Rear brake torque arm bent
Cigaro
PostPosted: 19:31 - 25 Feb 2009    Post subject: Rear brake torque arm bent Reply with quote
I have just noticed that my rear brake torque arm is bent in the middle, towards the tyre. it leaves less than 1cm clearance between the side of the torque arm and the sidewall of the tyre.
I don't know if it's always been like this but I'm sure it hasn't.
What could have caused it? Is my chain overadjusted? Is it just meant to be like that? (I'm assuming not.)
hmmmnz
PostPosted: 19:49 - 25 Feb 2009    Post subject: Reply with quote
what bike are we talking about?? i gather its not the el250 as thats got a drum on the back
the humans are dead
I kick arse for the lord
PostPosted: 20:14 - 25 Feb 2009    Post subject: Reply with quote
Still needs something to attach the drum to the bike, or else it would just spin.
My RX-S has a torque arm and that has a rear drum.
lonner
PostPosted: 20:56 - 25 Feb 2009    Post subject: Reply with quote
is it a kink or any paint chipped which would suggest impact Question
would it just pull back into shape Smile
Saul Good
PostPosted: 23:00 - 25 Feb 2009    Post subject: Reply with quote
sounds like your wheel alignment is out.
Did you kick the back wheel when you were adjusting the wheel alignment as this can bend the arm on the wee bikes.
bikes with rear drums still have a torque arm
hmmmnz
PostPosted: 01:54 - 26 Feb 2009    Post subject: Reply with quote
arhh i see both my drum brake bikes have a notch in the drum and locating pin on the swing arm.
but pics show that the el250 has a torque arm.
and it being on the bottom, i cant see any reason it would bend
as i would be pulling against the arm.
the humans are dead
PostPosted: 02:02 - 26 Feb 2009    Post subject: Reply with quote
Flip it through 180 degrees so it bends back again?
Cigaro
PostPosted: 09:39 - 26 Feb 2009    Post subject: Reply with quote
Should do yeah, but would be nice to find out why it's gone like that in the first place.
Wheel alignment doesn't SEEM out, and it certainly seems to ride OK. Surely if it was out sufficiently to bend things, I'd notice something?
It's basically bowed in the middle. Imagine if you take a long flat piece of metal, fix one end to something and then push the other end - push hard enough and it will bend one way or another.
Should I just bend it back and keep riding?
lonner
PostPosted: 16:09 - 26 Feb 2009    Post subject: Reply with quote
well that's what id do Thumbs Up
the only thing i can think of is you have brake ed hard while going backwards and this has forced the arm to flex if that sounds feasible
The last post was made 17 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 61.69 Kb
