Looking at picking up a Honda SP1 *pic added*
Seb
PostPosted: 22:13 - 31 Jan 2009    Post subject: Looking at picking up a Honda SP1 *pic added* Reply with quote
Weather allowing, I should be checking out an SP1 next week, but I'm not really sure what I should be looking out for besides the usual corrosion. Did they have any faults that I should be wary of?
Cheers in advance Thumbs Up
2010 Triumph 1050 Sprint ST
PostPosted: 22:18 - 31 Jan 2009    Post subject: Reply with quote
Check the side mounted rads for drops. They get damaged quite easily if it goes over.
Check if it's an ex racer as well. Drilled sump plug, chipped rims, tired chassis on mint plastics.
A PCIII is an ideal mod as the standard fuelling is crap.
Does he keep it on an optimate, as it's a big twin they put quite a bit of strain on the starter system.
If it has carbon fibre exhaust cans they can be damaged by the engine's power pulses IIRC, and when were the exhausts last re-packed. The SP1 is pretty hard on them.
The whirring is the gear driven cams so is nothing to worry about.
HTH
Seb
PostPosted: 22:41 - 31 Jan 2009    Post subject: Reply with quote
The original owner did quite a lot of miles on it and threw silly amounts of money at the thing, but the signs I've seen of it from my first quick glance over made me think it was more for pose value than track performance.
The radiator's looked mint when I had a glance over it a couple of weeks back, but I'll give them a close inspection when I pop over again, cheers for the heads up on the sump plug too, thats not something I'd have thought of at all Thumbs Up
I'm looking forward to putting my money down and getting whoring with the photos, it's smutty beyond belief Smile
Seb
PostPosted: 23:16 - 02 Feb 2009    Post subject: Reply with quote
Rode it today (and yes, got caught in the snow too), not as bonkers as I was expecting it to be. The fueling had it's moments, it likes to bog down and then surge a bit at low speeds, but I'm used to working the clutch with the Aprilia so it's not too big a deal.
Biggest problem right off the bat is the noise, it's abusively loud, I filled it up right next to a police car in Morrisons on the way out and I'm honestly surprised I didn't get tugged right there and then. Putting stock cans back on it would be an injustice, but it desperately needs a set of baffles to make it a bit more considerate. Any ideas what should I be expecting to pay to get a set made and fitted?
The tyres on it (Bridgestone 012 front and back) also need to go sharpish, the front end didn't give me any grief, but the back end seemed to take a lifetime to get some heat going and actually start gripping. I don't suppose any of you have first hand experience of sports touring tyres (BT-021s or Roadsmarts preferably) on an SP1/2? BT-016s would be the logical choice but I suspect I'd square them off too fast.
Beyond that, I'm as good as sold on it I think, as impractical as it is, it's just too stunning to pass over Thumbs Up
PostPosted: 09:23 - 03 Feb 2009    Post subject: Reply with quote
For baffles unless the cans are a strange bore(I don't think they are) then you should be able to buy some generic baffles or DB killers over the counter then just drill the outlet of your can to hold them in place. Usually they are £10-£20 per can.
I don't have experience of sports touring tyres on the SP2, but from the mille I'd say avoid Conti Road Attacks, and BT-014's since they square off too quickly. Most people tended to rate standard diablos or Corsa III/ 2CT's. Thumbs Up
If you're interested BSD in Peterboro can get a reliable 140ish bhp out of SP1's. Go any higher than that and you'll start hitting problems with the clutch, gearbox and crank. Thumbs Up
Seb
PostPosted: 13:35 - 03 Feb 2009    Post subject: Reply with quote
Moneys down, let the whoring commence....
It's been fully blueprinted and has a power commander fitted (annoyingly looks like a PCII though), it needs a few little things done but beyond that, it's pretty much got everything short of a turbo on it already Thumbs Up
AppleJoe
PostPosted: 13:45 - 03 Feb 2009    Post subject: Reply with quote
That looks really nice. How much did it set you back?
Also, has it been resprayed? As far as I know it was the SP2 that came in the Castrol scheme.
Full licence from 16/4/08 Smile
Previously: '56 YBR125 - Current: K1 SV650S
tafflade
PostPosted: 13:50 - 03 Feb 2009    Post subject: Reply with quote
I agree, it look stunning, I thought the castrol reps were SP2's though.
you say its got a few mods, what's the spec?
Graprilia
PostPosted: 13:53 - 03 Feb 2009    Post subject: Reply with quote
Well nice bike Thumbs Up
Piaggo liberty 125 SOLD - CBR 125 - SOLD Aprilia RS 125 - SOLD CBR 400 NC29 - SOLD ZX6R currently own https://bikepics.com/members/Graprilia/
Steve-D
PostPosted: 14:10 - 03 Feb 2009    Post subject: Reply with quote
Is that from PGH in Torquay?
