reply with quote
my battery kept going flat, so i bought a new one, but that goes flat after a day! is it the regulator?
beacaus i know the alternator is working because even though there wont be enough power to make that flasher unit work, it will when i rev the engine.
so regulator maybe?
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
loply
PostPosted: 21:53 - 26 Jan 2009    Post subject: Reply with quote
Do you have a multimeter?
Yamaha SZR660 Caution to the wind, the throttle pinned!
veze
PostPosted: 21:58 - 26 Jan 2009    Post subject: Reply with quote
yeah i got one at my dads house
loply
PostPosted: 23:45 - 26 Jan 2009    Post subject: Reply with quote
Alright, set it to 20vdc and put the two prongs on the terminals of your battery. Probably get 12.8v or thereabouts.
Turn the engine on, and measure it again. If it's normal you should get 13.5v or therabouts.
Rev it up to 4k or thereabouts, it should rise now to something like 14v.
If the voltage doesnt go up when you turn on the engine and/or rev it, then your charging system isnt working probably. Either the alternator or reg isn't doing its job. You can test those by following the procedure in your workshop manual.
If the voltage DOES work as described above, then it appears to be charging. Perhaps it's running out when you arent using it...
To test this, disconnect the positive red cable from your battery. Set your multimeter to ADC and put one prong on the positive terminal of the battery, and the other end on the cable you just disconnected. With the engine OFF this is.
It'll tell you how much current is being drawn by the bike. Ideally 0! Sometimes 5-10ma if you have clocks or alarms. Any higher might indicate a shortcircuit or faulty handlebar grips or suchlike.
NSR Mick
PostPosted: 02:45 - 27 Jan 2009    Post subject: Reply with quote
Does the bike have a cheap alarm?
PostPosted: 04:15 - 27 Jan 2009    Post subject: Reply with quote
Also check you aren't leaving the parking lights/heated grip on?
veze
PostPosted: 21:40 - 27 Jan 2009    Post subject: Reply with quote
no alarms or heated grips, ive tried that test on the batt, the voltage doesnt improve that much, alwost reaches 13 but not quite. if the regulator/ rectifier is but should it run hot? someone told me that. i havent had a chance to test it just yet?
if its that thats but im goin up newark autojumble on the weekend hopefully i could pick one up.
hopoffbaby
PostPosted: 00:39 - 29 Jan 2009    Post subject: Reply with quote
Hi all, im having a similar problem with my bike.
It doesnt seem to hold its charge for more than a few days without use. I have just brought a new battery but want to check the old one while its still on the bike because i want to know if my heated grips are causing the problem.
I understand the bit about the VDC test.
What i don't understand is how to set up on my multimeter to do the ADC test.
My multimeter has 3 sockets on it. I have the black lead plugged into the one that says COM. The red lead is plugged into the one that says "V<ohms>mA" (the other socket says 10ADC) is this right? I dont wanna blow up my bike lol.
Neil.
el_oso
PostPosted: 12:00 - 29 Jan 2009    Post subject: Reply with quote
the multimeter will not do any damage to your bike no matter what weird and wonderful way you may set it up it will just give you an incorrect reading or no reading at all.
a good garage will check whether you have a dead battery or not for free. take it into them if your not sure. batterys do tend to die this time of year especially if they havent been run for a while or used for short journeys
Sir Black Pig
PostPosted: 12:11 - 29 Jan 2009    Post subject: Reply with quote
For the Amps DC Put the black lead into the COM (-) and the red lead into the ADC (+) and measure, setting you multimeter dial to DC Amps.
The reason ADC has a seperate socket is that is individually fused so if you have a massive surge it will protect the muttimeter and (of course) you!
Hope this helps.
Eurotrip 2009
Sportugal 2010
loply
PostPosted: 19:53 - 29 Jan 2009    Post subject: Reply with quote
If the voltage doesnt reach 13v even wen revving the engine, then definately its not charging.
Either the reg/rec is shot or the alternator is, or any of the wiring/connectors that they rely on.
To test the alternator is pretty easy, just find the plug going into the reg/rec that leads back to the alternator. Itll probably have 2-4 wires in it. Run the engine, disconnect the reg/rec and test the AC voltage between those... I dunno what you would expect, maybe 60v or 45v or something.
If it's 0v or 5v or something daft then it's your alternator. If it seems normal (check the right amount in a manual) then it's presumeably the reg/rec and not the alternator.
loply
PostPosted: 19:56 - 29 Jan 2009    Post subject: Reply with quote
Incidentally if you ride without your lights on and charge the battery nightly you can probably ride it like this for quite a while.
Obviouslly though just bear in mind you are using up battery charge like fuel, so always make sure you are able to charge it, and try not to turn the engine off till you get home (else it might not restart)!
Sir Black Pig
PostPosted: 10:34 - 30 Jan 2009    Post subject: Reply with quote
This is true you can, however, this is very ill advised, you may be in a potentially very dangerous situation and a total power loss cripples you! Shocked .... (ie. The battery goes flat).
Eurotrip 2009
Sportugal 2010
PostPosted: 15:16 - 31 Jan 2009    Post subject: Reply with quote
Well not really as you generally get warnings if your battery runs flat when riding. The bike will start to mis-fire when you use the brakes etc. They don't usually just cut out dead.
veze
PostPosted: 22:26 - 31 Jan 2009    Post subject: Reply with quote
ran out of battery earlier, took to hours and 4 long hills to get home. i tried bumping it but the back wheel locked in all gears even with me jumping on it. it was a farce. i will test hat in the morning then and hopefully i can see what the problem is.
cheers folks.
Phoenix
Twisted Firestarter
PostPosted: 00:24 - 01 Feb 2009    Post subject: Reply with quote
Regulators are a pain in the arse to check with a multimeter, the readings never come out right. It sounds like it's your regulator anyway, they do run hot and heat kills them over time. You should be charging at over 13volts and if the bike is dying while you're riding it's not a current drain or short somewhere that's causing your flat battery it's the charging circuit, and i'd bet on regulator rather than alternator.
The last post was made 17 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 91.91 Kb
