zzr 600
chris924
PostPosted: 21:34 - 30 Jan 2009    Post subject: zzr 600 Reply with quote
i was doing about 80 on motorway when i went 2 wind it up more it would not do out for about 3sec then kick in can you help it runs well low speeds
calum17
PostPosted: 21:47 - 31 Jan 2009    Post subject: Reply with quote
dont hold me on this one, but it sounds like the carbs may need balancing. i asked a friend (who's a mechanic ) about it before when my E1 model did a similar thing .. mine was ok but deffainatley not 100 %. if you get the kit you might be able to do it yourself, and whilst in the process it might be worth putting in new spark plugs and checking your air filter ... all of which can affect the bike - and if things aren't right at higher speeds you'll notice them more (such as winding on at 80 mph)
might be worth asking your local garage to balance the carbs for you if you dont think you're able. - may also be other factors which would give you the problem though.
Finglonga
PostPosted: 21:58 - 31 Jan 2009    Post subject: Re: zzr 600 Reply with quote
Can anyone . . https://img.photobucket.com/albums/v112/finglonga/Finglonga%20Inc/trans.gif
Andy Sez....
F.Y.Y.F.F.
calum17
PostPosted: 22:01 - 31 Jan 2009    Post subject: Re: zzr 600 Reply with quote
'I was doing about 80mph on the motorway, when I tried to accelerate, but it would not do so for about 3 seconds. Then the power kicked in and was ok. It runs fine a low speeds though. Does anyone know what my problem could be and have advice for me please?'
good enough?
Finglonga
PostPosted: 13:56 - 01 Feb 2009    Post subject: Re: zzr 600 Reply with quote
good enough?
Much better than the OP, sounds like fuel starvation or a flat spot, as you said replace spark plugs/check filter see how it is then then balance the carbs go from there.
Andy Sez....
F.Y.Y.F.F.
chris924
PostPosted: 14:08 - 01 Feb 2009    Post subject: Re: zzr 600 Reply with quote
thks for the help
Finglonga wrote:
good enough?
calum17
PostPosted: 14:27 - 01 Feb 2009    Post subject: Reply with quote
just had another thought, and from the info about the exhaust in the email... could be that the carbs weren't set up properly when the exhaust was fitted. might be worth getting someone to dyno it to check,. but a general service and the carbs checked should see the bike running better
chris924
PostPosted: 14:33 - 01 Feb 2009    Post subject: Reply with quote
tks for got about thinking about that only had bike 1 month
The last post was made 17 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 57.42 Kb