My mate was going to buy it but they told him it was sold.
Looks even better in the flesh have fun.
www.southwestbikers.com
Seb
PostPosted: 14:15 - 03 Feb 2009    Post subject: Reply with quote
Not gone through all the receipts for it yet, but what I know at the moment:
PCII + blueprinted.
Harris high level carbon system.
Harris adjustable rearsets
Ohlins damper
Ohlins fork internals
Ohlins rear shock (Looks like a 46PRLS)
It's a 2000 V plate, but bar a few small blemishes on the paint work it's in incredible condition given the age, cosmetically the only issues I have with it are the polished swingarm (just why) and a small split starting above the center screw on the front nose cone that'll want sorting sooner rather than later.
It went for £3795, bit steep for the age, but its worth it Smile
sagalout
PostPosted: 14:19 - 03 Feb 2009    Post subject: Reply with quote
Looks stunning - I'd love to own one of these but couldnt afford the chiropractor to go with it!
Current Bike: Triumph Speed Triple T309
Previous: CBR600F => ZX9R => Triumph Tiger => Honda Blackbird => GSXR 750 => Versys =>ZX12R
Seb
Yeah, thats the one. he wouldn't happen to be the van driver I was talking to at Morrisons yesterday? Thank him if it was, I reckon I'd have gotten grief from the police right there if he wasn't talking to me at the time Very Happy
Faldo
PostPosted: 14:27 - 03 Feb 2009    Post subject: Reply with quote
Looks very smart dude, I bet it sounds even better though. An SP1 would be in my dream sportsbike garage. Thumbs Up
Let's hope the weather clears up so you can get your moneys worth out of it.
Current: ZZR1400
AppleJoe
PostPosted: 14:35 - 03 Feb 2009    Post subject: Reply with quote
PCII + blueprinted.
Ohlins damper
As you say, it's pretty steep for a V plate, but you're getting a lot of bike for your money. If it's definately from 2000 then it's had what looks like a very professionally done respray too Thumbs Up
Seb
PostPosted: 14:47 - 03 Feb 2009    Post subject: Reply with quote
Yeah, the paint was done by BBW race paint and looks absolutely stunning. The right side tail numberboard has a little blemish but beyond that its mint.
rac3r
PostPosted: 15:49 - 03 Feb 2009    Post subject: Reply with quote
Awesome! Thumbs Up Drooling
Just shows how a paint job can make a big difference
Chequered Flag
AppleJoe
PostPosted: 17:39 - 03 Feb 2009    Post subject: Reply with quote
Have you got a reciept for the paint job? Just wondering how much something like that would cost - I'd imagine a fair bit...
Mr Nice Guy
PostPosted: 17:44 - 03 Feb 2009    Post subject: Reply with quote
I think the SP2 swingarm will bolt onto these (IIRC)...
Suzuki GSX-R750K4 ~ Mivv GP
Charlie
PostPosted: 19:20 - 03 Feb 2009    Post subject: Reply with quote
I was going to say, that looks sexy as but the swingarm lets it down. Powered coated black would be good.
Looks very nice... a bike for me in the future maybe Cool
Tristan.
PostPosted: 21:18 - 03 Feb 2009    Post subject: Reply with quote
Thats lovely, lucky bastard.
Chap on my course said he got a swingarm powder coated for 100 quid, including removing and fitting to the bike, seems a bit too good to be true, possibly mates rates. Anyway might be worth a try, want me to get the details?
Seb
PostPosted: 21:21 - 03 Feb 2009    Post subject: Reply with quote
God yes, thats an absolute steal at that price Thumbs Up
CRF_Rider
PostPosted: 03:03 - 04 Feb 2009    Post subject: Reply with quote
you are the envy of many a rider now myself included.
prepare for the 'i would buy you a coffee but seeing as you have that you can buy it yourself' stuff.
an as for the cans:
well loud pipes save lives live with it and grin like a loon Very Happy
Why is it everything i race, seems to be going backwards?
Current: Honda CRF 450 R Supermotard
Previous: Yam TY250 x2, Gas Gas TXT 200, Sherco 290, Suzuki TS 50,Honda CG 125, Yam SR250, Suzuki DR-Z400E, Yamaha YZF R6 112rwbhp
PostPosted: 03:27 - 04 Feb 2009    Post subject: Reply with quote
I guy I new had twin harris high levels on an SV650. That sounded like the world was ending every time he started it, that SP1 will be evil.
The last post was made 17 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 133.74 Kb
