| 4Stroke |
 4Stroke Scooby Slapper
| 4Stroke |
| 4Stroke |
| DaveH |
 DaveH World Chat Champion
 Posted: 18:44 - 01 Feb 2009 Post subject: |
Also might be worth making sure that all the earth points are clean and tight. ____________________ https://www.timhastingsracing.co.uk/
ZX7R & ER6F |
| thefallenange... |
 thefallenange... Crazy Courier
 Posted: 21:33 - 02 Feb 2009 Post subject: |
not a reg/rec is it? Causing crazy electrical faults?
Rev up to 5k and put a meter across the output to the battery to check. Also check the battery voltage when revving incase it's goosed the battery too but i doubt it. ____________________ Past - CG125 ,KR1S, SV650s, Street Triple R - Current - Duke 390
r.bridge1988@gmail.com |
| 4Stroke |
| thefallenange... |
| 4Stroke |
| 4Stroke |
| Bikeless |
 Bikeless World Chat Champion
| 4Stroke |
| 4Stroke |
 Posted: 08:55 - 05 Feb 2009 Post subject: |
Right last night I spent from 8 till 12 on it.
I checked the plugs and revved it an the spark timing seemed to increase dramatically with the engine revs.
The spark also seemed to remain 'in time' with the engine note if that makes sense.
I checked out the fuel pump and fuel pump relay, pump seems to be working ok, tried another rely.
Found a load of wires and block connectors under the airbox near the startor and engine earth my haynes doesn't seem to mention, some of which were corroded so sorted them out.
Yet it's still exactly the same...  |
| DaveH |
 Posted: 09:43 - 05 Feb 2009 Post subject: |
Were the earths on battery, frame and engine all clean and tight - no dodgy looking wires? ____________________ https://www.timhastingsracing.co.uk/
ZX7R & ER6F |
| 4Stroke |
| 4Stroke |
 Posted: 13:51 - 05 Feb 2009 Post subject: |
Is anyone in the devon/somerset area who could meet up to perhaps shed some light on this?
Maybe an outside opinion could work wonders very least I may be missing something but being too invovled.
Crate of bear? bottle of wine?
Just be grateful for a second opinion.
If not I'm going to see if I can live with it till next month then take it to someone once I have a little more cash.
| 4Stroke |
 Posted: 20:44 - 09 Feb 2009 Post subject: |
Ok guys, a hopefully final update on this.
If we look back about when I first posted an issue with this the problem was misfiring and stuttering and reall running issues when it was wet and damp out.
As progress went on and I started delving deeper and swapping bits out and refurbing bits the problem kind of morphed into the OP above.
A final update... The initial issue of nasty running problems in the wet seems to have been solved, hell I rode it in todays downpour 25 miles and it didn't miss a beat.
Secondly the problem posted above was likely my own fault as I rebuilt the carbs in a vain attempt to eliminate them from the equation I didn't do two of the main jets back up (as I rejetted back to factory) so as a result of pulling the carbs again today I found two main jets rolling around the float bowls.
Screwed them back in the emulsion tubes and she's running great through-out.
Also I have hopefully eliminated the original issue as I have pretty much swapped out everything electrical and as I said earlier rode today in the down pour and was magic.
Big thanks to all who helped and the patience you guys had with me also.
| DaveH |
The last post was made 17 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
