Changing up without the clutch
AppleJoe
PostPosted: 14:30 - 15 Feb 2009    Post subject: Changing up without the clutch Reply with quote
When accelerating hard, I just go through the gears without using the clutch. Never thought much of it, but is it bad for the gearbox / the bike in general?
Full licence from 16/4/08 Smile
Previously: '56 YBR125 - Current: K1 SV650S
Flip
PostPosted: 14:35 - 15 Feb 2009    Post subject: Reply with quote
It's fine. Just don't do it going down. Laughing
The Tot
PostPosted: 14:38 - 15 Feb 2009    Post subject: Reply with quote
It's fine when done properly. But always use your clutch between 1st and 2nd to prevent going into neutral.
Never argue with autism
AppleJoe
PostPosted: 14:44 - 15 Feb 2009    Post subject: Reply with quote
Good good. Titz - what do you mean 'done properly'? I've never actually seen it done or read about it (I just discovered it one day) so have no idea how it's meant to be done Smile
PostPosted: 14:46 - 15 Feb 2009    Post subject: Reply with quote
I've never had any problems doing it, i make sure its a firm upshift.
But would like to know the actual mechanics of a clutchless gearchange compared to normal changes. Keep it simple please.
Pat
[edit]
made the effort and did some searches..lots of info already
S1KE
PostPosted: 15:15 - 15 Feb 2009    Post subject: Reply with quote
ive always done it changing up, but never down, for obv reasons,
get a quickshifter kit and u wont have to back of the throttle before you knock it up Thumbs Up
random twat!
* xbox live mickeyc26
* zx6r b1h 2004 GREEN !
bEN_
PostPosted: 15:20 - 15 Feb 2009    Post subject: Reply with quote
No need to do it going down on the road although it's not any harder.
i'm not sure about done 'properly' but all i do on a bike is put abit of pressure on the lever before changing up so it's smoother and less of a 'clunk' feeling when rolling off/shutting off the throttle.
2010 Ducati 848 Dark
Lamp Post Enthusiast
The Tot
PostPosted: 15:33 - 15 Feb 2009    Post subject: Reply with quote
Well i back off the throttle to the point where the bike is neither accelerating nor decelerating, just a slight flick of the rigth hand forwards, and you snick it up into gear.
I've seen people, and I admit when i was first doing it, I used to let off the throttle for a prolonged period of time before i snicked it up and it used to go in with a clunk.
My motion now is, when i roll off the right hand, my left foot is placed right under the shifter. Once I dip the throttle, next gear is enganged. Make sure you do it swiftly though... well that's what i meant by doing it properly.
You do see people doing it incorrectly - it's not a fine art or anything; just practise and feeling.
Finglonga
PostPosted: 17:48 - 15 Feb 2009    Post subject: Reply with quote
Can be done up or down, I rarely use the clutch apart for stopping, starting or from going from first to second. Been loads of threads about it.
Andy Sez....
F.Y.Y.F.F.
MinhDinh
PostPosted: 18:01 - 15 Feb 2009    Post subject: Reply with quote
Wow i use the clutch all the time. I didn't even realise it was possible to shift up gears without the clutch without any problems.
Hit the G spot. Wink
Acemastr
PostPosted: 18:39 - 15 Feb 2009    Post subject: Reply with quote
i do it on the 125, problem is it tends to 'lurch' forward when i do it, need some more practice i think!
2016 Toyota Tacoma Limited
PostPosted: 18:51 - 15 Feb 2009    Post subject: Reply with quote
It won't hurt it. The exact technique varies from bike to bike, but what I do is apply upward pressure to the lever then slightly chop the throttle and it'll just snick up. With different bikes you can get away with shuting off different amounts.
cicatrez
PostPosted: 19:21 - 15 Feb 2009    Post subject: Reply with quote
I'm clumsy sometimes. I'll flick it into neutral after topping out in 1st. or sometimes (tho rare), i've flicked it into 2nd, and its gone back to neutral?
'02 Honda City Fly
PostPosted: 19:23 - 15 Feb 2009    Post subject: Reply with quote
If you don't shift into second positively enough it'll jump out. I used to do it when I first started out, don't do it anymore though.
PostPosted: 19:34 - 15 Feb 2009    Post subject: Reply with quote
My GSXR 400 was terrible for it too. Hornet wasn't as bad, and not had problems since.
ajb
PostPosted: 19:37 - 15 Feb 2009    Post subject: Reply with quote
My CB500 sometimes used to find a false neutral between 5th and 6th when clutchless upshifting. The rev needle would whizz up to the top followed by a massive clunk as it engaged into 6th lol Twisted Evil
I've never done down shifts without a clutch, unsure on the exact method.
CBR125R '05 > CB500 '00 > CBR600F '99
PostPosted: 19:48 - 15 Feb 2009    Post subject: Reply with quote
My view on downshifting without the clutch is that if it was that good then the racers would do it. When they stop using the clutch so shall I. Wink
MaybeGuy
PostPosted: 22:15 - 15 Feb 2009    Post subject: Reply with quote
downshifting is easier in my opinion.
light pressure downward as you engine brake, then it just drops straight in.
Tristan.
PostPosted: 22:21 - 15 Feb 2009    Post subject: Reply with quote
On my CB I just stamp on the lever, but thats cos my CB is magic
0ddball
PostPosted: 22:25 - 15 Feb 2009    Post subject: Reply with quote
Why would anyone be in such a hurry that they would need to do it on the downshift?
You're pulling into Tesco's carpark not braking for the Melbourne hairpin.
Tristan.
PostPosted: 22:27 - 15 Feb 2009    Post subject: Reply with quote
Because I can.
KevTM
PostPosted: 23:32 - 15 Feb 2009    Post subject: Reply with quote
yeah i still use clutch on downshifts, little blip of the throttle, scare the little pedestrians.. more fun.
Method
PostPosted: 10:11 - 16 Feb 2009    Post subject: Reply with quote
Havent used the clutch for changing gears (other than 1st/2nd gear to avoid neutral) for years now.
It takes a while to get used to downshifting without, but its very smooth when you get it right. Upshifting is easy!
Just take your time if your wanting to learn how to downshift, get it wrong and you could have your mid-regions against the tank quite hard Wink
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Faldo
PostPosted: 11:08 - 16 Feb 2009    Post subject: Reply with quote
I never even think about changing gear, I just do it. Very rarely use the clutch for up or down shifting. Only use clutch for down shifting if I'm attempting some rather heroic engine braking.
Current: ZZR1400
Kal
PostPosted: 12:02 - 16 Feb 2009    Post subject: Reply with quote
Get it wrong and the gearbox will lunch itself, I am efficent enough at detonating engines without blowing up the gearbox as well.
Personally I cannot see the point, I have heard it said many, many times that clutchless is faster and smoother - but to be honest with you my clutch control is smooth enough that I don't have pillions hitting me in the back of the head when upshifting/downshifting and sharp enough that Superdream willing I am about as quick as I want to be off the line in the traffic light Grandgrix.
Yes racers do it on the track but then their bikes get a rebuilt between rides and they spend more on spares for a meet then then entire value of my garage.
Kal...
The last post was made 16 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 128.6 Kb
