| Gazdaman |
 Gazdaman I did a trackday!!!
| Gazdaman |
| fra-zzr |
 fra-zzr Spanner Monkey
 Posted: 18:08 - 01 Mar 2009 Post subject: |
is there a front caliper?  ____________________ 04' Hyosung Comet Gt125
96' zzr600 |
| Gazdaman |
| KLR600 |
 KLR600 World Chat Champion
 Posted: 23:56 - 01 Mar 2009 Post subject: |
This will sound mad but I have been wondering about something for about 10 years now and I just need to figure some stuff out.
If you're taking the engine out is there any way you could weigh the bike sans engine? No worries if not. Just the running gear like frame, forks, wheels, bars and brakes. Don't need to know how much it weighs with plastics and the tank on and stuff, maybe without the suframe aswell.
I used to be able to bunnyhop my old DT125 with a full tank of petrol so I'm wondering how heavy a crosser would be without all the engine bits.
Looks like a good project, keep us posted! ____________________ Now: '00 Kawasaki ZRX1100R - Past: '84 Yamaha DT125, '89 Kawasaki KLR600, '97 Yamaha XJ600N
<Take Cool Photos!> |
| Gazdaman |
 Posted: 20:50 - 02 Mar 2009 Post subject: |
What a weird request. If I get the engine out and the bike magically falls onto a set of scales then sure, I'll look at the reading and note it down.
Other than that, I wouldn't hold my breath mate
I would have thought it'd be about 60-70kg? Maybe less I suppose.
Gaz |
| OssY |
 OssY Nearly there...
| Gazdaman |
| Gazdaman |
 Posted: 17:26 - 31 Mar 2009 Post subject: |
Doris passed its MOT today
Gave me a chance to work on the KX too. According to the timestamps on the camera, it took me 54 minutes to go from this:
https://www.gaz-racing.co.uk/images/vehicle_514.JPG
To:
https://www.gaz-racing.co.uk/images/vehicle_520.JPG
That's seat and tank off, exhaust off, carb off, swingarm off (the pivot is an engine mount), drain coolant, engine out.
The powder coated frame is just a joy to work with. Everything's so clean.
Also found where I think the gearbox oil is going. The previous owner said he thought it crank oil seals. But in fact I think it's leaking where the crank cases join together. Never mind, I'll strip it down and rebuild it anyway.
I love projects!
I think it needs a new exhaust really too, this one is battered to fuck. And has been welded several times already.
https://www.gaz-racing.co.uk/images/vehicle_518.JPG
Gaz |
| BenR |
 BenR World Chat Champion
| Gazdaman |
| freko |
 freko L Plate Warrior
 Posted: 15:30 - 09 Apr 2009 Post subject: |
I'm working on the same bike(though -88). My engine got totally trashed when it cut. The piston broke into pieces, that fell down into the crankshaft...
I'm going to open it up tomorrow and check the damage, but it doesn't look good...
I have some pics here if you are interested, https://www.bikepics.com/members/freko/88kx125/ ____________________ You do what you can, I do what I wan't. |
| Gazdaman |
| freko |
| Gazdaman |
| Gazdaman |
 Posted: 19:21 - 18 Apr 2009 Post subject: |
Had a small go at it today:
https://www.gaz-racing.co.uk/images/vehicle_541.JPG
Turns out there's about 1mm of sideways play (each way) in the con-rod.
So what do I need to replace? Just the big end bearing? Or the cod-rod et al? A kit is about £40, which I suppose isn't too bad.
But I'm guessing I have have the crank split and pressed back together.
Gaz |
| BenR |
 Posted: 19:33 - 18 Apr 2009 Post subject: |
Movement side to side should be there, it's if you have movement up & down that you have a problem?  ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
| Gazdaman |
| element |
 element World Chat Champion
 Posted: 20:04 - 18 Apr 2009 Post subject: |
1mm side to side is fine.. theres meant to be a tiny bit of play.. its up and down play that means a crank rebuild so all is good  ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| Gazdaman |
| Gazdaman |
| Welshd1k |
 Welshd1k World Chat Champion
 Posted: 19:56 - 19 Apr 2009 Post subject: |
loving the chav mobile  ____________________ Current >Cb600fx hornet, ns125rk90 21.7bhp@wheel<
Sold >,zxr400 h2 (33bhp kit) rd350 n1 rd350 lc2< |
| Gazdaman |
 Posted: 20:00 - 19 Apr 2009 Post subject: |
| Welshd1k |
| Gazdaman |
The last post was made 17 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
