Bandit help Part 2.
instigator
PostPosted: 22:52 - 07 Feb 2009    Post subject: Bandit help Part 2. Reply with quote
(ELECTRICAL PROBLEMS DETAILED IN POST FURTHER DOWN )
Continuing from my last thread...
The bike originally required slipping of the clutch when setting off and would bog down at low revs. At idle and low revs in 1st gear, it would let out a "tssst" release of air every now and then, mostly at a standstill or when the throttle was blipped.
This week in particular, the bike wasn't riding too well. It felt like it wasn't running on all 4 cylinders and was seriously down on power. I used it Wednesday, Thursday and Friday. Throughout these 3 days it got progressively worse - it would eventually stall at traffic lights and would need to be 'over-rev'd' to get anywhere. This slipping of the clutch got worse until Friday, when, in the blizzard, it felt like the engine was ready to blow up. I had to keep the thing on the choke most of the time and on my final trip, it spat a continuous amount of flames out of the exhaust at idle before it died and would not start, even with the choke on/off.
At this point, I turned the fuel tap onto prime for a few seconds and back and it started up and purred nicely for a brief moment before resorting to being down on power and, what feels like the 4th cylinder only kicking in until 4-5k revs. At least I managed to get home okay. I put these problems down to a fuel delivery problem.
This week, the "tssst" noise had ceased. For reasons, I'm not sure but I hadn't touched it.
So, it's off the road for now until I get it running satisfactorily.
I took it to bits today and, after examining the fuel vacuum tube as suggested by others on the previous thread, found it to be securely fastened and free of any splits/leaks. However, referring to the following photo, No.2 was found to be uncovered. No.1 being the vacuum tube connection to the fuel tap.
https://img.photobucket.com/albums/v612/greggreggreg/breathers.jpg
Upon trying to remove the bastard carbs (it is difficult, 1st time round, right?), I opened the airbox and found the air filter to be relatively containment free. However, the mesh between carbs and air filter was splattered with oil from, what I suspect is, cylinder No.2.
https://img.photobucket.com/albums/v612/greggreggreg/airbox.jpg
I am yet to inspect the spark plugs as my tool kit does not contain the correct sized deep socket (can anyone advise on the size (mm) req'd?). I am also yet to do the valve clearances which I'll do once I get feeler gauges through the post. Smile
Any input from the knowledgeable folk? On parts I should examine etc. I have the carbs on my desk which I am intending to disassemble tomorrow. Smile
NiteMare
PostPosted: 23:19 - 07 Feb 2009    Post subject: Reply with quote
well first off i would have tried the bike again with that vacuum point plugged/capped as that being missing would severely bugger the running and probably require use of the choke to keep it running ....
i've no idea of the plug socket size as i found an old box spanner to suit in my pile of tools...
the "tssst" "could" be a backfire thru the carbs into the airbox , my slabby spits thru the carbs from time to time, i've no idea what causes it..
excessive choke will possibly be the cause of the flames out of the exhaust, unburnt fuel
it ain't broke...
i ain't fixed it enough
Kennypa4
PostPosted: 02:10 - 08 Feb 2009    Post subject: Reply with quote
Just for your info my vacum tube on my 600 k2 is on where your N0: 2 marked is . As the nitemare said you will need sort the missing vacum plug will not help at all.
Kenny
RBLS Riders
Scottishbikers Forum
Ichy
PostPosted: 09:35 - 08 Feb 2009    Post subject: Reply with quote
As snudge said, No.2 is the original fitting point for the fuel vacuum.
https://fiche.ronayers.com/Index.cfm/Module/Main/TypeID/26/Type/Motorcycle/MakeID/2/Make/Suzuki/YearID/39/Year/1998/ModelID/6335/Model/GSF1200S_BANDIT/GroupID/260713/Group/CARBURETOR
The missing vacuum cap is going to be the major cause of all your problems. Ignore the mesh in the filter box, its because the vacuum cap is missing.
I think I used an 18mm box spanner for the plugs, got it from halfords for about £3.
BanditsHigh
Worse than a woman
PostPosted: 10:04 - 08 Feb 2009    Post subject: Reply with quote
The oil on the mesh is from the engine breather on the cam cover.
As mentioned above having that carb sucking air in will completely feck the fueling for that cylinder and it'll be a drag on the other cylinder.
Is that a K&N that's in the piccy and I take it you have a race can fitted ... if so was the bike rejetted, if not then you'll be running lean ... not good.
