| binge |
 binge Emo Kiddy
 Posted: 21:06 - 08 Feb 2009 Post subject: Speed Wobble |
Since fitting my new forks on my pit bike, I am experiencing speed wobble at around 65 - 70mph.
I'm not sure what is causing it. It wasn't doing it with my old forks, BUT the old forks had very tight headstock bearings. So much that when the front wheel was suspended off the floor, it was quite "clunky" to turn the bars from left to right.
I think this may have acted as kind of a steering damper with the old forks.
Now my new forks are nice and smooth left to right. It is wobbling. The forks are also longer than my old ones, However, I have dropped the yokes by 2" to compensate for this.
It sounds stupid for a pit bike, But would a steering damper be my only option of cure? Obviously these bikes weren't designed to do 70mph.
Ben |
| TUG |
 TUG World Chat Champion
| element |
 element World Chat Champion
 Posted: 21:21 - 08 Feb 2009 Post subject: |
wider bars might help too.. ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| binge |
 binge Emo Kiddy
| TUG |
| binge |
 binge Emo Kiddy
 Posted: 21:32 - 08 Feb 2009 Post subject: |
I never had any on my NC29. I had flush fit Oxford bar ends which were weightless.
Might give them a shot. Just think they might look a bit gay.
Ben |
| TUG |
| MarJay |
 MarJay But it's British!
| G |
 G The Voice of Reason
| TUG |
| lllN30lll |
 lllN30lll World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 21:56 - 08 Feb 2009 Post subject: |
You got the forks straight ?
Are the new one's bent in anyway ?
Perhaps trying altering the amount you have dropped them and see if it changes anything. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Kickstart |
 Kickstart The Oracle
 Posted: 21:58 - 08 Feb 2009 Post subject: |
Tight steering head bearings normally make stability worse. However one main reason for this is that when the bearings are stiff you land up over correcting all the time.
A full on tank slapper is largely down to the forks flapping from side to side at a natural frequency. Weights on the bars can change this (for better or worse), but not their primary purpose.
I would go with Marjay and say to change how much the forks are dropped through the yokes. 2" is a long way to have dropped the yokes down the forks. Also check the mounting of the wheel (ie, was the axle in front of the forks on the old set).
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 22:00 - 08 Feb 2009 Post subject: |
unbalanced wheel?
it is a tiddler after all... lost any of the weights on it? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| G |
| MarJay |
| Kickstart |
 Posted: 22:16 - 08 Feb 2009 Post subject: |
Looking at the side on views of the bike in the alloy bracket thread there seem to be a fair few differences between the old forks and the new ones.
Also remember that the forks springing / damping is likely to be very different. Entirely possible that when you sit on the bike the new forks are compressing rather more than the old ones, reducing stability even more.
| G |
 Posted: 22:39 - 08 Feb 2009 Post subject: |
Sorry, I should have specified dropped the yokes, which is what I was thinking at least .
Also what N30 meant I presume, as that would slightly reduce wheelbase. |
| lllN30lll |
 Posted: 22:42 - 08 Feb 2009 Post subject: |
I was meant to say yokes  ____________________ Turbo R1
CRF450R |
| binge |
 binge Emo Kiddy
 Posted: 23:04 - 08 Feb 2009 Post subject: |
Yes. The old forks were 660mm long, And the axle bolt was smack bang across the bottom of the fork legs.
The new forks are more like "Big bike" forks. The axle is set forward by about 10mm, It has pinch bolts like my NC29 did.
These new forks also have and adjustment on the top of each leg. One leg has a "Fast - Slow" knob on it, And the other has a "Soft - Hard" knob it on.
The reason the new legs are longer is because they are designed to be run on a KLX110, which has a 6.25" headstock. Now my bike only has a 5.5" headstock, so I got the shorter headstock bolt when buying the forks. And obviously I needed to move the yokes down the legs a bit otherwise it would be like riding a Harley. And lets face it, That would be ghay.
I will have a tinker tomorrow, Will raise the yokes back up by 10mm, Balance the front wheel and go from there.
My old forks had 20 weight oil in them, And a set of 1/2 spacers above the springs. I did this because they were too soft when I bought them.
My new forks, I have no idea if there is even oil in them! I've heard some of the high end pit bike forks (Fast ace, Marzocchi, Fox, Elka, etc) are Nitrogen filled.
The new forks seem to be very adjustable though.
Maybe the suspension and Geo needs setting up properly. I've not really set anything up yet. Just set it so it bounces down evenly when I bounce up and down on the foot pegs.
Ben |
| Kickstart |
| binge |
 binge Emo Kiddy
 Posted: 23:28 - 08 Feb 2009 Post subject: |
Yea one leg adjusts one, and the other leg adjusts the other.
No idea what which is though. Rebound, Preload?
Ben |
| Kickstart |
| binge |
 binge Emo Kiddy
| G |
The last post was made 17 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
