CBR600 Headgasket blown?
MattBlackPaul
PostPosted: 19:32 - 03 Mar 2009    Post subject: CBR600 Headgasket blown? Reply with quote
Hello
Before i started to strip and rebuild the CBR600. i had noticed the oil was milky brown.. does this 100% mean the headgasket has blown? ive done a few water seal checks they are ok... is it the headgasket or is there another problem it could be, as i dont know about Hondas other then how to ride one...
Bikeless
PostPosted: 19:40 - 03 Mar 2009    Post subject: Reply with quote
You need to find a garage that can do the sniff test to clarify it and/or if it is losing coolant with no obvious leaks.
puremagic72
PostPosted: 19:34 - 04 Mar 2009    Post subject: Reply with quote
How many miles has it done?
Mines like it, its just the weather.
Baz. Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
Noxious89123
PostPosted: 21:47 - 05 Mar 2009    Post subject: Reply with quote
+1, you get a little water in the oil from condensation inside the crankcase.
MattBlackPaul
PostPosted: 20:19 - 10 Mar 2009    Post subject: Reply with quote
thanks for your replys...
it had been snowing hard and very cold when engine was turned off... i looked at what was coming from the pipe when it was on tick over and watched though the rev range.. normal i know on a turbo car when the head gasket blows there water or steam coming out of the pipe and misfires... as there no misfiring and no water coming from pipe... i would suspect weather.. but as i was not sure about the bike i had to ask..
im about to buy some cheap oil and run it for a whiles on tick over and up the rev range a little.. is this a good enough test as the oil has been drain and left with plug off,, ill open casing and clean any old oil out i see inside..
Thanks again Smile
The last post was made 17 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 43.72 Kb
