Help removing nylon locknuts from footpegs
Suitor_Stu
PostPosted: 20:01 - 05 Mar 2009    Post subject: Help removing nylon locknuts from footpegs Reply with quote
Quick question - My footpegs are held in place by nylon locknuts, but for whatever reason they don't actually engage the threads on the bolts anymore. They turn, but go nowhere. I need to remove the pegs to do some work on the primary chain, but short of just using a dremel to cut them off and just replacing the nuts and bolts I can't think of how to remove them. Anyone out there got any tricks o' the trade I should try?
Cheers, Stu
nowhere.elysium
The Pork Lord
PostPosted: 20:09 - 05 Mar 2009    Post subject: Reply with quote
They're definitely not on the thread? You're positive of that? Then whip out the mole grips, and just pull them off.
Leap of faith, no? Wink
If they're definitely not engaged with the thread anymore, then there won't be a problem. If, however, the thread is partially, well, threaded, then you risk causing damage to the bolts/footpeg mount.
You could try heating them, too, which may cause either the nylon to melt, or the metal of the nut to expand or relatively contract, which may engage/more cleanly disengage the thread.
Of course, your idea about using the dremel sounds distinctly easier, less risky and is the path that I'd most likely take.
PostPosted: 21:02 - 05 Mar 2009    Post subject: Reply with quote
They are fucked anyway. If the bolt is a standard size, cut them off and replace them. It will be quicker in the long run and you're going to have to buy new ones anyway.
If they are a special bolt, might be worth trying to split the nut and see if they are saveable.
I would be very suspicious of that being a non-standard footpeg fitting on an Enfield anyway. I'd have expected a plain nut and bolt with a spring washer so you keep having to stop every 50 miles and tighten them up again.
Suitor_Stu
PostPosted: 21:40 - 05 Mar 2009    Post subject: Reply with quote
Here's an image of the assembly (stolen from the Hitchcocks website) to give you an idea what I'm dealing with. The nuts (11) are attached to the bolt (14) which is encased in cylinders (21, 22, 23) under the bike.
https://www.hitchcocksmotorcycles.com/pictures/142145-03page138.gif
I must confess that the real reason I hope there is some cure is that I don't have anything other than a hacksaw to cut them off - I'm too broke to buy myself a dremel!
Cheers, Stu
PostPosted: 21:53 - 05 Mar 2009    Post subject: Reply with quote
A hacksaw would do it quicker than a dremmel.
You could almost certainly replace that with a bit of threaded bar, or two seperate bolts, one for each side.
yen_powell
PostPosted: 21:55 - 05 Mar 2009    Post subject: Reply with quote
Put a spanner on one nut to hold it still. Use a second spanner on the other nut. Make sure you use a ring spanner or a socket. Undo one of them, if the bolt inside turns with the nut you are working on then it should undo from the nut on the opposite side.
You may end up pulling the whole bolt out with one nut still attached, just use molegrips and a spanner to remove the remaining nut.
XT1200Z and a DR350 in bits
MattEMulsion
PostPosted: 07:44 - 06 Mar 2009    Post subject: Reply with quote
yen_powell wrote:
Put a spanner on one nut to hold it still. Use a second spanner on the other nut...
Thats looks correct according to the picture, doing each side individually will just car the bar to turn all of the time.
Yamaha YZF-R6
Suitor_Stu
PostPosted: 12:13 - 07 Mar 2009    Post subject: Reply with quote
Thanks guys - I ended up having to go at the nut with a hacksaw cause nothing else was moving it. However once I got the nut off, I found that the bolt was bent (probably something to do with the fact I stood on the footpegs while they were loose - oops!) either way, this meant that I had to saw through the bent part of the bar which was over 1cm in diameter. Suffice to saw that my right arm is now twice the size it was!
Cheers, Stu
The last post was made 17 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 65.09 Kb
