| suzuki rider |
 suzuki rider Borekit Bruiser
| Itchy |
 Itchy Super Spammer
 Posted: 21:04 - 29 Jan 2009 Post subject: |
You can pump them out a bit say 3/4 of the way out and clean the pistons if you want, as long as it is cleaned properly, you don't need to pop the pistons out, but I recomend it.
Not popping them however means that you don't have to bleed your brakes,
However you can't change or clean the seals up or the cylinder of the caliper up which may harbour some crud.
Brake fluid , brake cleaner whatever , I actually put the pistons under the tap , scrub them off and pick off any crud using a plastic ruler as it won't damage the steel piston. Dry them up with bog roll and bog roll on the seals that you take out, spray some cleaner on. Pop them back in.
Sickpup has a trick here though to minimise bleeding , put the seals back in , clean the pistons up and the body,
Now how the caliper in the palm of your hand holes facing up , put some brake fluid in about 75% up the barrel on each pot then pop the pistons back in forcing them about 80% the way in with your thumbs...
This allieviates a great deal of bleeding... not that bleeding is difficult as you need a piece of hose that goes to your bleed nipple an 8 spanner and some string if you do not have a mate to help out , you also need a glass or something brake fluid safe.
Its as simple as , pump brake lever, tie with string , undo bleed nipple (with the tube on the end in a glass of brake fluid) , do up nipple, undo brake lever, repeat until the brakes firm up , you can usually hear some creaking as the fluid forces the pistons back out again.....
Thats IF your bike has sliding calipers though. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| suzuki rider |
| lonner |
 lonner Spanner Monkey
 Posted: 23:43 - 29 Jan 2009 Post subject: |
if you are going to re-use the seals make sure you install them the correct way round as they have a leading edge and that goes to the inside.
So raised edge facing in.
you should fit new really  |
| suzuki rider |
| Shay HTFC |
 Shay HTFC World Chat Champion
| Davie_G71 |
 Davie_G71 World Chat Champion
| suzuki rider |
| lonner |
 Posted: 15:30 - 30 Jan 2009 Post subject: |
a good tip for bleeding brakes is when you start the process .
ring spanner on the bleed nipple pipe to container.
all movements with the leaver should be done slowly (2 seconds to pull leaver to bar and same speed letting out)
then 1/2 turn on the bleed nipple as you pull leaver.
hold leaver to the bar nip up the bleed nipple.
repeat this until you see the air is about gone odd tiny bubbles.
if you now have a spongy leaver or reasonably solid feel the best thing to do is apply pressure to the leaver then tie it to the handle bar so the brake is applied and leave it for a few hrs or over knight is best.
this works and will usually solve the spongy brake issue.
this task is a lot easier if you get a one way bleed kit or a syringe for drawing the fluid through as it will free your hands up.
but the most important bit is always nip up the bleed nipple with the leaver pulled up fully to the bar and take your time .
doing it up with it in the out position just draws air back in and hence the feeling its a impossible task.
as with any brake work keep everything spotless and use new brake fluid  |
| Howling TerrorOutOfOffice |
| suzuki rider |
| lonner |
 Posted: 19:24 - 30 Jan 2009 Post subject: |
good lad your doing things the right way for a novice (preparation)
copper grease is a good thing on all the exposed parts as it prevents corrosion
will keep up with your progress and help where poss if needed  |
| Itchy |
 Itchy Super Spammer
 Posted: 19:28 - 30 Jan 2009 Post subject: |
No no no ! , copper grease is only ok for the back of brake pads and then only a smidge as it is highly abbrasive.
What you want is red rubber grease (a tub will last years if not decades) to put around the pistons. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| lonner |
 Posted: 20:04 - 30 Jan 2009 Post subject: |
copper grease is a anti seizing compound and has a very high melting point.
it is used for threads as a anti seizing agent
works well on the rear of brake pads to reduce squealing.
and is great for use on exposed threads as gives good protection
try here for relevant uses
https://www.mandp.co.uk/productinfo/526842/Lubricants/Lubes-other/Granville |
| suzuki rider |
| Itchy |
 Itchy Super Spammer
| lonner |
 Posted: 21:03 - 30 Jan 2009 Post subject: |
I'm of the opinion that hydraulic seals need to be replaced as they should not be exposed to detergents and the likes.
and as this is a learning curve for you new seals will be the right way to go as bodging on brakes is fookin dangerous and i would rather you did it correctly for this reason and also you are removing the chance of a seal failing and then having to do it all again.
when you go to the shop ask if the mechanic can show you or give you a heads up and a few tips as seeing is the best way.
| suzuki rider |
| djr |
 djr World Chat Champion
| sickpup |
 sickpup Old Timer
 Posted: 00:34 - 02 Feb 2009 Post subject: |
| Itchy wrote: | Sickpup has a trick here though to minimise bleeding , put the seals back in , clean the pistons up and the body,
This allieviates a great deal of bleeding... not that bleeding is difficult as you need a piece of hose that goes to your bleed nipple an 8 spanner and some string if you do not have a mate to help out , you also need a glass or something brake fluid safe. |
Slight correction to the order of things.
Reassemble calipers but only push pistons 80% or so in.
Pour some brake fluid into the caliper, not much and it settle to the bottom of the caliper.
Bolt caliper to fork leg and top up with brake fluid.
Bolt brake line back on.
If twin front caliper do the same on the other side.
Now you only have to bleed the lines NOT the caliper as well.
| zzr lon wrote: | if you are going to re-use the seals make sure you install them the correct way round as they have a leading edge and that goes to the inside.
No they don't or at least Japanese calipers don't and neither do the Brembo's I've worked on. |
| lonner |
| suzuki rider |
| Davie_G71 |
 Posted: 15:59 - 02 Feb 2009 Post subject: |
Not always
check out www.wemoto.com for parts. ____________________ Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003. |
| suzuki rider |
The last post was made 17 years, 66 days ago. Instead of replying here, would creating a new thread be more useful? |
