| gwernybwch |
 gwernybwch Nova Slayer
| frazer1981 |
 frazer1981 Nitrous Nuisance
 Posted: 12:43 - 18 Jan 2009 Post subject: |
When i replaced my cltuch plates on my mtx i had a similar problem.
What is was, was the little tooth'd thing that had fell out when i took the clucth cover off. You have to make sure it is lined up properly other wise you cannot select gears. Took me ages to get it right including having to take it all apart again as i could not change up gears but down was ok.
https://i154.photobucket.com/albums/s241/VR_XRAY/Picture001-1.jpg
https://i154.photobucket.com/albums/s241/VR_XRAY/Picture002-1.jpg
top picture shows the shaft and the teeth that need lining up correctly.
2nd picture shows the tooth'd gear that was the main cause of my problem's.
I am sure somebody will be here with the correct names and stuff but from my past experance with this i think you should check this out??? ____________________ 1st bike - chunlan starway 50QF4 (SOLD) 2nd bike - 92 Honda mtx125RW-L ( In my garage awaiting some TLC)
05 Honda xl125v Varadero stolen and recovered but now a write off!
07 Hyosung GTR125R |
| gwernybwch |
| frazer1981 |
 Posted: 21:21 - 18 Jan 2009 Post subject: |
Yeah could only get 1st and no higer though the box than neutral, that was even with the bike running or not running. May be your problem but as you may or not know 2nd gear on the mtx was not the best and even an older field bike version i had @ 15 had 2nd gear replaced twice in the 8 months i had it. ____________________ 1st bike - chunlan starway 50QF4 (SOLD) 2nd bike - 92 Honda mtx125RW-L ( In my garage awaiting some TLC)
| gwernybwch |
 Posted: 22:15 - 01 Feb 2009 Post subject: |
I’ve made sure that the ‘reduction gear’ is correctly aligned and still have the same problem
I think that it selects fine when the engine isn’t running and when cold, but jumps out after a couple of minutes must be the key to be problem.
Anyone else want to hazard a guess as to what might be wrong with it?
All suggestions gratefully received. |
| sumpgard |
 sumpgard Nova Slayer
| Jello |
 Jello Nova Slayer
| gwernybwch |
The last post was made 17 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
