Hornet 600 overheating:
deanoet
PostPosted: 16:17 - 31 Jan 2009    Post subject: Hornet 600 overheating: Reply with quote
Checked the coolant levels, they are fine
I am thinking it is maybe an air lock in the system? But how can i dislodge it?
Bikeless
PostPosted: 16:31 - 31 Jan 2009    Post subject: Reply with quote
Check you expansion tank bottle and make sure the rad is filled to the top.Next i would check the thermostat and water pump also your fan switch.
deanoet
PostPosted: 16:44 - 31 Jan 2009    Post subject: Reply with quote
the fan isnt cutting in
How do i check waterpump and thermostat?
deanoet
PostPosted: 17:36 - 31 Jan 2009    Post subject: Reply with quote
Check radiator hose is attached properly before posting that your bike is over heating...
Radiator is now full...
Levels are normal
I`ll get my coat.
Good example of checking the obvious first Embarassed
Fan wasnt cutting in though, so will look into that... Smile
Bikeless
PostPosted: 18:09 - 31 Jan 2009    Post subject: Reply with quote
Fan switch on rad,mine is sometimes a little late kicking in when i'm in traffic on very hot days.I just wired a manual switch to it aswell so i can whack it on myself.
deanoet
PostPosted: 19:06 - 31 Jan 2009    Post subject: Reply with quote
it says in the haynes that if the radiator fan doesnt kick in check the coolant levels
The fan itself is connected to a white plug (i assume heat sensor) on the radiator. So if there is no water in it, it wont trigger and switch it on. Smile
Will see how it goes. Smile
PostPosted: 19:19 - 31 Jan 2009    Post subject: Reply with quote
Are there any bits of gravel stuck in the fan. On the hornet it's not unheard off for gravel and stones to get stuck in the fan preventing it from coming on. Thumbs Up
Stelmer
PostPosted: 21:49 - 31 Jan 2009    Post subject: Reply with quote
You could check the fan by shorting the connectors in the switch plug.
But yeah, air locks and the like will make it come on late or not at all.
The last post was made 17 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 54.75 Kb
