Gyroscopic effect
Shaun
Likes 'em bent
PostPosted: 18:09 - 17 May 2004    Post subject: Gyroscopic effect Reply with quote
I've read a couple of wheelie guides recently and they both said that if you hit the front brake whilst doing a wheelie it has an interesting gyroscopic effect. Is it really that interesting since neither of them mentioned or explained any more of what this effect is and whether it is dangerous or not, anyone care to explain? Thinking
I hope I'm not being really stupid and they just mean the wheel will stop turning.
Smoto Bob
PostPosted: 18:16 - 17 May 2004    Post subject: effect Reply with quote
i have no idea but..
Gyroscopic effect is from spinning, so whens its spinning it helps keep the bike balanced left-right. And you can use the steering as well for this.
If your doing a tail whip, you have to rev the engine to bring the back into line Wink same sort of thing.
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
Milo
PostPosted: 18:17 - 17 May 2004    Post subject: Reply with quote
With the front wheel spinning it will help you keep the bike on the strait and narrow, if you stop that force then it'll make wheelie's much less stable. I don't wheelie too much myself so can't say how much of a difference it makes, best to wait for one of the other guys/gals to post.
Ads
Shaft drives rule. Razz
DukeRed
I imagine you'd become unstable because the spinning of the front wheel even in the air gives stability.
Jan
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
mr jamez
PostPosted: 18:24 - 17 May 2004    Post subject: Reply with quote
Rally drivers use the gyroscopic effect to stop their cars from nose diving after a jump as well Very Happy
PostPosted: 19:09 - 17 May 2004    Post subject: Reply with quote
Right, firstly you can apparantly counter steer while on one wheel using the gyroscopic effect, it thus also helps to keep the bike straight.
I've never really noticed this, most of my wheelies are pretty slow, so I probably wouldn't notice it anyway even if I was good enough to.
also...
I know that in motocross stunts you can pull the throttle on to make the rear dip (I think). So presumably pulling the brake on could actually help the front to rise a bit?... obviously it's going to have to be going fairly fast in the first place.
Smoto Bob
PostPosted: 19:40 - 17 May 2004    Post subject: Reply with quote
G wrote:
..I know that in motocross stunts you can pull the throttle on to make the rear dip (I think). So presumably pulling the brake on could actually help the front to rise a bit...
If you rev when mid air its does get the back down a bit and braking brings it higher (as i rember Confused ). Dont do anything with the front brake cos it will hurt when you land on mud.
I would think that the front brake would lower the front though. Neutral
Korn
Admin
PostPosted: 20:53 - 17 May 2004    Post subject: Reply with quote
I don't completely understand the physics but I can tell you it's a bad idea. At one point one of the calipers on my VTR was binding, meaning that a second or two after clutching it up the front wheel would have stopped spinning, this made it really unstable and it was impossible to correct the bike's heading, not to mention the landings were very violent as the front wheel had to suddenly spin up from 0 to 60 odd mph in a fraction of a second. After a few hairy moments I figured out the problem and fixed it double quick time Shocked
Incidentally the gyroscopic effect of the front wheel is also why the faster you pull wheelies, the easier it is to adjust direction and actually make your wheelie go in a straight line.
3516 Miles, 11 Countries
old bob
PostPosted: 21:24 - 17 May 2004    Post subject: Reply with quote
Please unless you are very skilled and have supberb reactions do not try applying the front brake to the front wheel when off the ground.
The spinning front wheel exerts a strong force due to gyroscopic effects, the forces work at right angles (you can gauge the direction of a reaction by applying the corkscrew rule). Difficult to explain simple to feel with a small gyroscope. When you lift the front wheel with it spinning there is a fairly large force reacting which you naturally balance and compensate for, moving the steering changes the direction of the reaction and gives some feel of control.
The effect reduces as the wheel slows but you naturally compensate. Stop the wheel suddenly and you change the reaction effect rapidly and you won't have had time to adjust you will probably find the bike will react violently.
Apart from which if you touch down with a bit of brake applied you may find the resultant cartwheel over the bars a little embarrassing.
Danny
Ask Me About Stoppie School
PostPosted: 21:27 - 17 May 2004    Post subject: Reply with quote
...and painful. Shocked
hugo-a-gogo
PostPosted: 22:09 - 17 May 2004    Post subject: Reply with quote
talking bout 'crossers and rally cars using the engine to adjust position in mid-air, isn't that just torque reaction? view the car bike from the left - engine turns anti clockwise, car tries to turn clockwise, rear dips (assuming these rally cars have transverse engines)
"There are some things nobody needs in this world, and a bright-red, hunch-back, warp-speed 900cc cafe racer is one of them - but I want one anyway, and on some days I actually believe I need one. That is why they are dangerous."
Hunter S Thompson
clicky 4 bikey
Milo
PostPosted: 22:39 - 17 May 2004    Post subject: Reply with quote
If you spin the rear wheel up or stop it then then using the equals and opposite reaction theory then the bike must turn in the other direction - pitching the front up or down.
Shaun
Likes 'em bent
PostPosted: 23:20 - 17 May 2004    Post subject: Reply with quote
And now I know. Very Happy
Very good explanation bob, I now fully understand that its a terrible idea to do it! Thumbs Up
Adam_P
PostPosted: 09:43 - 18 May 2004    Post subject: Reply with quote
Watching the Motocross and indoor super cross stuff they all use the back brake while in the air to get the back end to come up a bit so they land in a better position.
I'd never thought about what the front would do though. But then, I'm not one for wheelies really (I have a hard enought time staying in control on two Laughing ) so I'll leave it to the talented people. Wink
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
The last post was made 22 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 83 Kb
