| priller |
 priller Brolly Dolly
| Dazed |
 Dazed Two Stroke Sniffer
 Posted: 16:24 - 13 May 2004 Post subject: |
I've searched for this on Google before (just out of interest), there were some problems with some bike speedos not working after 75mph, so it's best to find out which ones work to a useful speed before buying. Also try to ensure that the sensor cable will be long enough for your motorbike.
I also read that wireless ones might not work, due to interference from the engine and possibly due to the extra distance on a motorbike between the sensor and bicycle speedo. Also you may have to upgrade the magnet yourself so it can activate the sensor from further away. My magnet clips around the spokes on the wheel, and is then screwed together. I read a lot of people glue/epoxy theirs onto the wheel - bear in mind that it could fly off and hit you, or unbalance the wheel possibly.
You also have to take the placement of the sensor into consideration more on a motorbike (e.g: the distance from the center of the wheel) because, say putting it on the outside of the wheel it could go past too fast for the sensor to trigger. Another thing is that the tyre expanding due to heat may affect the accuracy.
A big problem people find is the cable from the sensor to the speedo can snap easily, so look for ones with a nice thick cable like my Enduro has, it also came with a twisty plastic cable cover to save it from abrasion. I read some Sigma ones do up to 150mph. A backlit speedo would be useful at night, as well as a waterproof one if they exist.
It would be pretty cool though having the functions of the bicycle speedo, my 'Cat Eye Enduro 2' (£20, for my bicycle) has current speed, average speed, max speed, 2 trip meters, clock, timer and an odometer. A useful function on mine is that if you lose the data due to a battery change, it'll let you re-program the total distance back in. One thing to remember is that you'll need to program the circumference of the tyre into the speedo, the manual for mine had lists of standard bicycle tyres and also how to just measure it and convert it. |
| badlydamaged |
 badlydamaged Spanner Monkey
| senebole |
 senebole L Plate Warrior
| Kickstart |
 Kickstart The Oracle
| priller |
| Flip |
 Flip Super Spammer
The last post was made 21 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
