Stripping front forks?
BenR
PostPosted: 19:27 - 08 Mar 2009    Post subject: Stripping front forks? Reply with quote
Hi all. I've been stripping my little wolf project & need to do the forks as the seals are well & truly shot the stanchions also are in bad need of recoating. I've worked on bikes for many years but I've never taken forks apart. A guy on the RGV forum gave me the manual for the RG125 but it's for the FUN which has USDs the wolf has ordinary right way up forks. All I can see on the legs is a big nut on the top but I take it they'll need draining first? How do I do this? Any help much appreciated cheers!. Thumbs Up
0ddball
PostPosted: 19:53 - 08 Mar 2009    Post subject: Reply with quote
Some basic forks don't have a drain hole, you just take off the spring cap and invert the fork while slowly pumping it to empty it.
BenR
PostPosted: 20:03 - 08 Mar 2009    Post subject: Reply with quote
Thanks for that mate. Will do it tomorrow cheers! Thumbs Up
Ichy
PostPosted: 20:25 - 08 Mar 2009    Post subject: Reply with quote
Most forks will have a bolt that passes up through the bottom of the fork into the damper rod. Hard to see unless you look for it.
take a look
https://www.motorcyclistonline.com/howto/replace_fork_seals/index.html
The last post was made 17 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 39.27 Kb
