Flat spot on CG125
webbaldo
PostPosted: 20:58 - 08 Mar 2009    Post subject: Flat spot on CG125 Reply with quote
How do, just recently moted my cg125 but ive noticed if you lightly blip the throttle it struggles, then after the flat spot its fine through the rest of the throttle range
is this just fuel/air mix issue? Throttle cable seems fine and smooth in movement.
Acemastr
PostPosted: 21:13 - 08 Mar 2009    Post subject: Reply with quote
Do you mean opening it up from idle? My YBR won't rev hard from idle no matter what. Otherwise yea, sounds like fuel mixture, or a dirty carb.
2016 Toyota Tacoma Limited
webbaldo
PostPosted: 09:36 - 09 Mar 2009    Post subject: Reply with quote
I mean it stutters before you can open the throttle. I dont mean reving it hard just from idle.
Gawain
PostPosted: 16:35 - 09 Mar 2009    Post subject: Reply with quote
Clean the carb esp the emulsion tubes/needle jet and the air filter. Should sort it.
The last post was made 17 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.6 - MySQL Queries: 13 - Page Size: 38 Kb
