Speedo accuracy
LeeR
PostPosted: 20:49 - 23 Feb 2009    Post subject: Speedo accuracy Reply with quote
How accurate are speedos supposed to be?
I took my GPS with me on the bike today and although 30mph is 30mph apparently 90mph is only 78mph.
I reckon my indicated top speed was around 95mph and yet the GPS said my top speed over the entire run was 84.8mph
Is this usual for a Suzuki speedo?
My claim to fame: Austin Vince nicked my pen...
nunswimming
PostPosted: 21:17 - 23 Feb 2009    Post subject: Reply with quote
Legally speedos are only allowed to over read by 10% plus an extra 2mph.
So essentially when you think you are doing ton you could in fact only be doing 88mph.
However obviously not all speedos under read this much people have put their bikes on dyno and the indicated speed is very close to the real speed.
Have heard it can depend on make of bike, type of speedos etc.
PostPosted: 21:44 - 23 Feb 2009    Post subject: Reply with quote
Depends how accurate your GPS is! Most GPS units are not that accurate, while performance ones don't directly use the GPS directly but instead work off the doppler effect on the GPS signal. Don't rely on a "highest speed" reading because that could just be a blip. For example I have had a highest speed reading of over 70mph on my YSR50 (does about 50mph really), but checking the logs showed that the speeds a second either side of the 70mph reading were FAR lower.
Speedos are allowed to be 10% +8kmh out for production but must read accurately or high. It cannot read low. Think nunswimming is getting confused with the guidelines for doing someone for speeding. They are also only tested at 2 speeds (from memory 50kmh and 120kmh).
On my 1200 Bandit the last marking on the speedo is 170mph, which coincides with the red line in top on standard gearing. It is an actual 154.5mph.
davthegreat
PostPosted: 00:08 - 24 Feb 2009    Post subject: Reply with quote
hi
ive seen people buy a bicycle computer and put it on there motorbike to compare speeds with normal speedo. how does this work because when you get one you need to input the wheel size and most of the computers have a lowest value of 20" ive seen some that say fit all bike though so they or is it just to the lowest value. Also another factor of the the calibration/setting up the computer to make it accurate is entering the tyre width wtf how can you enter for example 100/70 x 17 on my derbi senda Smile into it when its made for bicycle tyres. Here is the sizes that can be entered into a random one i found on google
Schwinn Bike Computer Wheel Size numbers
Wheel Diameter Number
20" 1596
22" 1759
24" 1916
26" (650A) 2073
26.5" (Tubular) 2117
26.6" (700x25C) 2124
26.8" (700x28C) 2136
27" (700x32C) 2155
28" (700B) 2237
w/ tire
ATB 24X1.75 1888
ATB 26x1.4 1995
ATB 26x1.5 2030
ATB 26x1.75 2045
ATB 23x2 (650B) 2099
27x1 2136
27x1 1/4 2155
thanks if anyone can help Smile people put them on so there must be a way of getting round it or getting a universal one.
Smooth
PostPosted: 12:42 - 24 Feb 2009    Post subject: Reply with quote
davthegreat wrote:
hi
I have a Sigma Targa into which you put the measured wheel circumference in mm.
My bike's speedo does appear to over-read by a few Km/h compared with the bicycle computer (and compared with those road-side "this is your speed" signs)
Bikeless
PostPosted: 13:23 - 24 Feb 2009    Post subject: Reply with quote
I used to run a bicycle computer on mine and you could put the front wheel diameter in,measured with a piece of string sat in the middle of the tread.
davthegreat
PostPosted: 18:29 - 24 Feb 2009    Post subject: Reply with quote
i see, ok thanks for the help
davthegreat
PostPosted: 18:35 - 24 Feb 2009    Post subject: Reply with quote
ok i like them sigma ones heres one on ebay
Item number: 260365354483 just copy and paste the number into ebay.co.uk for the item (for ppl who dont know what to do with the number)
do you know if it has a clock on it like 12hr/24hr clock, as in a clock not speedo clock. need a clock on my bike Smile and the ones on ebay made for handlebars are analog Sad wouldnt look good on my bike, it says clock in the writing but im not sure if its talking about the speedo when it says clock in the writing
also the one on ebay says in the writing 12mph = 24kmh but does the actual speedo on it that will work in mph
thanks for any help (assuming its the same as yours)
Charlie
PostPosted: 18:57 - 24 Feb 2009    Post subject: Reply with quote
I wouldn't go off highest speed either, I once got over 1000mph while on a walk.
We downloaded the log onto the computer, there was a glitch for around a second in which we visited the north poll and back Shocked
T0MMY
PostPosted: 19:02 - 24 Feb 2009    Post subject: Reply with quote
When my car has 130 on the speedo the GPS reads 116. Never tested the bike.
