Hard/stiff suspension
swiftb
PostPosted: 20:35 - 25 Feb 2009    Post subject: Hard/stiff suspension Reply with quote
Hi all, im looking for some advice on my suspension setup if anyone can help. Bikes a 2000 zx6r. The main problem is I bought the bike from a large guy, prob 16+ stone. Im 11.5 stone. Ive found the bike is extemely hard and is literally throwing me out the seat to the extent where is seriously dangerous!
So far ive softened front preload, compression&damping, and softened rear compresion and damping. It has helped to soften the overall ride and the bike doesnt try and spit me off as much, however its still a little erratic and the rear in particular seems too hard.
Will adjusting the rear preload soften the ride at all? My only worry is, is that I dont think the rear spring is standard. Its yellow so i suspect its been uprgraded, possibly for a stiffer one. Most zx6rs ive seen have a black rear spring.
Is it worth messing witht the preload or should i just replace the rear spring with oe to eliminate the possiblitly that the rear spring has been swapped out for a stiffer one??
Any comments appreciated, cheers
lonner
PostPosted: 20:46 - 25 Feb 2009    Post subject: Reply with quote
hi
if you can achieve a static sag of about 10-15 mm by backing of the preload it should help .
but if its a heavier spring you might struggle.
would back of the comp more as this will soften the ride.
the rebound may need a bit less too hth
PostPosted: 22:49 - 25 Feb 2009    Post subject: Reply with quote
www.marjay.co.uk/setup.pdf
download it, read it, digest it and use it.
Reppyboyo
PostPosted: 22:52 - 25 Feb 2009    Post subject: Reply with quote
Alternatively get it set up by a local suspension specialist.
swiftb
PostPosted: 12:49 - 26 Feb 2009    Post subject: Reply with quote
spot on, cheers people, thats particularly useful Marjay
The last post was made 17 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 42.95 Kb
