vt250 help
hmmmnz
PostPosted: 11:54 - 04 Feb 2009    Post subject: vt250 help Reply with quote
well i have aquired a vt250 (free) with a couple of spare engines and a big box of spares,
i am currently trying to get it running, and you'd think being as simple a engine as it is it shouldnt be a problem
but all i have managed is a huge fireball from the carb (ether induced Embarassed ) and a rather large back fire,
i have a decent spark on both cylinders (new plugs)
i have decent compression on both cylinders
the timing is set correctly on both and i did the valve clearances
i have cleaned out both carbs..
it should run right???
well tell that to the bloody bike Very Happy
any ideas helpful,
here are some pics of the state of it. bear in mind its an 86 bike
and hasnt been running in 3 years
as it turned up to my house
https://i58.photobucket.com/albums/g257/hmmmnz/1986VT250FG.jpg
checking the timing
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1933Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1934Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1936Small.jpg
as she is at the moment
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1931Small.jpg
the spares
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1929Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1930Small.jpg
um well yeah Very Happy
the humans are dead
I kick arse for the lord
PostPosted: 12:43 - 04 Feb 2009    Post subject: Reply with quote
What the heck is going on with that front brake? Shocked
NSR Mick
PostPosted: 12:46 - 04 Feb 2009    Post subject: Reply with quote
Inboard disc. They overheat for fun and arent particularly good.
Paddy Blake
PostPosted: 23:00 - 04 Feb 2009    Post subject: Reply with quote
Did you take the air filter out.It is likely to be knackered from damp.
Oh and curse at it.Maybe kick it. Thumbs Up
Paddy.
virus
PostPosted: 23:31 - 04 Feb 2009    Post subject: Reply with quote
Ive got no experience of the VTs, but make sure the airbox is connected properly, i know a few bikes that refuse to cough without an airbox but burst into life on the button with it fitted.
oh and use a drop of petrol down the bores rather than easy start etc.
John
own: 81 xs1100g...
hmmmnz
PostPosted: 08:27 - 05 Feb 2009    Post subject: Reply with quote
yeah its a bloody inboard disc setup, craziness really, about as good as anti dive forks, ya know a bit of a fad in the 80s,
yeah its got an airbox and brandnew airfilter fitted,
just checked cams again, and all is good there,
can't really alter ignition timing as its 2 seperate fixed pickups,
ill try the petrol down the bore an see how i go, (ive gone off easy start after that fire ball Very Happy)
ill keep ya posted, im kind of miffed really.
keep the ideas coming
the humans are dead
virus
PostPosted: 12:50 - 05 Feb 2009    Post subject: Reply with quote
I know what you mean about easy start, I managed to set myself, an air filter and my wiring on fire in a matter of seconds with that stuff.
good at bike rallys though for starting campfires. Laughing
Good luck
John
own: 81 xs1100g...
headgear
PostPosted: 12:50 - 06 Feb 2009    Post subject: Reply with quote
If you have the space how about towing it in 3rd gear.
Cover me in tuna and throw me to the lesbians.
NiteMare
PostPosted: 13:39 - 06 Feb 2009    Post subject: Reply with quote
to check that my last goldwing stood a chance of running i squirted a shot of easystart down the carb throats (all i wanted was it to cough a couple of times) DON'T go mad with it...
if it coughs/fires a couple of times you're good to go, all you need then is to get petrol flowing thru the carbs correctly which can be tricky with modern fuels and carbs when the bike has sat for as long as yours has ...
i got a lawnmower a couple of weeks ago with a very basic carb that had been sitting two years, the carb didn't look too bad but it had blocked the main jet solid ...
moderm bike carbs are way more complicated with loads more passages that may be blocked (my wing carbs were scrap)
it ain't broke...
i ain't fixed it enough
lonner
PostPosted: 14:06 - 06 Feb 2009    Post subject: Reply with quote
id go with carb prob looking at the furriness of that little vt
is it possible the leads are the wrong way round at the coil if its a double as this big backfire has mixed up firing order written all over it.
worth checking as god knows what's been done since it last lived Thumbs Up
virus
PostPosted: 14:21 - 06 Feb 2009    Post subject: Reply with quote
If the plugs are getting wet you can pretty much rule out carbs for now, id be tempted to go along with the HT leads being the wrong way around or something simmilar.
John
own: 81 xs1100g...
The last post was made 17 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 72.47 Kb
