Sidelights - Noob question!
Thom
PostPosted: 16:52 - 07 Mar 2009    Post subject: Sidelights - Noob question! Reply with quote
Believe it or not i have only just discovered what sidelights are...
And i thought they were dipped beam Embarassed
Anyway, on the gpx400r and xj600s if i put my switch into the 'sidelights' position only the rear light illuminates on both bikes. However on an sv650 i have just seen it has a small light up front that illuminates.
Should the gpx400r and xj600s have a light on on the front when the sidelights are on? and if so where is the bulb as obviously this needs replacing!
Sorry this sounds so stupid, i can strip and engine now but bugger me if i understand electrics.
iooi
PostPosted: 17:19 - 07 Mar 2009    Post subject: Reply with quote
Well the XJ 600 certainly has a sidelight bulb.
Find it in the headlight at the bottom.
I would say most bikes have them in the same place as well.
Thom
PostPosted: 17:25 - 07 Mar 2009    Post subject: Reply with quote
looks like im going to have to replace it then!
Do they test it during an mot do you know?
Finglonga
PostPosted: 17:58 - 07 Mar 2009    Post subject: Reply with quote
Yes.
Andy Sez....
F.Y.Y.F.F.
Thom
PostPosted: 10:34 - 08 Mar 2009    Post subject: Reply with quote
Grrrr i hate replacing headlight bulbs theyre such a pain in the arse to get to.
Nevermind, looks like id better.
Cheers lads.
iooi
PostPosted: 10:52 - 08 Mar 2009    Post subject: Reply with quote
On this XJ. Stick your hand up the fairing between the forks and feel for the wires at the bottom of the light. Its just a rubber bung that you pull out. Its a lot easier than the main bulb Thumbs Up
Finglonga
PostPosted: 16:29 - 08 Mar 2009    Post subject: Reply with quote
Try some of the modern cars, some need the headlight unit to come out completely for any bulb to be replaced.
Andy Sez....
F.Y.Y.F.F.
The last post was made 17 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 2.26 - MySQL Queries: 13 - Page Size: 52.89 Kb
