I've had enough... blown engine
ripzay
PostPosted: 11:45 - 26 Feb 2009    Post subject: I've had enough... blown engine Reply with quote
Hi guys...
so... i've blown my engine up. (1994 Suzuki GSX-R 400 GK76A)
The bike dropped out of gear at speed and jumped up past 16000rpm before i had time to react.
cue horrible snap noise and then tapping coming from the engine.
no smoke from the exhaust so i dont think it is bottom end.
It's deffinitely on cyl 3 (when i cranked the engine over this cylinder remained cold, so the fuel isnt being burnt, or isnt being burnt properly.
So i need some advice.. i'll be taking the bike apart tonight - just wondering if there's anything i need to know about removing my engine, anything that i am likely to forget about and will have to do..
i'm hoping i've just killed or spat a spark plug, but i don't think that this is the case.
next i'm hoping its just a snapped valve that hasnt been mashed into the piston too much..
but worst case scenario.... i need to buy:
piston
valves
valve springs
etc.
now, my question is, where will i buy these from if i do need them ?
and how much should i expect to spend.
also.. does anyone have a head off a running bike for sale ?
Thanks.
Ben
Current: 2005 KTM SuperDuke 990
Previous: 1996 Suzuki Bandit 600
Previous: 1994 Suzuki GSX-R 400
PostPosted: 12:02 - 26 Feb 2009    Post subject: Reply with quote
Not being a UK model spares might be a bit hard to get hold of.
Personal guess would be that you are in the right area thinking of a valve issue. I would say take the rocker cover off and check the valve clearances. Also check none of the rockers have snapped. It is possible that a valve has clipped the piston, bent and now isn't closing properly, or that it has just spat a shim out (leaving you with a massive clearance on that cylinder), or even snapped a rocker arm (neighbour managed that in their car trying to change from 2nd to 3rd gear at high revs and instead getting 1st). If you are lucky it will be an easy fix (eg, shim is there undamaged and can be put back in).
Barry_M2
PostPosted: 12:03 - 26 Feb 2009    Post subject: Reply with quote
If it's still turning over, it could just be a cam follower thats snapped.
Or, worst case is that you've lost a valve and it's mashed into the piston and the head. Sad
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
ripzay
PostPosted: 12:09 - 26 Feb 2009    Post subject: Reply with quote
still turns over and runs (fires on 3 cylinders - started it to diagnose, was running for like 5 secs before i hit the kill switch), but has a tapping from the top end and a bit of white smoke from the exhaust (unburnt fuel)
the bike wasnt shaking violently while it was running for those 5 seconds, just making a loud tapping, like as if the valve clearance was way out.
i'm thinking snapped rocker (or threaded adjuster on rocker) - i'm not sure if this bike is shims.. i've never had the head off or even seen inside one, earlier models didnt have shims afaik, they had screw adjustment on the end of the rockers.
we'll see tonight when i get the rocker covers / head off
Barry_M2
PostPosted: 14:45 - 26 Feb 2009    Post subject: Reply with quote
I snapped a rocker on an old ZXR400 I had (about 12 years ago now) and it still ran on 3 ok. I even rode it home about a mile or so as I didn't want to push it! Laughing
Fingers crossed thats all it is.
PostPosted: 08:22 - 27 Feb 2009    Post subject: Reply with quote
If it's dropped a valve head and battered the piston crown you're going to need to pull the big-end cap off and check the rod bearings for signs of contact with the crank journal.
ripzay
PostPosted: 13:57 - 27 Feb 2009    Post subject: Reply with quote
Well, i got the engine out last night... and it's bad.
the cause of the destruction was a snapped cam follower, which has then fallen down the valve into the engine and bounced around a bit atop the piston.
the results are:
1) Snapped Cam Follower
2) Bent Valve
3) Mashed spark plug
4) Mashed piston (i guess, havent taken the head off yet)
5) Lots of bits of ground metal in the intake, and probably in the cylinder.
6) Scratched / pitted cylinder bore.
I've managed to find a guy with an engine i can have for £350, which has done 10000km, (25000 less than my engine) and i'm going to pick that up tomorrow.
The dead engine, i'm going to keep and build a race engine out of it, there are kits available to make this engine 440cc, so as money allows, i will be doing this as a little spare-time project.
Gutted. Sad
Some pictures:
https://www.binary-pulse.co.uk/Random/Bike/Pics/Damage_Remains.jpg
Bits of metal...
https://www.binary-pulse.co.uk/Random/Bike/Pics/Damage_SparkPlug.jpg
Remains of Spark Plug
https://www.binary-pulse.co.uk/Random/Bike/Pics/Damage_Garage.jpg
No Comment - my landlord would kill me Very Happy
PostPosted: 14:02 - 27 Feb 2009    Post subject: Reply with quote
Nice wellies.
ripzay
PostPosted: 14:07 - 27 Feb 2009    Post subject: Reply with quote
The Shaggy D.A. wrote:
Nice wellies.
ex-gf's, she still needs to come get the rest of her stuff.. they = size 5, me = size 12 Wink
PostPosted: 15:33 - 27 Feb 2009    Post subject: Reply with quote
Err, that cannot happen short of the engine somehow managing to punch the valve follower through the head (very unlikely). The follower might have managed to drop down the cam chain tunnel and into the sump though.