If you don't get anywhere then gimme a bell and I'll bring over my carbs which have dual K&Ns and have been rejetted ... and because no airbox are piss easy to fit Thumbs Up
instigator
PostPosted: 11:19 - 08 Feb 2009    Post subject: Reply with quote
Cheers for the thought mate but I live in the big smoke these days. Shocked
I thankfully found a small red cap below the carbs, sitting on the engine block which obviously used to be fitted. However, due to the fact the subframe has what looks like a contraption to hold a tube/long cylinder fitted to it, my guess is that a scottoiler used to be fitted. And it used that breather cap.
The air filter is just a standard OEM jobbie, thankfully.
Cheers for the help all, will only be able to see if she's working as she should once I get my rivet gun through the post which is needed after stubbying/repacking my exhaust.
If all else fails, the OEM can will go back onto it.
timjim
PostPosted: 12:56 - 08 Feb 2009    Post subject: Reply with quote
The spark plugs are 10 mm threads but use a 5/8" spark socket..the number 2 and 3 plugs are a bit of a squeeze,so i invested in a flexi spark plug socket to make it easier..halfords should sell a decent plug socket..make sure you get one with a rubber insert to grip the plug when fitting/removing!!Good luck.Tim
timjim
PostPosted: 13:00 - 08 Feb 2009    Post subject: Reply with quote
the reason it ran ok on prime is that the fuel tap is then switched over to a gravity feed of the fuel as opposed to the vacuum feed from the carbs.make sure the stubs are blanked off.also make sure that the coils are clean and water tight..my 96 B6 has done nearly 60k in ALL weather conditions and has suffered from coil faults in the past when wet,but it sounds like yours is pointing more to a fuel problem.If its only suffering in cold weather have a look for a thread on SILCOLENE PRO FST use..good gear!! Thumbs Up
BanditsHigh
Worse than a woman
In reply to your wanted post (other section) I've posted you two links to cheap silencers on Ebay Thumbs Up
instigator
PostPosted: 14:32 - 08 Feb 2009    Post subject: Reply with quote
It has been the cold weather which has made the bike suffer more than usual but the decline in the engines power delivery has been gradual. Which would make me think it is the cold weather more than anything else. The missing cap would have always been off. So the symptoms don't match up per se but what has been suggested should hopefully sort it.
Also noticed that the airbox has 6 extra holes that have been drilled into it. I'll duct tape those up I think and if it still doesn't run correctly, pull out the carbs and check what size jets they are running.
timjim
PostPosted: 15:37 - 08 Feb 2009    Post subject: Reply with quote
the extra holes in the airbox would make me suspect that someone has done a home improvement on the irbox along with a K&N filter..mine has!! Rolling Eyes I wouldnt say that the stubs have ALWAYS been off,possibly removed during carb balancing or possibly just perished and fallen off??If you have major concerns or worries do a compression test.Its difficult to identify the cause at a quick glance ,but id have a look at the basics first before attempting to take the carbs off! Rolling Eyes
BanditsHigh
Worse than a woman
PostPosted: 16:57 - 08 Feb 2009    Post subject: Reply with quote
Ah, the old airbox mod ... as timjim pointed out this is one of the mods to the bandit airbox which along with rejetting and a race can gives a healthy release of horses ... although usual method is to remove plastic trumpet and cut anther 2" (I think) hole Smile
It's the cheaper method of the two, the other being the airbox getting dumped and replaced with dual K&N's as in my B12s case.
Hope you get her sorted Thumbs Up
instigator
PostPosted: 17:03 - 08 Feb 2009    Post subject: Reply with quote
I put it all back together and put the sealed off the remaining vacuum point with the red cap which I found after disassembling the bike. Started the bike and heard the "tssst" noise and found the red cap had flown off straight away. So one can only assume that it was off from the start. The 'OEM' vacuum cap is secured on with a clamp which was unfortunately missing. So I'll order that tomorrow. Instead, I kept it on with some duct tape and a cable tie.
It idles nicely and blips the throttle fine but is well down on power, still. I did stubby the exhaust but I have a gut feeling that that is not the problem here. I still reckon it's something to do with the fuel delivery. Riding along at 30mph in 3rd and I can yank the throttle open and it won't do anything for a few seconds....or it'll "gurgle". Stupid machine, I'll sort it next weekend I'm sure.
OEM exhaust will be ordered though.
P.S Timjim am sure my filter isn't a K&N - it's a paper type material and has no branding on whatsoever...doesn't mean someone hasn't put one in before. Mad
BanditsHigh
Worse than a woman
PostPosted: 17:17 - 08 Feb 2009    Post subject: Reply with quote
I think we both thought it was a K&N due to the colour, aren't standard filters more of a yellowish/creamish colour.
