Need suggestions for trouble shooting my motorcycle engine
 Topic moved: from to The Workshop by G (16 May 2004 - 09:13)
jpeter
PostPosted: 03:01 - 16 May 2004    Post subject: Need suggestions for trouble shooting my motorcycle engine Reply with quote
Can't start my 83 nighthawk 550. Trouble began when she would fail to rev past 5000 rpm. It would shut off like I had hit the switch. Let the rpm drop to 4500 and the engine would kick back in and run normally. It got worse until it quit on me entirely. I shot gas into the air intake thinking if it would fire on a direct shot gas the trouble would be fuel related. It wouldn't fire. Hooking up a spark plug outboard shows a faint spark but not strong enough to fire off my clamp-on timing light. Should the light blink, which it did a time or two, a cylinder or two will fire. I changed out the cdi unit with a used one which I have the option to return. No improvement. Whats next? Any suggestions for testing the pickup? Any Ideas at all would help a lot. Crying or Very sad
I so miss my little Nighthawk.
Jim
Robby
Dirty Old Man
PostPosted: 09:24 - 16 May 2004    Post subject: Reply with quote
Get the coils tested, they could be knackered. If they are ok, get a new HT lead and spark plug.
PostPosted: 11:29 - 16 May 2004    Post subject: Reply with quote
I would be inclined to say the coils as well, but also worth just putting some new plugs in there. It is not that likely to spark at all if the cdi unit is gone
jpeter
PostPosted: 02:35 - 17 May 2004    Post subject: Still won't go. Reply with quote
First thing I did was replace the plugs. I would be surprised if both coils went together. Its got two pickup coils for timing. I doubt if both of those would go together. I outta check the thing that pulses those coils though. Anybody know how that works?
Jim
mchaggis
PostPosted: 01:31 - 18 May 2004    Post subject: Reply with quote
https://www.dansmc.com/MC_repaircourse.htm
This site should be able to help. More specifically,
https://www.dansmc.com/troubleshooting2.htm
The last post was made 21 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 16 - Page Size: 43.69 Kb
