| paul651975 |
 paul651975 Two Stroke Sniffer
| salty21 |
 salty21 World Chat Champion
 Posted: 17:57 - 28 Jan 2009 Post subject: |
does it also get louder and more throaty? then picks up dramatically at 6,500-7,000rpm ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
94 CB400 Super Four ---- 2000 VTR SP1 (sold) ---- 08 ninja p8f(sold, meh) ----05 CBR600rr  |
| alains |
 alains World Chat Champion
| paul651975 |
| dougon2wheels |
 dougon2wheels Nitrous Nuisance
| paul651975 |
| salty21 |
 Posted: 22:07 - 28 Jan 2009 Post subject: |
im pretty sure its the powervalve being open, hold the revs at the point where it loses power(or around there if you cant hold it steady) then key off at those revs and check the position of the powervalve, it should be on low still. ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
| joop200789 |
 joop200789 Renault 5 Driver
| paul651975 |
| paul651975 |
| salty21 |
 Posted: 12:51 - 31 Jan 2009 Post subject: |
its the barrel side that needs to line up correctly, the servo side just gives a rough idea, but if its not moving fully in each direction it would suggest the valves in the exhaust port have coked up or you have the wrong p/v control unit. ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
| paul651975 |
| paul651975 |
| salty21 |
 Posted: 14:17 - 31 Jan 2009 Post subject: |
weird are you sure its a tv-78 as the restricted unit only opens the valves to about 70% which would fit your problem perfectly.
only other thing i can think of is the red/white wire from the cdi, which tells the r/c control unit what rpm the engine is at which in turn opens the valve accordingly, so would be worth checking the connections on that wire, also do you have an orange/white wire on your cdi box that has 2 connectors and and goes round in a loop back into the cdi? ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
| paul651975 |
| salty21 |
 Posted: 14:37 - 31 Jan 2009 Post subject: |
yep the ci626 should smoothen out the revs too and give more power, will probably sort out the powervalve openings aswell, but dont hold me to that.
for the mean time, depending how you ride you can set the valves to be on hi or low, say if its dual carriage ways probably best on hi, if its town or city riding keep it on low.
make sure when you get the cdi it's a ci626 and not a ci626a as this one tops out at 10,500rpm and the normal ci626 tops out at around 11,500rpm which is well into the redline  ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
| paul651975 |
| salty21 |
 Posted: 15:00 - 31 Jan 2009 Post subject: |
| robbo68 |
 robbo68 Borekit Bruiser
| alains |
 Posted: 16:37 - 01 Feb 2009 Post subject: |
exactly  ____________________ the worst day fishing is better than the best day working |
| paul651975 |
| alains |
| paul651975 |
| robbo68 |
| alains |
The last post was made 17 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
