fixing guitars
chillpill
PostPosted: 23:50 - 01 Feb 2009    Post subject: fixing guitars Reply with quote
my guitar snapped on the fretboard up near the headstock in sort of a diagonal snap, can anyone recomend something to stick it back together with ? will a hot glue gun do the trick ?
PostPosted: 23:55 - 01 Feb 2009    Post subject: Reply with quote
Hi, tried a similar repair myself, didn't last long and used proper wood glue.
If it's a cheap guitar then give it a go, if it's your fav or expensive then get it repaired by a luthier.
Good luck
Pat
KLR600
PostPosted: 01:08 - 02 Feb 2009    Post subject: Reply with quote
I'd suggest a new neck to be honest.
The amount of tension/strain the strings put the neck under is something like 90kgs when tuned to pitch depending on what strings you use so I doubt any repair would last that long really.
<Take Cool Photos!>
bazza
PostPosted: 08:47 - 02 Feb 2009    Post subject: Reply with quote
When no wood is lost, no one plays with the break, the wood has not been crushed or compressed and the crack has not been previously repaired, this kind of break can often be successfully repaired by gluing and clamping. Aliphatic glue is very strong is often my glue of choice as it does not harm the finish and will minimize touch up. Hide glue is also an option but I find epoxy to be too thick for a tight fitting crack and it can obviously damage the finish.
There are many factors that will determine how much effort is needed to repair a broken peghead. Longer cracks running sort of parallel with the neck offer us a greater gluing surface and are usually a common candidate for a "glue and clamp" repair. But short choppy breaks, as if someone had sawed right thru the neck at the nut have little chance of simply being glued and clamped.
https://www.fretnotguitarrepair.com/neck_repair_broken.htm
chillpill
PostPosted: 17:28 - 02 Feb 2009    Post subject: Reply with quote
cheers , yeah its only a crappy practice one , ill try and repiar it with some glue Thumbs Up
chrisjacks
PostPosted: 18:34 - 02 Feb 2009    Post subject: Reply with quote
i have 2 guitars a gibson les paul and a crappy fender thing luckily this happened to my fender, so i got a drill a put it isnt a jig i made at college for this actual job and drilled two wholes 100mm deep in both parts, then got two 200mm rods and forced them into the wholes with metal/wood glue so that worked alright.
but becuase i knew it wouldnt hold it i removed all the frets and filled them in (went fretless) then got some thin aluminium and wrapped it round the entire back of the fretboard and glued that in place.
is not broken yet =]
bazza
PostPosted: 21:27 - 02 Feb 2009    Post subject: Reply with quote
https://www.deluxematerials.co.uk/pages/emulsionglues.htm
chillpill
PostPosted: 23:23 - 04 Feb 2009    Post subject: Reply with quote
well i stuck it back together witha glue gun , only problem was the glue raised the fretboard so the strings got fouled on the board and fucked the sound right up
then i smashed it because it pissed me off and i couldnt unstick the glue Laughing
bazza
PostPosted: 22:55 - 05 Feb 2009    Post subject: Reply with quote
Well done.
I'm so glad I took the time to actually look up the exact information for you to ignore. I can only imagine how awful it would have been for you if you'd totally ignored the wrong advice...
The last post was made 17 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 61.15 Kb