I was under the impression the GPS was pretty accurate, is that not the case then?
ZX6R + CBR600RR
Moonie
PostPosted: 19:08 - 24 Feb 2009    Post subject: Reply with quote
OT, how accurate are the roadside signs that tell you your speed?
I haven't got the GPS speedo any more and want to know how fast the chinkmobile really is.
PostPosted: 19:15 - 24 Feb 2009    Post subject: Reply with quote
General use GPS is accurate, but it is designed to give position rather than speed. If it is a unit that takes speed by checking the distance between positions then a minor error in one of those positions (maybe due to the signal from a satellite being obscured) could make a fairly large difference to speed.
For example most GPS units take positions every second. If one of the positions is just 5m out then it could add ~11mph to the speed (could also subtract it, depends on the direction it is out) for that second. A crude display might just hide this by smoothing out the speed readings so you might not see it except by checking the log.
LeeR
PostPosted: 19:34 - 24 Feb 2009    Post subject: Reply with quote
I take your point Keith, and thanks everyone for the answers.
Having thought about it some more, I reckon that given a GPS tolerance +/-3m then at speed I'm obviously going to get some anomalous readings.
I have noticed that when I'm in 50 zone and I've slowed down to 50mph that all the vehicles seem to be moving at a fairly constant speed.
I don't reckon my speedo is out, but I do think as has been pointed out that all speedos report a higher reading and they seem to be consistent.
PostPosted: 19:40 - 24 Feb 2009    Post subject: Reply with quote
Not sure they are always consistant. Certainly the accuracy of the speedo in one of our cars varies when compared to GPS. Much of the time it is 5mph high (goes up slightly at high speed, but not much, but 35mph indicated is 30mph, while maybe 86~87mph indicated is 80mph), but after a long journey it strangely gets more accuate. Had 2 GPS units in the car at once (one normal bluetooth one with a PDA, the other a GPS performance meter taking 10 samples a second) to double check it and it definatly gets more accurate (will land up overreading by 1~2mph at 30mph).
Smooth
PostPosted: 12:51 - 25 Feb 2009    Post subject: Reply with quote
Yes, it has a clock, which is what I mostly use mine for.
sagalout
PostPosted: 13:09 - 25 Feb 2009    Post subject: Reply with quote
When we did a day at Bruntingthorpe, the datalogger said 165.5 mph, the tomtom GPS said 165mph and the clocks read 185mph lol.
Most bikes I've had have been about 10% out.
Current Bike: Triumph Speed Triple T309
Previous: CBR600F => ZX9R => Triumph Tiger => Honda Blackbird => GSXR 750 => Versys =>ZX12R
TimNorwich
PostPosted: 13:32 - 25 Feb 2009    Post subject: Reply with quote
I think lower down speedo's are accurate, not so much the higher the speed.
binge
Emo Kiddy
PostPosted: 14:25 - 25 Feb 2009    Post subject: Reply with quote
davthegreat wrote:
hi
20" 1596
22" 1759
24" 1916
26" (650A) 2073
27" (700x32C) 2155
28" (700B) 2237
That is just a guideline in the instruction manual. It says.
For 20" wheels, use 1596. Etc.
That 1596 is the circumference of the tyre in mm.
You can work this out by doing 12" (or whatever size your wheels are), into mm. Plus the side wall height timed by two.
Then convert the diameter of the wheel into circumstance.
OR, you could do what I did. Mark the wheel and the floor with some chalk. Then roll the bike forwards until the front wheel has done 1 complete rotation. And mark the floor again where the chalk on the tyre is.
Then measure the gap between the chalk marks with a tape measure.
The Circumference of my front wheel is something like 1452mm. Thats on a 12" pit bike wheel.
So the bicycle speedos do go small enough. You just have to do the math yourself.
Ben
T0MMY
PostPosted: 19:27 - 25 Feb 2009    Post subject: Reply with quote
binge wrote:
The diameter of my front wheel is something like 1452mm. Thats on a 12" pit bike wheel.
I think you mean the circumference unless you're riding one of these Laughing Laughing :-
https://4.bp.blogspot.com/_KQlh6G_ERA8/SWryZKOzO2I/AAAAAAAABvw/sJI3Q1593xs/s400/penny.farthing1.jpg
Sorry, any excuse to post a picture of a penny farthing Very Happy
ZX6R + CBR600RR
davthegreat
PostPosted: 19:58 - 25 Feb 2009    Post subject: Reply with quote
thanks binge youve cleared it for me, i think ill do your idea of the full rotation of the wheel mines a 17inch so if yours works with a 12" itll defo work with a 17" thanks for your help
The last post was made 17 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 110.65 Kb
