Swarf in the oil
T0MMY
PostPosted: 11:29 - 28 Feb 2009    Post subject: Swarf in the oil Reply with quote
Just gave the bike a service and was a little concerned to find swarf in the oil. Is ANY swarf bad and is my engine fecked or is a little bit ok Confused
ZX6R + CBR600RR
Knacker
PostPosted: 11:30 - 28 Feb 2009    Post subject: Reply with quote
What the funk is swarf ?
If your talking about Stuff that looks like salad creme its just emulsified oil and a good 50 mile run will clear that out Thumbs Up
Previous: K1 GSXR 1000
PostPosted: 11:36 - 28 Feb 2009    Post subject: Reply with quote
This the CBR?
You mean metal swarf yeah? Big bits or dusty bits floating on top of the oil? Alloy or steel (do they stick to a magnet)?
In my experience metal filings in the oil have often come from the clutch area. It would be my first thing to check if you are worried.
T0MMY
PostPosted: 11:40 - 28 Feb 2009    Post subject: Reply with quote
Fairly big bits, have to check with a magnet later.
The clutch basket(?) rattles a bit so maybe this is the source?
ZX6R + CBR600RR
https://www.ghettowebmaster.com/images/google-mother-fucker.jpg
SWARF
https://www.2recycling.com/assets/images/swarf_1.gif
PostPosted: 11:44 - 28 Feb 2009    Post subject: Reply with quote
Worth a look. If it is loose, it might be touching the casing occasionally and shaving a lump off. Of they can apprently knock lumps off the clutch basket on occasion.
If it were me, I'd check that and assuming it is the clutch, fix the problem then do a couple of short interval oil and filter changes using cheap oil to flush out any particles of crap. If the bits are magnetic, I'd fit a magnetic sump plug or stick an old speaker magnet to the oil filter cartrige, or both.
hellkat
PostPosted: 11:45 - 28 Feb 2009    Post subject: Reply with quote
I thought swarf was, like, bits of stuff, grit or whatever?
hellkat
PostPosted: 11:47 - 28 Feb 2009    Post subject: Reply with quote
Ah, but I see that the wondrous Stinkwheel has explained whilst I have been gossiping about torque with Summercamp/Doro.
Thought thats what it was. I kind of meant that, too. But that photo of the curly things is a good description (or is that Samuel L Jackson's hair?)
Serves me right for having too many windows open Smile
yen_powell
PostPosted: 11:57 - 28 Feb 2009    Post subject: Re: Swarf in the oil Reply with quote
Small bits of metal are okay, I mean very small, not big threaded lumps of steel or bits of gearwheel.
XT1200Z and a DR350 in bits
ThoughtContro...
PostPosted: 12:15 - 28 Feb 2009    Post subject: Reply with quote
Go operate a lathe or milling machine for 5 minutes. The bits of metal crap you've got lying around the job are swarf.
I thought you were an engineering student? Or am I confusing Matts?
doggone
PostPosted: 14:21 - 28 Feb 2009    Post subject: Reply with quote
It's not impossible suchlike stuff has been in there for ages and just recently dislodged & circulated around to the filter or bottom of the sump.
Unless there's identifiable bits like bearing parts I wouldn't be unduly worried.
Finglonga
PostPosted: 14:23 - 28 Feb 2009    Post subject: Reply with quote
Can't believe folks don't know what swarf is. Shocked
Don't rely 100% on the magnet then as most are alloy! Personally I would be concerned as there shouldn't be any in there. What was the inside of the oil filter like.
Andy Sez....
F.Y.Y.F.F.
MaybeGuy
PostPosted: 14:34 - 28 Feb 2009    Post subject: Reply with quote
yes, you're confusing matts... thankfully i know what swarf is.
PostPosted: 14:51 - 28 Feb 2009    Post subject: Reply with quote
What colour is the swarf? If it's anything but shiney then that's bad. If it's bronzey colours (I don't mean oil-staining) then that's bad. If it's like little tiny grey biscuit-crumbs - bad again.
If it's little tiny silver flakes or curls then it's probably left over from the manufacturing process. Not so bad but they shouldn't be there.
Best thing as always is to post a pic.
hellkat
PostPosted: 15:24 - 28 Feb 2009    Post subject: Reply with quote
Specially when EVEN I KNOW what it is Laughing
But then again ... ya got to ask, even if it makes you look a bit dumb.
Else you'll never know.
Finglonga
PostPosted: 16:35 - 28 Feb 2009    Post subject: Reply with quote
Probably just me showing my age. Whistle Mr. Green
Andy Sez....
F.Y.Y.F.F.
Knacker
PostPosted: 16:48 - 28 Feb 2009    Post subject: Reply with quote
Nope im not an engineer and i do apologise for my lack of knoledge-ness Laughing
PostPosted: 18:34 - 28 Feb 2009    Post subject: Reply with quote
And spelling Very Happy
T0MMY
PostPosted: 20:39 - 28 Feb 2009    Post subject: Reply with quote
I suppose somewhere between tiny silver flakes and little tiny grey bisuit crumbs Confused Bit worrying as the engine vibrates a lot for a CBR6 and I was previously concerned about crankshaft bearing damage being the cause but several mechanics have listened to it and said there's nothing wrong Confused
ZX6R + CBR600RR
PostPosted: 21:31 - 28 Feb 2009    Post subject: Reply with quote
Crank bearing damage would give little golden-bronze specks in the oil or 'silver paint' floating on the surface. Have you checked behind the clutch cover to see if there are bits missing off the basket?
T0MMY
PostPosted: 00:18 - 01 Mar 2009    Post subject: Reply with quote
No not yet Thinking Quick flick through the Haynes manual makes it look pretty simple though. Not sure this could cause the vibration though (other than the rumbling felt with the clutch out)?
ZX6R + CBR600RR
Billy Balthorpe
PostPosted: 10:27 - 01 Mar 2009    Post subject: Reply with quote
How old is the bike? How many miles has it done? If its new, it could be your engine knocking all the lumps off itself left over from manufacturing, but i would only expect this after the 1st 1000 miles or so.
Rumbling from the clutch when ticking over that dissapears when the clutch is pulled in is either the basket or the bearing, alloy swarf is usually the basket, steel is usually the bearing.
Visible swarf in the oil after the first 1000 miles is never a good sign.
M.O.B. Successfully taking the piss since 2014.
T0MMY
PostPosted: 10:43 - 01 Mar 2009    Post subject: Reply with quote
The bike is only 3 years away from being old enough to ride a moped and has done 32,000 miles. No spring chicken but not astronomical, but their is a lot of engine vibration which I have been unable to find the cause for.
ZX6R + CBR600RR
ratboy
PostPosted: 16:03 - 01 Mar 2009    Post subject: Reply with quote
Probably best to change the oil and filters. Use a flushing oil like Asda own brand to clear out any swarf still in, then keep checking it for any new stuff. If there's none in then it could hopefully be remnants from previous damage or even bedding in which have been sat. Either way it needs clearing out so it doesn't block oil-ways.
Billy Balthorpe
PostPosted: 17:21 - 01 Mar 2009    Post subject: Reply with quote
I've used Diesel as flushing oil before. The only problem was that the oil was so clean after i did it you couldnt see the level on the dipstick.
The last post was made 17 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 129.53 Kb
