Can I use a bigger tyre?
LanaTheGreat
PostPosted: 00:40 - 24 Feb 2009    Post subject: Can I use a bigger tyre? Reply with quote
My wife's Yamaha DT175's tyres need to be replaced. The tyre sizes are as follows:
Front: 3.00-21
Rear: 4.10-18
My Yamaha XT350 tyre sizes are as follows:
Front: 3.00-21
Rear: 4.60-18
Seeing that the front tyres are the same size on the two bikes, is it possible that I can use the bigger 4.60-18 tyre that is on the XT350 on the DT175?
PostPosted: 00:48 - 24 Feb 2009    Post subject: Re: Can I use a bigger tyre? Reply with quote
I reckon half an inch should be fine as 10mm up is generally ok.
Trail tyres seem to be more adaptable.
I've had a 4" trials tyre on both my LC4 and EXC (former has a 140 tyre as standard, latter a 110) and it's been fine.
lonner
PostPosted: 08:48 - 24 Feb 2009    Post subject: Reply with quote
hi m8
as above should be fine on a trail bike.
would not recommend on a road bike though as over sizing messes up the handling characteristics.
Blue_SV650S
PostPosted: 10:01 - 24 Feb 2009    Post subject: Reply with quote
The question is why?
If you are buying a new tyre, why not buy the one intended for the bike? The smaller tyre will prolly be cheaper too Wink
Or are you intending to put one of your cast-offs on it? If so, I'd have no qualms about fitting the 4.60! Thumbs Up
iooi
PostPosted: 12:38 - 24 Feb 2009    Post subject: Reply with quote
If its a spare you have give it a try.
Only issue would be it catching on the swinging arm or something else, due to the increased size.
LanaTheGreat
PostPosted: 21:35 - 24 Feb 2009    Post subject: Reply with quote
Thanks for all your replies. I am not going to use a cast off, my wife has an inferiority complex because her tyre is thinner than mine, and says it looks like a Marie biscuit. I am going to replace my tyre anyway, so I will put it over at some stage when I feel like it to see if it will fit. Her tyre is still okay for the time being though.
The last post was made 17 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 46.91 Kb
