[PHP] display files in order
powelly
PostPosted: 15:37 - 06 Feb 2009    Post subject: [PHP] display files in order Reply with quote
I have a webcam that uploads an image to a folder every minute, this files are named as follows:
Im using the following code to display all the images from a given date (currently hardcoded as $date)
Code:
<?php
$date = "2009-02-02";
if ($handle = opendir('../../webcam/')) {
   while (false !== ($file = readdir($handle))) {
      if ($file != "." && $file != "..") {
         if (eregi('2009-02-02', $file)) {
            $page_name = $file;
               //$page_name=substr($file, 0, strpos($file, "."));
               echo "<img src='../../webcam/$page_name' width='160'/>";
closedir($handle);
However the output does not display the images in order, is there anyway to get round this based on either the filename or the files timestamp?
Yamaha RXS 100 > Gilera Runner 50 > Suzuki SV650SY
PostPosted: 15:59 - 06 Feb 2009    Post subject: Reply with quote
I would do your directory command and stick the results into an array and then look through the array to output it.
Eg.
Code:
<?php
$pages=array();
            $pages[] = $file;
rsort($pages);
foreach($pages as $page_name)
closedir($handle);
Not tried test running it but that should work.
rc211v
PostPosted: 16:27 - 06 Feb 2009    Post subject: Reply with quote
Code:
that's a weird way of constructing a conditional statement.
I always advice my students from doing it this way, I don't know why though.
Anyway, yeah, same as mentioned above. Go through the directory and place the filenames into an array. You can then sort the array, and use it to display your images in order.
I don't know if PHP comes with a built-in sorting function, but there are lots of algorithms out there you can use. Bubble sort maybe? Mr. Green
VFR400 (NC30)
PostPosted: 16:50 - 06 Feb 2009    Post subject: Reply with quote
rc211v wrote:
Code:
It is a bit strange but a few things seem to do it that way including on the php help pages.
Bloomin loads of them depending on what you want to sort.
powelly
PostPosted: 22:33 - 06 Feb 2009    Post subject: Reply with quote
Worked perfectly, Thumbs Up
The last post was made 17 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.83 - MySQL Queries: 13 - Page Size: 49.33 Kb