All th best
Barry_M2
PostPosted: 16:08 - 27 Feb 2009    Post subject: Reply with quote
Quite right Keith, cant believe I didnt' spot that either!!
What's likely is that the follower snapped, got jamed between the cam lobe and top of the valve, which held the valve open while the piston came up and smashed into it. The only thing that can fall into the cylinder is the head of the valves and spart plug tip.
PostPosted: 16:22 - 27 Feb 2009    Post subject: Reply with quote
Funny but both of those wellies look like they could hold the old oil from the engine. I always have trouble find stuff to put used oil into...
ripzay
PostPosted: 17:58 - 27 Feb 2009    Post subject: Reply with quote
good point r.e. the cam follower.. but yeah, i didnt find it in the head so i guess its in the sump..
i found the valve retainer, spring and the shim in the head.
I'll take more pictures after i've got my new engine in.
the old one is being put on the table in the kitchen, drained and stripped.
Barry_M2
PostPosted: 18:16 - 27 Feb 2009    Post subject: Reply with quote
I would have my bollox removed and fed to me for dinner if I even considered doing such a thing! You lucky sod!
ripzay
PostPosted: 18:19 - 27 Feb 2009    Post subject: Reply with quote
split up with gf on monday, she moved out.. so nobody to complain..
i paid the rent when she lived here anyway.. ripzay rules the roost Wink
PostPosted: 18:24 - 27 Feb 2009    Post subject: Reply with quote
By the way, as you blew this engine from over revving it, was the rev limiter mod in your sig a good idea? Razz .
Finglonga
PostPosted: 19:48 - 27 Feb 2009    Post subject: Reply with quote
Shocked Mr. Green Thumbs Up
Andy Sez....
F.Y.Y.F.F.
ripzay
PostPosted: 21:49 - 01 Mar 2009    Post subject: Reply with quote
well.. i found these little presents in my exhaust manifold:
https://www.binary-pulse.co.uk/Random/Bike/Pics/Damage_%20Remains%201.jpg
https://www.binary-pulse.co.uk/Random/Bike/Pics/Damage_Remains%203.jpg
2/3rds of the end of a valve.
1/3rd of a valve seat, and various other chunks of chewed up metal..
still not got the head off the old engine but i've got my new engine in, so that's the next job!
r.e. the rev limit mod.. that appeared to have failed.. it was only supposed to raise it, not remove it :p
ripzay
PostPosted: 10:31 - 12 Mar 2009    Post subject: Reply with quote
Please excuse my ugly lino and ugly wallpaper, i cant be bothered to decorate yet....
but...
Cams out...
https://www.binary-pulse.co.uk/Random/Bike/Pics/FubardEngine/IMG_2328.JPG
Cams...
https://www.binary-pulse.co.uk/Random/Bike/Pics/FubardEngine/IMG_2329.JPG
Head & Barrels Off....
https://www.binary-pulse.co.uk/Random/Bike/Pics/FubardEngine/IMG_2330.JPG
MUNCHED PISTON!
https://www.binary-pulse.co.uk/Random/Bike/Pics/FubardEngine/IMG_2332.JPG
MUNCHED PISTON.. from another angle...
https://www.binary-pulse.co.uk/Random/Bike/Pics/FubardEngine/IMG_2333.JPG
Down The barrel & valves.
https://www.binary-pulse.co.uk/Random/Bike/Pics/FubardEngine/IMG_2335.JPG
I think its fair to say that that head and piston is now worth nothing more than its weight in... cast aluminium ;p
Barry_M2
PostPosted: 10:40 - 12 Mar 2009    Post subject: Reply with quote
I have a piston just like that from when I brought my ZXR. It now sits on a shelf in my room as decoration! Laughing
https://i7.photobucket.com/albums/y269/Barry_mc21/ZXR750M%202006/DSC00052.jpg
https://i7.photobucket.com/albums/y269/Barry_mc21/ZXR750M%202006/DSC00049.jpg
stevo as b4
PostPosted: 11:48 - 12 Mar 2009    Post subject: Reply with quote
That explains the reason why it was smoking alot and running on 3cyls!
Definately put a std cdi box back on for your next engine!
ripzay
PostPosted: 11:29 - 13 Mar 2009    Post subject: Reply with quote
:o..
do i know you irl ? *confused*
The last post was made 17 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 133.84 Kb
