| Chriss |
 Chriss World Chat Champion
 Posted: 16:08 - 09 Feb 2009 Post subject: CAR: High Milage Servicing? |
Hi, my car's just ticked over 100,000 miles, and the Mrs and I have decided there's no reason not to carry on with it, so we're looking to keep it, idealy for another 100k miles.
I think my biggest fear is the head gasket(s?) going, or maybe the piston rings. The car's just had fuel filter changed at 90k, along with a oil change, and I've changed the oil and filter every 10k miles. Is there any preventative maintainance that I can/should do? Is it easier to change the head gasket(s?) before they go, or just fix things as problems arise?
The car's a Ford Cougar V6, hence, think there'll be two head gaskets.
Thanks in advance! Any help suggestions greatful. ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old. |
 Posted: 16:28 - 09 Feb 2009 Post subject: |
Not really any preventative maintenance for the head gaskets, except for making sure the antifreeze is up to spec. You could just replace them (on the basis that they would be less likely to need a skim if done without blowing first), but realistically it would not really make a difference to how difficult the job was and also could possibly cause them to fail if the job isn't done perfectly.
For the piston rings they should be fine. Just don't thrash it from cold and keep changing the oil regularly.
In other words, just keep on doing what you are doing.
| 0ddball |
 0ddball World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 17:01 - 09 Feb 2009 Post subject: |
If the gaskets are going to go then they will and there is nothing you can do.
You could change them, but they could still go, even after doing that.
Best thing leave well alone, carry on with regular servicing or not as the case maybe.
Like the post above, be gentle on cold statups as thats when the most damage is done.
Engines now seem to be able to take much higher milages with ease. Maybe its because they spend so much of their lives under next to no stress. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Howling TerrorOutOfOffice |
| NiteMare |
 NiteMare Spanner Monkey
| arry |
 arry Super Spammer
| arry |
 arry Super Spammer
| hmmmnz |
 hmmmnz Super Spammer
| Darth |
 Darth World Chat Champion
| hmmmnz |
 Posted: 20:52 - 09 Feb 2009 Post subject: |
a stabilizer thickens the oil and allows to be kind of sticky.. not really the right word, but it holds the oil together.
not really like oil
the worse thing you can do to an old engine is run super thin oil,
well in my experience anyway  ____________________ the humans are dead
I kick arse for the lord
| timjim |
 timjim Trackday Trickster
| stevo as b4 |
| drew70 |
 drew70 Trackday Trickster
 Posted: 23:28 - 09 Feb 2009 Post subject: |
As timjim says 5/30 semi synthetic, i change my v6 oil every 10k and anti freeze changes every 4 years 50/50 mix is what ford used to recomend. These engines are pretty much bullit proof, unless they get over heated. Have a look at your water pump belt as it might be the original, not the alternator belt. The w/p belt is on the nearside of the engine under the front head cover, its like a big hoover belt. I used to work for a large ford dealer and only twice in eight years we had a 2.5 v6 in bits and on both occasions it was due to driver abuse ,ie. not paying attention to the temp guage after the rad had burst lol.
| yen_powell |
| drew70 |
 Posted: 23:57 - 09 Feb 2009 Post subject: |
No probs with the 2.5v6 its got a cam chain  |
| 4Stroke |
 4Stroke Scooby Slapper
The last post was made 17 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
