A little lost, caliper help
Damon
PostPosted: 16:29 - 04 Feb 2009    Post subject: A little lost, caliper help Reply with quote
I finally got my calipers overhauled for the zxr 750. I have tried installing them today but they will not bleed. It must be me (im hoping) as i have never tried bleeding brakes from an empty system before. I have always just replaced the fluid by topping up the old fluid with new.
Is there anything i should be doing differently compaired to just chainging the fluid over without air in the system?
sorry for the stupid questions.
BCF to the resuce
Mudskipper
PostPosted: 16:35 - 04 Feb 2009    Post subject: Reply with quote
There are a few threads with ideas for this, I found the one that worked for my empty system was the back-bleed with a syringe one.
Syringe full of fluid, carefully force it through each (opened) nipple up the system until it bubbles through at the M/C end.
Then bleed as normal to get the few bubbles out. Thumbs Up
PostPosted: 17:53 - 04 Feb 2009    Post subject: Reply with quote
Try bleeding it at the top banjo bolt on the brake line (same way as you do at the nipples, pressure on then quickly loosen and tighten the bolt as you pull it in.). They sometimes get air locked at the master cylinder. Obviously you'll need a rag wrapped round it to stop brake fluid going everywhere.
I also find if you try and bleed it on every pull of the lever, you don't get far. I only crack the nipple every third pump.
Bikeless
PostPosted: 18:42 - 04 Feb 2009    Post subject: Reply with quote
I bought a one way valve from halfords(for a windscreen washer)then cut the bleed pipe and fitted it in the middle,then you can bleed the brakes without constantly having to open and shut the bleed nipple.You can just keep topping up the reservoir and pump.Makes things easier when you are doing it on your own.
BanditsHigh
Worse than a woman
PostPosted: 20:19 - 04 Feb 2009    Post subject: Reply with quote
All of the above is good advice (especially banjo bolt at reservoir) Thumbs Up
With regards bleeding without fannying about with the bleed nipple ... as above with the one way valve or get a length of silicon tubing (clear if possible, let's you see bubbles), block one end and put a small slit (lengthways) in it just up from the blocked end.
The tube will expand and open up the slit when fluid pressure is applied, i.e you pulling the lever but will close again when you release the lever.
You can also use a silicon tube to suck fluid down the brake lines (via the bleed nipple) to get the initail bleeding done ... needless to say you need to keep an eye out for fluid in the tube ... does not taste very nice and is bad for your health.
Good luck Thumbs Up
Damon
PostPosted: 21:44 - 04 Feb 2009    Post subject: Reply with quote
wikid thanks guys,
Will try again tomorrow.
Thumbs Up Karma
geordiecbrblo...
PostPosted: 21:51 - 04 Feb 2009    Post subject: Reply with quote
I couldn't get my CBR600 calipers to bleed - no pressure at all, until I took it off and literally held the caliper with the nipple upmost and that got rid of the air lock.
Smile
Damon
PostPosted: 20:59 - 06 Feb 2009    Post subject: Reply with quote
Hi all,
Spent the day out in the snow covered from head to toe in brake fluid. However, i managed to bleed all three brake calipers and now have competely new brakes for the zxr. I also changed the fluid in the hydrolic clutch to get rid of the spongy feel.
I've rebuilt the bike now and replaced the snapped alternator belt. Fingers crossed this will fix my charging problem and I will have a bike again. I just have small things like chain/sprockets, oil, air filter, finish repairing fairings etc to do now and I'm all done
Thanks for everyone's help Thumbs Up
The moral of this story. Do NOT let anyone ride your bike.
The last post was made 17 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.24 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 56.91 Kb
