Fuel Starvation or Flooding?
Gaz-t1esto
PostPosted: 14:06 - 05 Feb 2009    Post subject: Fuel Starvation or Flooding? Reply with quote
Hey people. Hope someone can help.
Used to experience issues with bike where when riding after about 10 mins the bike would jolt slightly and throw my weight forward as if i had dropped 3 gears and let the clutch out dropping several thousand rpm at the same time and its got much worse, I can now free ride at 50mph....lol Yes, as it starts to jolt and throw me forward, i pull clutch to stop myself being shot off bike and no sooner than i know it, the engine has cut out and im helpless to get it started until i stop. bump starting sometimes works. I have opened throttle to keep it running once i have pulled clutch lever but the bike still insists on dropping revs and cutting out.
What do people suggest is the issue.
My ideas follow:
Carb related?
Fuel Line maybe kinked/trapped?
Fuel Filter? (If it has one....im not too mechanically minded)Led to believe it might be gravity fed fuel but source wasnt 100% sure?
dirty fuel in tank being fed into engine?
Condensation at bottom of tank being fed into engine?
Not enough air mixture?
oil/fuel mixture wrong?
Blocked breather?
Recently changed the plug and its still the same issues.
Problematic vehicle is a CBR125 2006 Plate <<< An unreliable Honda.....for a change....
Blue_SV650S
PostPosted: 14:54 - 05 Feb 2009    Post subject: Re: Fuel Starvation or Flooding? Reply with quote
Id start with the blocked breather ... next time it conks out, pull over and 'pop' the fuel cap, if you hear it sucking air in .. well that is your problem isn't it Wink
Gaz-t1esto
PostPosted: 15:01 - 05 Feb 2009    Post subject: Re: Fuel Starvation or Flooding? Reply with quote
Didnt Think of that lol. and if it doesnt suck air in, then i will have one thing to score off the list. process of illumination then.
Gaz-t1esto
PostPosted: 16:17 - 05 Feb 2009    Post subject: Reply with quote
Doesnt appear to be breather or kinked pipe, lifted tank off and had a good look at pipes, all look fine with no kinks, tank very clean on inside....torch was very handy lol and breather pipe at bottom/over flow pipes are all clear of dirt and debris.
stumped for what to check next lol. maybe time for a mechanic.....
Blue_SV650S
PostPosted: 17:09 - 05 Feb 2009    Post subject: Reply with quote
I am not familiar with the exact nature of your bike, but the breather is highly likely to be in the 'cap' ... therefore I am not sure you can test this visually.
How many pipes are there to the fuel tap?
Paddy Blake
PostPosted: 17:31 - 05 Feb 2009    Post subject: Reply with quote
There might be water in the bottom of the carb.Turn off the fuel and open the drain screw at the bottom of the bowl.
Paddy.
Cigaro
PostPosted: 17:46 - 05 Feb 2009    Post subject: Reply with quote
You say it's almost putting you over the handlebars. That doesn't sound like a simple 'running out of fuel' thing to me.
Sounds almost like the engine may be partially seizing and then freeing itself up again, but being a 4t that seems very unlikely. By the way, you say 'Oil-fuel mixture wrong'... you do know that you don't mix oil with the fuel don't you?
Gawain
PostPosted: 23:09 - 05 Feb 2009    Post subject: Reply with quote
Sounds like lean surging. Could be fuel starvation/vacuum lock. Cleaning the carb may be necessary, are the carb rubbers in good shape?
Noxious89123
PostPosted: 23:31 - 05 Feb 2009    Post subject: Re: Fuel Starvation or Flooding? Reply with quote
Nope, just yours. Covered 10k on mine without a single hiccup. And as TheBassJunky said, it shouldn't be running oil in with the fuel.
Does your bike burn oil? Shocked
sam_w
PostPosted: 01:40 - 06 Feb 2009    Post subject: Reply with quote
i had a similar problem to this when i had my chinese bike, it could be a faulty ht lead/coil. A mechanic told me it was behaving the way it did because it wasnt sparking properly or at the right times so mine would jerk forward or cough and splutter and then occasionally cut out. get a multimeter and test your ht lead
Gaz-t1esto
PostPosted: 03:18 - 06 Feb 2009    Post subject: Reply with quote
i wil strip it down this weekend and have a good look if weather improves,
thanks for ideas people Smile
Gaz-t1esto
PostPosted: 15:57 - 06 Feb 2009    Post subject: Reply with quote
Im up2 22k on mines, its used for travelling to and from work and fun rides around scotland Smile
what would the seals on the carb look like if in good shape or even bad shape....
Also, is there a guide for easily stripping the bike of carb etc that i can follow...not being mechanically minded is my down fall...
no smart comments like, pick up the screwdriver or ratchet set and turn away till your heart is content Smile
The last post was made 17 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 74.41 Kb
