it think my engines seized!
veze
PostPosted: 14:32 - 01 Feb 2009    Post subject: it think my engines seized! Reply with quote
i was riding my gs 500 yesterday, when i was waiting at the lights it cut out. i tried to start it but the starter motor got slower and slower, i know i had charging problems, but i think that is due to a corroded connection on the starter solenoid.
as i was trying to bump the bike, the wheel was locking up in every gear. so i pushed it home which took 2 hours!
today i pooped it on the centerstand, put it in 2nd, 3rd, 4th, 5th and 6th and have tried to spins the back wheel by hand.
it will move when it takes the slack off the chain, but then wont budge, even in 6th. so u think the engine has seized?
cheers,
josh
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
Itchy
PostPosted: 14:40 - 01 Feb 2009    Post subject: Reply with quote
Take the spark plugs out then try it again turning the wheel by hand , without the spark plugs you won't have any compression and thus the pistons should move up and down somewhat easier than normal when the rear wheel is turned by hand.
If they don't then your engine might be seized.
PostPosted: 14:42 - 01 Feb 2009    Post subject: Reply with quote
Sounds to me like the battery is flat.
Charge the battery and give it a whirl.
I think you are pushing your luck trying to turn over a 500 twin by pulling ther rear wheel round, even in top. Or you could try doing it with the sparkplugs out.
If you wanted to check if the engine turns, you'd be better getting a socket on the end of the crank and trying to turn it by hand. Unfortunately from what I can see on pictures, a GS500 doesn't have an inspection cover allowing you to do this without removing the crankcase covers.
In general, if a big 4-stroke like that has seized, it is going to need a wholesale replacement of parts anyway. Giving it a try with a fully charged battery is unlikely to make things very much worse.
Ichy
PostPosted: 14:43 - 01 Feb 2009    Post subject: Reply with quote
Try the same with the spark plug taken out.
Take the bike out of gear. Take off the side cover to give access to the nut on the end of the crank, the one used to adjust the valves. Try turning the engine over by hand.
veze
PostPosted: 14:50 - 01 Feb 2009    Post subject: Reply with quote
yeah taking the plugs out was the first thing i did and it dnt budge.
as for the battery issue, its a brand new batt andi charged it last nite. the starter motor would engage so i took it off the engine then tried it, and nothing. so i looked at my starter solenoid, it looks like one of the connections is slightly corroded. mybe this is creating o short and draining my batt?
veze
PostPosted: 14:56 - 01 Feb 2009    Post subject: Reply with quote
im having trouble getting the flywheel cover off aswell, ive undon all the bolts but the casing qwont budge, i dont want to his it with anything because i dont want to damage it
Ichy
PostPosted: 15:02 - 01 Feb 2009    Post subject: Reply with quote
Can't say for definate on your bike but many have a dowel to locate the cover.
I usually just gently tap all around the cover with a soft mallet to release it.
Hit it with a rubber mallet or put a piece of soft wood on it and hit it with a hammer.
You need to break the gasket seal.
Finglonga
PostPosted: 15:04 - 01 Feb 2009    Post subject: Reply with quote
Place a piece of wood on it and give the wood a tap and it should shock it free, Make sure you have taken all the bolts holding it on first though.
Andy Sez....
F.Y.Y.F.F.
veze
PostPosted: 15:07 - 01 Feb 2009    Post subject: Reply with quote
cheers guys, well i will try that, and if the engine turns over, that would be ace, then all i would need to do is hopefully clean up the connections on that starter solenoid, i will jump on it now before it gets dark. cheers
veze
PostPosted: 16:28 - 01 Feb 2009    Post subject: Reply with quote
just tried to turn the engine over on ther rotor on the right hand side of the engine and it made a crunching noise and wouldnt turn, i think i may have slightly broken it. haha.
probably on con rod or sumut has snapped. there is oil in the engine so i dont think that would have been the problem. ah well. looks like im gunna have to cath a bus and a train to work. pants.
PostPosted: 16:41 - 01 Feb 2009    Post subject: Reply with quote
Before you write the engine off altogether, make sure it isn't the starter clutch/starter motor having self-destructed.
I don't know your bike but I'd imagine you could remove at least the motor fairly easily.
Failing that, don't forget to post pics when you perform the post-mortem. It takes a fair bit of doing to blow up a GS500 motor so I'm expecting something pretty spectacular. See if you've beaten my girlfriends record of putting a 270 degree bend in a conrod.
veze
PostPosted: 16:50 - 01 Feb 2009    Post subject: Reply with quote
haha thats awesome.
ive already taken the starter motor off, but th engine ant budging. i have achieved the unacheivable!!!!!! this should go in the bcf history books!
SoND
PostPosted: 18:12 - 01 Feb 2009    Post subject: Reply with quote
Eh?
Pics or it didn't happen.
PostPosted: 18:22 - 01 Feb 2009    Post subject: Reply with quote
I've blown up a GS500, Haven't taken it apart yet mind. I will do one day.
PostPosted: 20:01 - 01 Feb 2009    Post subject: Reply with quote
SoND wrote:
Eh?
https://i48.photobucket.com/albums/f216/stinkwheel/305/Image079.jpg
SoND
PostPosted: 20:13 - 01 Feb 2009    Post subject: Reply with quote
What happened there?
PostPosted: 20:20 - 01 Feb 2009    Post subject: Reply with quote
It's a GPz305. They do stuff like that all the time.
veze
PostPosted: 23:06 - 01 Feb 2009    Post subject: Reply with quote
thats nice, thats nice.
jut made a few phone calls.
one lads got a xj400 i could have for 200 quid, just need the back brake sorting.
and another chap has offerd me a near mint 1979 gs 750 for £500 which has had a complete rebuild, just need to put the light and indicators on it? which should i go for? hmmmmm
NiteMare
PostPosted: 23:37 - 01 Feb 2009    Post subject: Reply with quote
i've no idea of the XJ400 but would expect it to be a revvy little thing...
but for 500 i'd seriously consider the GS750 if i was needing another bike
it ain't broke...
i ain't fixed it enough
Lukaz2205
PostPosted: 00:49 - 02 Feb 2009    Post subject: Reply with quote
i hate to mention this but if you aint running fast enough tryin to bump the bike it will lock the rear if your in gear when you bang the clutch out i allways leave it in second, and jump on the back seat an hold the bars so my weight pushes the rear tyre into the floor.
was harder for me in the snow and ice mind.....
1st....2nd....3rd....4th.....into 5th......6th field and stopped in a heap!
PostPosted: 07:57 - 02 Feb 2009    Post subject: Reply with quote
Drain the oil and see if there are any bits in it.
£500 for a near-mint GS750 is a total bargain. Buy it, sell it for profit, get a modern bike.
PostPosted: 12:22 - 02 Feb 2009    Post subject: Reply with quote
Maybe you should read the whole of the thread before posting Rolling Eyes
veze
PostPosted: 20:01 - 02 Feb 2009    Post subject: Reply with quote
i mite not get the gs, but my i duno, i think it cud go to a better home than me, cuz i ride through the winter it will get all shit up, and that would be a dam shame. i think id mite get the little xj and potter round on that while i save up cash and get me newer bike for summer, sensible option? oh and yeah ther is, i seen bits of swarf in the oil when i took my starter motor out.
The last post was made 17 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 129.15 Kb
