HD TV
 Topic moved: from Random Banter to The Geek Zone by G (3 Feb 2009 - 23:49)
Ariel Badger
PostPosted: 22:53 - 03 Feb 2009    Post subject: HD TV Reply with quote
If a program is stated as being "Available in HD" where would one go to obtain it?
carvell
Scuttler
PostPosted: 22:55 - 03 Feb 2009    Post subject: Reply with quote
What channel?
Freesat HD ( https://www.freesat.co.uk ) is a free way to get HD TV. Buy the box, one off £150 odd. I have the Freesat+ PVR.
Yamaha TDM 850
pyx_e
PostPosted: 23:39 - 03 Feb 2009    Post subject: Reply with quote
HonDuras.
Shiney!
Kawasaki: ER5, Versys, VN900.
PostPosted: 00:01 - 04 Feb 2009    Post subject: Re: HD TV Reply with quote
Freesat HD is currently the only way of getting BBC HD for free. Otherwise its sky's HD service. There are currently no terrestrial HD services in the UK. I don't think there is the bandwidth available at the moment.
You also need a HD TV, and I'd personally look for a TV that can do 1080p at least (preferrably 1080i but you won't need that unless you've got an xbox 360 or a PS3.)
720p is a better format for most applications than 1080i, purely because interlacing is shit and should have been dumped along with PAL and NTSC.
<offtopic slightly>
Frustratingly, the stupid americans decided to go with 59.9 frames per second so it was a kind of double NTSC which is totally pointless. The reason why NTSC was nominally 30 frames was down to the electical frequency of US AC power. This is irrelevant nowadays and so the americans were pretty stupid to make the frame count maths harder than it needs to be.
Gimme 25 or 50 frames a second any day.</offtopic slightly>
Ariel Badger
PostPosted: 00:07 - 04 Feb 2009    Post subject: Reply with quote
Thanks all. My TV is " HD Ready" but I am buggered if I am going onto pay to view just to see shamless in HD.
PostPosted: 00:26 - 04 Feb 2009    Post subject: Reply with quote
Freesat.
HD ready is a marketing tool. For all you know it could only support 720p when Sky only supports 1080i.
You'll probably be OK though.
colin1
Captain Safety
PostPosted: 00:36 - 04 Feb 2009    Post subject: Reply with quote
or you could get a HD dvd player that also plays HD divx files of movies that are available to download illegally using 'torrents', and plug it into your hd tv using an hdmi lead
Ariel Badger
PostPosted: 00:45 - 04 Feb 2009    Post subject: Reply with quote
I have so little time to watch TV that it is not worth bothering with any of that stuff.
I sat down to watch Shameless tonight and instead spent the time writing an article about magnetos for a magazine and reading through the agenda of a SG meeting so Shameless is missed once again.
Rob
PostPosted: 10:48 - 04 Feb 2009    Post subject: Re: HD TV Reply with quote
Pah, keep your funny frame rates... 24fps FTW! Wink Laughing
I always find that one funny... how people think it's better because it says 1080 where as its only really 540 lines of resolution nearly 200 less than 720p!!!!
Love is 1050cc Smile
Rob
PostPosted: 10:50 - 04 Feb 2009    Post subject: Reply with quote
It also really depends on the size of your TV too. If it's anything below a 42" you're not going to see much advantage with an HD picture over a SD picture unless you watch TV stuck to the end of your nose! Wink
Danny
Ask Me About Stoppie School
PostPosted: 14:18 - 04 Feb 2009    Post subject: Reply with quote
Quick question on the how 1080i/p works on lcd screens.
I've got a 720p LCD tv connected by HDMI to my pc. Which should run a display resolution of 1280×720 afaik.
Yet I can set it to 1920×1080, am I correct in thinking that at that resolution it's essentially displaying 1080i?
If so, technically what resolution should I be setting it to then?
Ps. this is all fairly academic as I can't see any difference when playing a 720p or 1080p click on it, in either resolution!
Rob
PostPosted: 16:03 - 04 Feb 2009    Post subject: Reply with quote
Phew.. ok here goes!
