oil and break fluid
mapex
PostPosted: 20:01 - 25 Feb 2009    Post subject: oil and break fluid Reply with quote
When buying oil for my Bandit 600......it was serviced at the dealers
when i bought it, say they used synthetic oil i put in non synthetic
or vice versa would it be ok. also is car and bike breakfluid the same or
are they different............
mark
www.soundclick.com/foursticks
Itchy
PostPosted: 20:10 - 25 Feb 2009    Post subject: Reply with quote
You can mix and match oil , I use semi syth 10w-40 or is it 10-40w one of those combos.
brake fluid you should not mix and match every bike I've owned uses dot 4 brake fluid some of them are incompatible best keep the same type.
PostPosted: 20:16 - 25 Feb 2009    Post subject: Reply with quote
Car and bike brake fluid are the same thing. Chances are it is DOT 3, DOT 4 or DOT 5.1 fluid you need (the higher the number refers to a higher standard with a higher boiling point). They can be mixed.
Do not use DOT 5 fluid unless specifically required (think only some Harleys use it). While it will work it does not mix with the other fluids and your seals may not be compatible with it.
mapex
PostPosted: 08:19 - 26 Feb 2009    Post subject: Reply with quote
thanks for that
MARK
veze
PostPosted: 19:37 - 26 Feb 2009    Post subject: Reply with quote
semi syth should be fine, my dad runs his xjr1300 on semi syth, he finds that fully syth makes the clutch slip. or was it the other way round? i imagine im right.
but yeah go with the semi syth dude Thumbs Up
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
The last post was made 17 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 45.43 Kb
