sketchy bandit 600
mooserx
PostPosted: 19:11 - 06 Mar 2009    Post subject: sketchy bandit 600 Reply with quote
hello to all,
my friend has a bandit 600 which i tried to get going today after it has been stood since last spring, obviously the battery was dead, so after a jump start and a bit of tinkering i got it going. the battery was brand new last spring but with the bike not being used and the battery being as flat as a witches tit would this affect the battery's ability to hold a charge? i ask because when i went out for the test ride, the bike kept cutting out especially slowing down, i also noticed some flatspots in the power when throttling up and the fuelling seems a little wooly, any suggestions greatly received.
TL1000r-handful.
PostPosted: 19:46 - 06 Mar 2009    Post subject: Reply with quote
Yes, leaving a battery flat will knacker it in no time. Sounds like it's just about got enough to run the engine, using the brakes is dragging the voltage down and causing the misfire (brake light draining the power).
Replace it before you cook the charging system.
mooserx
PostPosted: 06:53 - 07 Mar 2009    Post subject: Reply with quote
cheers geri Thumbs Up Karma
TL1000r-handful.
The last post was made 16 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 35.81 Kb
