Bike cutting out
AppleJoe
PostPosted: 15:40 - 21 Feb 2009    Post subject: Bike cutting out Reply with quote
Recently by bike has been cutting out while riding along. It always happens when I'm approaching traffic lights, pull the clutch in to coast the last few meters, then the engine just goes.
Any ideas as to what, if anything, is wrong with it?
I thought it could be the cold, but when I start it up I leave the choke on enough so that it can just sit there ticking over without the choke on, and this is often after 5-10 minutes of riding.
Full licence from 16/4/08 Smile
Previously: '56 YBR125 - Current: K1 SV650S
doggone
PostPosted: 19:07 - 21 Feb 2009    Post subject: Reply with quote
sidestand cut out switch is a possibility.
Are you saying it starts again almost immediately?
cyberglass
PostPosted: 19:22 - 21 Feb 2009    Post subject: Reply with quote
Might need the idle ajusting slightly whats it like when riding?
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
AppleJoe
PostPosted: 12:57 - 22 Feb 2009    Post subject: Reply with quote
Nope I have to start it again (as in keep the clutch in, press starter button and give it some revs). Not the nicest of things to do when you filter to the front of traffic lights then they go green.
Finglonga
PostPosted: 14:16 - 22 Feb 2009    Post subject: Reply with quote
That isn't curing the fault though it is hiding it.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 14:37 - 22 Feb 2009    Post subject: Reply with quote
check your air filter is clean
check plug gap
check breather pipes
don't fiddle with carbs until you've checked everything out 1st
Pat
Skudd
PostPosted: 22:53 - 22 Feb 2009    Post subject: Reply with quote
Some Hondas do this and it has been found to be the ECU that needs resetting.
The Tot
PostPosted: 23:17 - 22 Feb 2009    Post subject: Reply with quote
I had this happen to me on the blade. Just increased the idle and it cured the problem. I checked for all the obvious things - side stand switch etc. The idle was somehow set at ZERO.. so i had to constantly blip. It was the first time i had a fuel injected bike so i didn't know how the cold start went.
Never argue with autism
The last post was made 17 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 57.27 Kb