Mind you, the K&N usually has a fine wire mesh over the filter ... I think Thumbs Up
Thing is if it was running okay up until now then, apart from the carb rubber bit coming off, I'd be more inclined to look at the silencer ... did it start going tits up when you fitted that?
timjim
PostPosted: 17:39 - 08 Feb 2009    Post subject: Reply with quote
hi,this is getting intriguing..the oe filters are an orangy gold colour from memory(cant remember as mines had a k and n for so long ,but dont tell the insurance co!!!!)id still say try some silcolene pro fst for a while in the cold weather as mine occasionally has the same symptoms..starts ok from cold,runs well/ok for a while till warm,then starts coughing,spluttering on acceleration..tried fuel additive and appeared to sort it out!!ps..ive got carb heatres fitted as welll Neutral
instigator
PostPosted: 17:48 - 08 Feb 2009    Post subject: Reply with quote
The bike was fitted with the race can when I bought it.
Re: the filter - it is the same as this one. https://cgi.ebay.co.uk/Suzuki-GSF-1200-Bandit-95-99-Model-Air-Filter_W0QQitemZ350142788001QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item350142788001&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318
Most likely a pattern part. I have the details of the owner before the previous one so will contact him out of curiosity.
Re: fuel additives - it was actually surprisingly warm today so not sure they would help really. Guess there is no harm in trying but it was colder when I bought the bike and it didn't misbehave as 'badly' as it is now.
timjim
PostPosted: 17:51 - 08 Feb 2009    Post subject: Reply with quote
sorry..it did look similar to the kand n!! Shocked keep the "race" can on!!lol
BanditsHigh
Worse than a woman
PostPosted: 17:54 - 08 Feb 2009    Post subject: Reply with quote
Bastids have changed the colour of standard filters Laughing
Keep us updated Thumbs Up
All the best ... Barry
P.S. I take it #1 is firing ok, in other words your coil isn't starting to go?
instigator
PostPosted: 17:58 - 08 Feb 2009    Post subject: Reply with quote
To be honest, I haven't checked. I've ignored coils as of yet due to the fact I haven't got a spark plug socket big enough.
Useless fucking Halfords didn't do an 18mm deep socket. 17mm, 19mm but no 18mm!!!!!! Great, sell spark plugs with an 18mm size but don't sell the socket. Rolling Eyes Ebay it is then.
I have a tendency to jump to look at the more complicated parts when I should really check the basics first. Embarassed
BanditsHigh
Worse than a woman
PostPosted: 18:08 - 08 Feb 2009    Post subject: Reply with quote
We all do mate ... I was having serious problems with the clutch on my Mk1 B12, just wouldn't disengage properly ... eventually burnt the clutch out.
Tried everything, heavy duty clutch springs and eventually the heavy duty springs plus a standard one to keep the clutch going.
Eventually worked out why it hadn't been disengaging properly ... the lever pivot hole had ovalised (is that a word) and wasn't properly actuating the reservoir piston Embarassed Embarassed Embarassed Embarassed Embarassed
timjim
PostPosted: 19:31 - 08 Feb 2009    Post subject: Reply with quote
the spark plug sockets are a nightmare..i ended up getting a Snapon 5/8" flexi soket(30 quid!! Shocked ),but its ace for getting the no 2 and 3 plugs out!!may be an idea to have a look at the coils..the left hand coil is for no 1 and 4 cylinder and the right for 2 and 3...good luck.
Gawain
PostPosted: 21:54 - 08 Feb 2009    Post subject: Reply with quote
You dont need to take the plug out to check for spark. Just take the ht lead off, stick any spare plug in and check for spark normally.
instigator
PostPosted: 22:04 - 08 Feb 2009    Post subject: Reply with quote
Gawain wrote:
any spare plug in
And therein lies the problem. Laughing
Spark plugs ordered (£2.50 each, bargain, love ebay) along with 18mm socket so will try on Tuesday.
teabag
PostPosted: 22:06 - 08 Feb 2009    Post subject: Reply with quote
My GSX600F used to run rough when it was cold and damp, which I eventually traced to water down those nice deep plug holes. New HT leads with a good tight rubber seal on the plug solved it.
NS125R = 2 years > GSX600F = 7 years > XR125L = 3.5 years > SV650S........and a Citroen Synergie HDI for the kids.
NiteMare
PostPosted: 03:34 - 09 Feb 2009    Post subject: Reply with quote
i believe there is a drain hole at the bottom of the plug recesses that blocks up with road crap, check to make sure those are clear
it ain't broke...
The last post was made 17 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 134.49 Kb