Because your screen only has a resolution of 720, even though it accepts a 1080i signal (it may accept a 1080p?) it will downscale it to 720. Now there are two way of looking at this... if the TV is good, its downscaler will do a good job so in 'theory' if you pump a 1080p signal into it then you may get 'marginally' better picture quality. If it doesn't have a good downscaler then it can stuff your picture up horribly! Honestly though you are better sending it's native signal of 720p into it. As Mark says, interlacing is the work of the devil, so personally I would advise to avoid 1080i at all costs (and thats what the EBU also recommend strangely enough but the broadcasters over here ignored them and went for 1080i anyway Rolling Eyes )
So, bottom line, stick to 720p unless you have a native 1920x1080p TV then PLEASE stick 1080p into it... Mmm Blu-ray at 1080/24p looks gorgeous! Wink
Ah, just another note... as I mentioned earlier, size DOES matter when it comes to HD. You won't see much difference between SD and HD on a small screen with a good source. You need big screens to see the difference, same goes for 720 to 1080... at normal viewing distances you would need a 50"+ screen to start to see the difference between 720 and 1080! -
Danny
PostPosted: 18:02 - 04 Feb 2009    Post subject: Reply with quote
Ok that makes sense, cheers Rob. Very Happy
JonB
Afraid of Mileage
PostPosted: 18:08 - 04 Feb 2009    Post subject: Reply with quote
Does anybody know if Sky HD plans to broadcast in 1080p in the future? At the moment it only broadcasts in 720p and I think 1080i.
carvell
Scuttler
PostPosted: 18:09 - 04 Feb 2009    Post subject: Reply with quote
Bear in mind that the OP wants to watch shameless in HD, which is probably on Ch4 HD, which isn't available on Freesat yet, cos they're still bound to Sky.
So to watch it in HD you'd need a Sky HD box. Note that you wouldn't need a subscription to view Ch4 HD, but you would need a Sky card, available for £20 from Sky.
You can't record on a Sky HD box if you don't have a subscription either, you can only watch stuff.
Yamaha TDM 850
carvell
Scuttler
PostPosted: 18:10 - 04 Feb 2009    Post subject: Reply with quote
Not for years and years and years and years, if ever.
They're pretty tight for bandwidth on satellite as it is, and all available new bandwidth will be used for more HD channels, rather than making existing ones 1080p.
Yamaha TDM 850
Rob
PostPosted: 16:43 - 07 Feb 2009    Post subject: Re: HD TV Reply with quote
LukeVFR wrote:
Debatable.
LOL, what's debatable about that??!! PLEASE tell me the upsides of 1080i? I can't wait to hear what you have to say in it's favour!
Rob
PostPosted: 18:19 - 07 Feb 2009    Post subject: Reply with quote
Hmm, ok. I guess in your case it's personal preference, but as you were being so specific with Marjay on technicalities then I thought you had another reason for your comment rather than just what you think looks better!
Rob
PostPosted: 01:04 - 08 Feb 2009    Post subject: Reply with quote
LukeVFR wrote:
Nope, I agree entirely with what you say (as it's factual), but I've tried 720p/1080i on numerous panels including a £5k 60" Pioneer KURO and it really is debatable which looks better.
Guess it's down to your vision/perception really!
I too have a 60" kuro at home and 720p looks MUCH better than 1080i, to me, but that is a cheap old domestic TV compared to what I use at work, and in those cases you see a VAST improvement!
The scaler in the TV will make a difference also, if the TV is better at up-resing than the whatever you are putting into it then that can make a difference, but it's the kit that is doing it! For some the scaler in the Sky box will be far better than what their LCD tv can do!
There is a gap of 1 year, 63 days between these two posts...
desideriascot... This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
Mr.Everready
PostPosted: 11:25 - 12 Apr 2010    Post subject: Reply with quote
desideriascott wrote:
Hd tv support high resolution output and won’t arouse visual fatigue,connecting the input sources,such as DVD,VCR,camcorder,projextor,to your LCD monitor.720p draws all 720 lines per 1/60th of a second. 1080i only draws every other line (540 lines each pass) per 1/60th of a second.720p is definitly the way to go if you can afford a fixed pixel display .
O rly ?
PostPosted: 11:32 - 12 Apr 2010    Post subject: Reply with quote
Fuck off you SEO hunting sweatshop monkey.
Tarmacsurfer
PostPosted: 13:18 - 12 Apr 2010    Post subject: Reply with quote
After years of observing your posting habits I can't work out whether you take time and quiet delight in crafting each of these responses individually or whether you've gotten bored and set up a small script so you can trigger this reply with a hot button.
I'm immortal. Well, so far.
Rob W
PostPosted: 19:30 - 12 Apr 2010    Post subject: Re: HD TV Reply with quote
I always thought 1080p was better than 1080i? Although saying that my 42" LG is 1080p (which I run the PS3 at) and I cant really tell much of a difference if anything from 1080i/1080p.
el_oso
PostPosted: 12:18 - 14 Apr 2010    Post subject: Reply with quote
you are correct. 1080p is better. he has his p's and i's mixed up.
Duke 390
Car: Jeep Wrangler 4.0L
The last post was made 16 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.33 - MySQL Queries: 16 - Page Size: 133.54 Kb
