Re-jetting and Re-mapping
rac3r
PostPosted: 15:21 - 25 Feb 2009    Post subject: Re-jetting and Re-mapping Reply with quote
Bikes need to be re-jetted/mapped when you fit a full exhaust or air filter right? so how does this work with cars because most people don't have the ecu re-mapped when they fit an exhaust/performance air filter. Just curious really Neutral
On a side note if you fit ONLY a new air filter to a bike without any other mods does it still need to be re-jetted/mapped?
Chequered Flag
chrisw
PostPosted: 15:52 - 25 Feb 2009    Post subject: Re: Re-jetting and Re-mapping Reply with quote
Just because they don't doesn't mean that they shouldn't.
You can get away with it on injection because most (if not all) have a percentage of change over their base map which is usually enough to keep the fueling in line after the changes.
Carbs don't have this, they can't change the shape of their needle or jet (the equivilant of the base map in the injection system).
Someone may want to correct me, but most bike carbs are of the variable venturi type, so don't actually get re-jetted, they just require a different profiled needle to change their fueling.
NSR Mick
PostPosted: 16:03 - 25 Feb 2009    Post subject: Reply with quote
Cars are easier to get away with as theres usually 3 sensors that control the fueling. Airflow Meter (MAF), knock sensors and Lambda sensors which will allow the ecu to alter the fueling / timing according to the results it is fed from them.
Bikes I think run a predetermined map according to revs and throttle opening.
Although I may be wrong. Laughing
stevo as b4
PostPosted: 00:11 - 26 Feb 2009    Post subject: Reply with quote
Yeah car maps are more adaptive than bike injection/ignition ECU maps generally. They also use more sensors and have to run over a wider range of variables normally. Few injected bikes have knock sensing AFAIK, but quite alot of cars do, and some allow the ignition timing to be advanced a fair bit if you use a high RON fuel, which can give more power and better throttle response.
Their are limits to how much extra airflow a car's ECU can cope and allow extra fuelling for, but normally any bolt on exhaust and induction changes are no problem. Higher lift and longer duration Cams can cause a poor idle and low down throttle response on engines with Plennum based fuel injection, where as you tend to get far better idling and low speed response with Individual throttle bodies, which is the norm on most multi cylinder bike engines.
The last post was made 17 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 41.16 Kb
