| The Rig |
 The Rig Derestricted Danger
| lonner |
 lonner Spanner Monkey
 Posted: 10:39 - 07 Feb 2009 Post subject: |
how old is the bike as unlikely if its under 10yr old but is possible.
if the brakes worked before its unlikely to be the m.c
you usually get leakage at the leaver if the m.c seals have perished.
so i think you need to bleed the brakes a bit more.  |
| BanditsHigh |
 BanditsHigh Worse than a woman
| binge |
 binge Emo Kiddy
| Cigaro |
 Cigaro World Chat Champion
 Posted: 15:05 - 07 Feb 2009 Post subject: |
Sure you've put the right fluid in?
Same thing happened to mine when I put ATF in instead of brake fluid, corroded the seals. Had to rebuild the entire m/c and calliper  |
| Borg |
 Borg Derestricted Danger
| timjim |
 timjim Trackday Trickster
| The Rig |
| BanditsHigh |
| The Rig |
| BanditsHigh |
 Posted: 19:05 - 08 Feb 2009 Post subject: |
Hmm, sounds like original brake lines ... may be they are past it, see if they bulge at any point when applying brake pressure as another check  |
The last post was made 17 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
