| Slinn84 |
 Slinn84 Scooby Slapper
| stinkwheel |
 Posted: 13:08 - 29 Jan 2009 Post subject: |
Shock and release spray and/or penetrating oil (as opposed to WD40).
Start spraying now to give it time to soak.
That said, if you are doing the seals, it might act to your advantage. Might make it easier to pull the pistons out if they are stuck to the pad, then you can put the pad in a vice and knock the piston off it with a bit of wood and a hammer.
Mind you. If it is so corroded you can't get the pads off the pistons, I'd imagine the pistons would need replacing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lonner |
 lonner Spanner Monkey
 Posted: 15:20 - 29 Jan 2009 Post subject: |
hi if it was my zzr11 same brakes i would un-bolt the caliper from the disc and then lever the pads and pistons back into the caliper.
then put a socket extension bar at one end and then use the brake lever to apply some pressure (don't go mad) the force at one side should break the rust seal hth
or nip it to the shop and moan at them
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 16:20 - 29 Jan 2009 Post subject: |
I've seen pads with sticky pads on the back to deliberately stick them to the pistons, before now, although not on any recent bikes.
I'd do as zzr reckons, drop the calipers off, wedge something between the pads and gently squeeze the brake lever, should break the seal nicely. Are the pistons rusting or is it some alloy corrosion? I wouldn't expect a relatively new bike to have that sort of issue yet.
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| Slinn84 |
The last post was made 17 years, 276 days ago. Instead of replying here, would creating a new thread be more useful? |
